EdPa
WinBox v3.39 released!
Wed Jul 26, 2023 2:02 pm
What's new in v3.39:
Important note!!!
Upgrade from older WinBox versions might not work due to the new digital signature. Manual WinBox upgrade is required.
*) added support for QR code field;
If you experience version related issues, then please report them to support@mikrotik.com.
Both Winbox 32-bit and 64-bit versions are available here:
https://www.mikrotik.com/download
normis
Re: WinBox v3.39 released!
Wed Jul 26, 2023 2:04 pm
Quick Tip: Now you can use Back To Home feature with regular Wireguard app in your phone or other device. Once BTH has been set up, in your "IP -> Cloud" menu you will be able to scan a QR code from any device with a stock Wireguard app, to quickly configure the tunnel there.
rextended
Wed Jul 26, 2023 2:06 pm
Apart from this:
If one doesn't use that feature at all, do you still recommend upgrading because something else, not reported, has also been fixed?
Thank you.
normis
The only changes:
1. New EXE signature (no effect for users)
2. QR code support
ErfanDL
Wed Jul 26, 2023 2:48 pm
The dark theme is an important feature that you do not add!
normis
Wed Jul 26, 2023 2:53 pm
Why is it important?
Spirch
Wed Jul 26, 2023 2:59 pm
would it be possible to add an option to auto enable safe mode on connection?
Maggiore81
Trainer
Trainer
Wed Jul 26, 2023 3:05 pm
I tried to upgrade... upgrade file is corrupt, on three different pc
EDIT: I tried the auto-upgrade mode and if failed with 3 different PCs.
I didnt replace the exe though.
mkx
Wed Jul 26, 2023 3:18 pm
Did you bother to read opening post in this thread. It says:
Important note!!!
Maggiore81
Trainer
Trainer
Wed Jul 26, 2023 3:21 pm
Yes, I read. It says "might not work". I just reported my experience.
mkx
Wed Jul 26, 2023 3:29 pm
The problem is that you wrote "upgrade file is corrupt" which is something very different from what was mentioned in announcement (and is probably the reason for upgrade to fail). If you phrased your post like "upgrade fails indeed, I tried on 3 different pcs", the meaning would be whole lot different (for starters, it would show that you did read the announcement and that you encountered the predicted problem).
Maggiore81
Trainer
Trainer
Wed Jul 26, 2023 3:31 pm
You are right! I just wrote quickly
normis
New phrasing, in case this will be more clear:
Built in upgrade will not work! This is because new Winbox has new exe signature. It will say "upgrade file corrupt". So download new winbox manually here: https://mt.lv/winbox64.
holvoetn
Wed Jul 26, 2023 3:32 pm
I kind of agree there. That line should be changed to "it will probably not work so upgrade manually".
EDIT: and it's done :lol:
I've seen it happen too (hey, maybe I was lucky... ) but after the first occurrence I already made my conclusion how to proceed for the second one.
And the message effectively said "file is corrupt". Quite confusing ...
BillyVan
Wed Jul 26, 2023 3:38 pm
Windows find some virus on 64 version
normis
Wed Jul 26, 2023 3:39 pm
Try other antivirus software
Spirch
Wed Jul 26, 2023 3:47 pm
when running on windows 10 enterprise, up to date as of yesterday
andriys
Wed Jul 26, 2023 3:52 pm
...new Winbox has new exe signature.
Something's wrong with this signature:
normis
Wed Jul 26, 2023 3:58 pm
RE-DOWNLOAD PLEASE.
FIXED :)
K0NCTANT1N
Wed Jul 26, 2023 4:42 pm
Why hasn't it been added to the window header next to the name "WinBox" to display its version when it is connected?
The dark theme is very interesting and useful for tired eyes.
chechito
Wed Jul 26, 2023 4:53 pm
Maybe Dark Theme is not important but, nowadays is a very common feature on most desktop applications, many websites include it also, in my case i use it every day when available
holvoetn
Wed Jul 26, 2023 4:59 pm
And I avoid it like the plague...
I hate dark theme.
rextended
Wed Jul 26, 2023 6:12 pm
Those who want the black theme don't really work, they just want it as a whim "because others do it"...
Try to work under the sun with a fuck–g black theme that doesn't let you see correctly what is present on the screen....
holvoetn
Wed Jul 26, 2023 6:40 pm
Quod Erat Demonstrandum.
raffav
Wed Jul 26, 2023 10:01 pm
something is in the 64x is triggering the Microsoft Defender SmartScreen and preventing from downloading, the 32bit is ok....
normis
Wed Jul 26, 2023 10:09 pm
See above, re-download for the fix
szalkerous
Wed Jul 26, 2023 11:23 pm
Try to work under the sun with a f---–g black theme that doesn't let you see correctly what is present on the screen....
Will all respect intended, I work in front of three large monitors for 10+ hours a day, dark themes save my eyes a lot of stress.
Just because you don't see it as useful does not automatically mean it's not useful to anyone. ;)
I would very much like that feature.
spippan
Wed Jul 26, 2023 11:43 pm
"don't really work" ... how come you conclude that?
working at a DC for over 6 years and in IT/ISP well over 10 years and where there is a good implementation of a dark theme i use it. it is way easier on the eyes
if you are out in the sun - switch to your beloved whatever-not-dark-theme or upgrade to a good display
EDIT:
+1 for dark-theme option to be switchable
holvoetn
Wed Jul 26, 2023 11:47 pm
I am mostly inside.
Usually I don't even switch on the lights in the office because I can't stand the light.
And yet I don't want dark theme.
Working with computers since 1980.
I started on monochrome CRT screens so I know what it is like to have black background.
Still don't like it.
spippan
Wed Jul 26, 2023 11:49 pm
I am mostly inside.
same with the light.
well ... good for you if you do not like it. why is it such a thing for people here on a dark theme to be asked for implementation?
if it is there as an option and you do not need to use it... do, not, use, it!
TomjNorthIdaho
Wed Jul 26, 2023 11:52 pm
I tried to update my Winbox on several of my computers to v3.39
All of them give me "ERROR: Upgrade file was corrupted"
holvoetn
Wed Jul 26, 2023 11:54 pm
I get it some do want dark theme.
But it is not there now and there are more urgent things to fix, no ?
So let's use resources where they are most beneficial.
And then, when all is done and fixed, we pull out the someday/maybe list and see what's left there 🤔
holvoetn
Manual upgrade :lol:
chechito
Wed Jul 26, 2023 11:55 pm
downloaded 5 minutes ago (manually downloaded from website)
TomjNorthIdaho
Wed Jul 26, 2023 11:57 pm
OOOooo , I guess I should read the post first then do ...
K0NCTANT1N
Wed Jul 26, 2023 11:58 pm
Yet again...
If you are not interested in the dark theme, then you should not respond to such messages, and do not use the dark theme. That's what the right to choose is for.
holvoetn
Chechito
Also that problem should have been fixed ?
But the file should be named winbox64.exe ?
K0NCTANT1N
Thu Jul 27, 2023 12:08 am
Yet again...
To everyone else
chechito
Thu Jul 27, 2023 12:12 am
Chechito
name was modified by me, to be able to distinguish from the other versions in the folder
chechito
Thu Jul 27, 2023 12:16 am
To everyone else
Yeah, i agree with you nobody said anything about a Mandatory not switchable Dark Theme
interested people in dark theme just want to have the option to be able to select Dark Theme if they want
i cant believe this kind of clarifications are needed for such a simple topic
looks like empathy is scarce these days
raffav
Thu Jul 27, 2023 1:39 am
Microsoft edge keep saying that have a virus on the 64bit
coddy
Thu Jul 27, 2023 3:01 am
Just manually downloaded winbox64.exe and it still has the invalid digital signature due to being signed after the signing certificate had expired... Either it has been signed with an expired certificate (and signed after the certificate expiry date) or if MT have fixed the problem (i.e. They must have signed it with an expired certificate to start with - Yes they did I have the digitally signed proof, published it, then published a new file after discovering the mistake - hopefully).
So either (1) They are continuing to sign with an expired key or they have update the key, resigned the file and there is a caching issue at MT end (since this is the first time I've downloaded the file).
Content-Length 2287960
Content-Type application/octet-stream
Date Wed, 26 Jul 2023 23:41:18 GMT
ETag "64c0f648-22e958"
Last-Modified Wed, 26 Jul 2023 10:32:40 GMT
Server nginx/1.18.0
winbox64.exe SHA256: 475ff5996ad6558f2966eb26129e167d48105105b0e4d5e44b8c4d57f6a84627
It says the certificate "Mikrotikls SIA" is valid from "10-Feb-2020 to 10-May-2023", so obviously that certificate would be outside of its validity range to have just signed a new winbox64.exe executable.
@MT please check your signing key is updated, and that your publishing system is using the new signing key.
nichky
Thu Jul 27, 2023 5:23 am
@normis
how u mean , Back To Home feature with regular Wireguard app in your phone or other device.
Does Back To Home work independent?
pls need more info
Spirch
Thu Jul 27, 2023 6:31 am
between dark theme and an option to automatically turn safe mode on, i would do safe mode first and then dark theme
siuswat
Thu Jul 27, 2023 7:35 am
I found that there are 2 versions of winbox64.exe when I download from different networks on Mikrotik main site. It looks like some CDN / Web servers are not updated with latest version. Mikrotik should publish the hash of their firmwares and winbox software
Expired certificate winbox64.exe SHA-256
SHA-256 475ff5996ad6558f2966eb26129e167d48105105b0e4d5e44b8c4d57f6a84627
Valid certificate winbox64.exe SHA-256
SHA-256 b4ff98aa38183948beb78b2d5077bad116d166b520f869bcfb5936811fd11dad
mazel
Thu Jul 27, 2023 9:03 am
If now Winbox has *) added support for QR code field, what about button or command to generate QR code for Wi-Fi login from configuration?
nichky
Thu Jul 27, 2023 9:20 am
i think i got that, with back-to-home u can add allowed-address manually,which is so hendy.
ToTheFull
Thu Jul 27, 2023 11:08 am
Thanks for the FIX for the QR code, much better!
Re-downloaded as advised.
normis
Thu Jul 27, 2023 2:42 pm
Yes, it gives possibility to make something like that for the future. Do you really need it in the Winbox? Will you show Winbox to your family, when they come over? You can just use this and print it: https://www.qr-code-generator.com/solut ... i-qr-code/
mazel
Thu Jul 27, 2023 2:56 pm
I usually use https://qifi.org/, however it would be nice to have this feature directly in Winbox, better with possibility to export it as image. As no one can be 100% sure that SSID and password is not stored anywhere by 3rd party (owner of QR generator website). Also it might come to Mikrotik mobile apps (Home or Pro app), right? :D It is just "nice to have" feature (configure network, export QR, print it and connect). :D
rextended
Thu Jul 27, 2023 3:04 pm
roe1974
Thu Jul 27, 2023 5:07 pm
How did you get the logo in the middle?
rextended
Thu Jul 27, 2023 5:12 pm
With my hands.
roe1974
Thu Jul 27, 2023 5:15 pm
what else 😜🤪
rextended
Thu Jul 27, 2023 5:19 pm
what else 😜🤪
:lol:
"Gimp" ?
AdHocCZ1
Thu Jul 27, 2023 7:43 pm
INFO: regarding QR codes for wifi processed locally...
1/ to generate and print QR -- can be done via label printers and their sw -- they can do that also as batch processing using database/csv.
2/ just to share QR code for wifi -- some smartphones today can natively show QR code for connected wifi -- just tap on connected wifi in the settings.
Of course you can also printscreen displayed QR code and send the image to any printer -- only some taps on the phone.
SIDENOTE1: Not having phone photos autosync to the cloud (and also not having wifi logins autobackup to the cloud) can be recommended...
SIDENOTE2: Some more advanced auth methods than one pwd (Personal mode) for SSID can be recommended also.(i.e. Enterprise ways)
and RouterOS offers several ways/functions for that.
roe1974
Thu Jul 27, 2023 8:33 pm
what else 😜🤪
:lol:
"Gimp" ?
no, all good :-)
huntah
Thu Jul 27, 2023 9:36 pm
QR Code is very useful if it would be implemented in UserManager-Users.
There is a field OTP Secret.
It works which GoogleAuth!
I use this QR Generator:
https://jwessel.github.io/totp-gauth-to ... rator.html
But if Mikrotik would implement this in Winbox or even better WebPortal. We could have a nice 2FA solution for VPN!
pe1chl
Thu Jul 27, 2023 10:03 pm
As this apparently has turned into a wishlist for winbox, let me add my 2 cents:
- settable timeout for router connections, so that a 5 second interruption of the network does not always result in a disconnect
- better recognizable "active" state of the Safe Mode button (make it yellow or red when active, not just a different shade of grey)
- allow to "lower" a window in the windows list (e.g. via right-click), in addition to the current possibility of "rising" a window
- make the BGP "sessions" window auto-refreshing, like the BGP "peers" window was with v6 RouterOS (and like most other windows are)
- change the .viw files from binary to some user readable and editable format (JSON, XML, text, whatever). I HATE to have to discard an entire .viw file because there is some small corruption in it. and unfortunately, these occur all to easily over time
- fix the bug in skin handling where the menu buttons hidden in webfig skin still appear in winbox
rextended
Fri Jul 28, 2023 12:18 am
+1
+1
+1
+1
+1
+1
+1
+1
uhm... +1
+2
mt99
Fri Jul 28, 2023 12:44 am
Totally agree that MT should publish the Winbox hash in their checksums list like their NPKs. In the meantime, I'm used to validating the digital signature. But I recently moved to running Winbox in Wine and I wasn't able to find a GUI way to do that. Here's what I ended up doing:
* Downloaded Sigcheck from Sysinternals
* Opened Terminal and typed "wine cmd" to get a Windows command prompt
* Navigated to the Sigcheck path and entered the following: sigcheck -accepteula -a -i your_Winbox_path
In the output, you see whether the file is signed or not as well as show/validate the certificate chain. And yes, on real Windows you could follow these steps as well if you'd rather use the command line for some reason.
nichky
Fri Jul 28, 2023 3:48 am
roe1974
Fri Jul 28, 2023 10:08 am
THX !!!!! :-)
spippan
Fri Jul 28, 2023 1:59 pm
+1
you can cycle trough windows in WinBox with [F6] as a workaround
+1 YES PLS!
still a thing? works for me
pe1chl
Fri Jul 28, 2023 3:35 pm
Thanks! I did not know that. I always open a Log window and set it to full screen size and use that as a backdrop to open other windows on top of that.
One click in the wrong place and the Log window is the top window and all others are gone.
I would like to "lower" the Log window e.g. via Windows->Log->Right-Click so all the others re-appear.
However, with a couple of F6 presses it also sort of works and is a bit easier than going along all other windows to raise them.
Try to hide the MPLS menu. It has several sub-menus. When (in Webfig) MPLS is removed (and even when all sub-menus are removed), in Webfig the MPLS item is completely gone, but in winbox it remains visible but when clicked it shows an "empty" (small) submenu.
When an item like Quick Start, which has no sub-menus, is removed it correctly disappears from the menu bar.
AdHocCZ1
Fri Jul 28, 2023 11:01 pm
If any GUI improvements to winbox...
1/ BIG THANKS FOR KEEPING the old=archaic=great=reliable=clean=GOLDEN_STYLE of GUI without any "modern improvements"
2/ ...to ...
100/ repeat of the (1/) ... no joking. I am just that thankful ...
About welcome improvements not mentioned yet in this thread.
101/ better definition of three/four Alt-hotkeys in main menu -- as e.g. now there is a lack of resolution for Session/Settings as shown below.
(Suggestion is based on my experience fixing such things in MS dev center 20+ years ago.)
Collision = (black+bold=to_keep) vs (red+bold=to_change),
Solution+Suggestion = (blue+bold=changed-fixed)
now: | &Session | &Settings | &Dashboard
new: | &Session | S&ettings | &Dashboard
now <&Session>: | &New | &Open | &Save | &Save As | &Autosave on Close | &Close All Windows | &Disconnect | &Exit |
new <&Session>: | &New | &Open | &Save | Save &As | A&utosave on Close | &Close All Windows | &Disconnect | E&xit |
And of course underscores for Alt-hotkeys in menus to be shown when it is set so in OS (or maybe better - always...)
102/ EDIT: reworded -- making more clear:
Wondering why there is <Exit> button on the left pane on one click with no confirmation,
when the same can now user do safer by two clicks via main menu (Session > Exit).
WHY IMPORTANT?: Because misclicking on the <New WinBox>
cause immediate/without_confirmation <Exit> (hopefully not exitus in some stress situation).
So maybe a NEW main menu item <S&ettings> --> <Deactivate-Hide Exit button> as is for <Hide Passwords>
103/ Would appreciate <NewWinBox> and <Windows> as NEW main menu items:
now main menu = &Session | &Settings | &Dashboard |
new main menu = &Session | S&ettings | &Dashboard | &NewWinBox | &Windows |
And if none of that will happen ... never mind. WinBox is one of my favorite sw helping me to keep a good mood.
Cha0s
Sat Jul 29, 2023 2:39 pm
2/ ...to ...
+1
spippan
Sat Jul 29, 2023 7:26 pm
ur welcome
oh i just tested it again and it does not work at all ... webgui yes, winbox no.
like winbox totally ignores the skin settings. but i remember it working some time in the past. did not test this any further so no idea since WHEN it doesn't work any longer
infabo
Long time Member
Long time Member
Sat Jul 29, 2023 10:25 pm
spippan
Sun Jul 30, 2023 2:16 pm
if i had not pressed SAVE it also would not work in the webGUI.
did that.
but thanks for the hint
pe1chl
Sun Jul 30, 2023 2:27 pm
Remember it only works from some v7.x version, not before and not on v6.
Here it does something, but with a bug: not able to hide menu entries when there are sub-menus.
kidalabama
Sun Jul 30, 2023 5:14 pm
Tools, Check for updates.
Error: Upgrade file was corrupted.
holvoetn
Sun Jul 30, 2023 5:20 pm
Read everything on the first post including the 2nd part of the important note.
Important note!!!
spippan
Sun Jul 30, 2023 8:53 pm
it is literally the first thing the "important note" section states.
nmt1900
Mon Jul 31, 2023 5:01 pm
Would really appreciate if Auto reconnect on RoMON connections became really usable. If Address list is protected by master password, then connection loss will lead to "Error. disconnected from RoMON" - awaiting re-entry of master password. This happens even when connections is lost to RoMON neighbour while RoMON agent itself is accessible all the time. It looks like address and therefore RoMON agent list cannot be accessed because address list is locked by master password.
For straight connections (MAC or IP based) this problem does not occur and even when reconnect is canceled, address list stays unlocked until Winbox is closed.
pe1chl
Mon Jul 31, 2023 5:04 pm
I have quickly given up on "auto reconnect"... too many issues.
Instead I would prefer when sessions do not disconnect so easily.
nmt1900
Mon Jul 31, 2023 5:10 pm
It has almost always worked on straight IP connections - connection is re-established even after rebooting the device. Something is borked in case of RoMON connections because address list gets locked...
pe1chl
Mon Jul 31, 2023 7:59 pm
Well, one problem I have with it is that I use workspaces (virtual desktops) and when a connection is closed and auto-reconnected the window opens on the currently visible workspace instead of the one it originally lived on.
That could be fixed by not closing and re-creating the window in case of an auto reconnect.
Cha0s
Mon Jul 31, 2023 9:29 pm
I essentially gave up on MikroTik fixing Winbox for these 'usability bugs'. These issues with multiple monitors/virtual desktops, started (at least for me) after v3 winbox. v2 worked perfectly fine on multiple monitors, it remembered each session on which monitor to load, etc. As one would expect really.
I mentioned them a couple of times in the first versions of v3, but I got thoroughly ignored, so I ended up using a 3rd party app (DeskSoft Window Manager) that forcefully moves windows wherever I want depending on various factors (executable name, window title, etc).
Unfortunatelly this doesn't solve another bug with winbox, that is, when it loses connection to a router and reconnects, sometimes the window will load on the top left corner at around 1024*768 (or smth) size, essentially destroying all windows placements within winbox. Window Manager will resize the window after the fact, so it doesn't really solve the problem.
Again, I resorted to a 3rd party solution, by keeping all my sessions on my Nextcloud, so when they get messed up, I simply revert the affected ones to a previous version.
pe1chl
Tue Aug 01, 2023 11:28 am
I am running Winbox on Linux with Xfce. There are capabilities like that (pinning windows to certain workspaces) but my use of Winbox is too varied to make that work.
Although it now is a lot better due to the availability of BFD in v7, there still are occasional interruptions in the network that take long enough for Winbox to disconnect from a router (that does not take long!) and when I have auto-reconnect it re-opens on the workspace where I am currently working and I risk clicking on something I do not want. Or, when I come back to my system I find a number of Winbox windows (that normally are on different workspaces) opened all on top of eachother on the currently active workspace.
So I just disabled auto-reconnect...
The reason I ask for "- change the .viw files from binary to some user readable and editable format (JSON, XML, text, whatever)." is that I have .viw files that A LOT of work have been spent on to get everything correct, and then they build minor corruptions that probably could be fixed by removing a paragraph describing some particular window, but the file cannot be edited. Like you, I of course have regular snapshots and backups of .viw files, but corruptions may sneak in over time. Some windows won't remember the position/width of one particular column anymore, for example. Starting fresh with a new session fixes it, but means a lot of work is lost.
densenator
Tue Aug 01, 2023 2:23 pm
Also There is no "Make static" item in the DHCP Leases menu.
ErfanDL
Tue Aug 01, 2023 2:58 pm
It is important because it blinds people at night with this white theme.
holvoetn
Tue Aug 01, 2023 3:19 pm
Yes there is.
Used it several times yesterday.
ivicask
Tue Aug 01, 2023 4:23 pm
Yes there is.
It used to be there on right click menu of lease and it was gone at some point recently, you need to open lease to see Make Static button.
holvoetn
Tue Aug 01, 2023 4:36 pm
Oh I see ... I never used that right click menu.
K0NCTANT1N
Tue Aug 01, 2023 7:29 pm
I do not understand why "invalid" when setting the time
rextended
Tue Aug 01, 2023 7:32 pm
What day ?
K0NCTANT1N
Wed Aug 02, 2023 12:43 am
What day ?
it doesn't matter if I set the day of the week or not
Cha0s
Wed Aug 02, 2023 2:56 am
It used to be a "Make Static" button between the Filter button and "Check Status" button.
At some point this got removed, for no apparent reason, and was put in the context menu of each lease.
Recently, the context menu option was removed and the old "Make static" button got re-instated.
So for years it was a button, we got used to that, then it was moved to the context menu, we got used to that, and now it's back as a button.
Dumb UI decisions that ruin muscle memory...
Cha0s
Wed Aug 02, 2023 3:03 am
I agree, a editable format is much preferred. I have the exact same problems you describe with old sessions that have grown too much and gotten corrupted over the time to the point that even viewing the routing table may randomly completely crash winbox (it simply exits, no error, no exception, no nothing).
But it is so much work to rebuild everything from scratch that I just put up with it....
Having a readable format, will allow for creating a basic template and use that to incorporate to multiple sessions in a semi automatic way with scripting.
I know I can do the same now, by having a basic preconfigured session and build on top of that for each router, but, when having literally hundreds of routers on winbox, it not feasible.
pe1chl
Wed Aug 02, 2023 11:47 am
That is the exact problem I have too! "IP->Routes" sometimes just exits winbox.
And: in IP->Firewall->Mangle (for example), a column "New Packet Mark" can be added but it does not "stick", every time I close that window and re-open it, the column is gone and when I re-add it, it appears beyond "Comments" and I have to drag it into view.
I think it is partly related to migrating a .viw file along too many RouterOS versions, where features appear and disappear and/or change name.
I know that both of these problems can be fixed by starting a new session file, but that is just too much work.
When I could read the .viw file and look for the sections pertaining to "IP->Routes" and "IP->Firewall->Mangle", maybe I could see what is wrong or at least I could remove these sections and have to reconfigure only those particular windows instead of everything.
MikroTik: PLEASE consider doing this. It should be easy to auto-detect the format on read, and on write change to a new format.
sinisa
Wed Aug 02, 2023 10:47 pm
+1 (or *100 maybe) for readable&editable config
Registry is so out of fashion... well, at least in Linux
pe1chl
Fri Aug 18, 2023 4:59 pm
Another feature request: when enabling a "filter" in winbox, after adding one or more filter rules, then disabling the filter, please remember the filter rules so that when filter is enabled again the last-used rules re-appear, and not a blank new filter.
Also when changing the filter topic on an existing filter line, e.g. from Src.Address to Dst.Address, please do not clear the match condition and value.
(these should be kept when the topic is changed to another one of the same data type)
volatilemolotov
Sat Aug 19, 2023 1:57 pm
Is there a way to use QR feature for Wireguard peers? As in without BTH
spippan
Mon Aug 21, 2023 11:36 am
also please add an option to choose between AND/OR matching for more than 1 filter rule
spippan
Tue Sep 19, 2023 4:32 pm
maybe also useful to add a "bind to interface" for winbox operation or discovery
maybe something like this
EdPa
Tue Oct 10, 2023 3:05 pm
WinBox v3.40 is released.
viewtopic.php?t=200431
Users browsing this forum: No registered users and 8 guests
