What does your config look like so far..
add name=DHCP-Server
set [ find default-name=ether2 ] name=ether2-LINK1
set [ find default-name=ether3 ] name=ether3-LINK-L2
set [ find default-name=ether4 ] name=ether4-SERVER
set [ find default-name=ether6 ] name=ether6-DHCP-Server
set [ find default-name=ether7 ] name=ether7-DHCP-Server
set [ find default-name=ether8 ] name=ether8-DHCP-Server
set [ find default=yes ] supplicant-identity=MikroTik1
add name=dhcp_pool ranges=192.168.0.2-192.168.0.254
add address-pool=dhcp_pool disabled=no interface=DHCP-Server \
name=dhcp1 relay=192.168.0.1
add bridge=DHCP-Server interface=ether6-DHCP-Server
add bridge=DHCP-Server interface=ether7-DHCP-Server
add bridge=DHCP-Server interface=ether8-DHCP-Server
add address=10.0.0.1/30 interface=ether3-LINK-L2 network=10.0.0.0
add address=192.168.0.106 interface=ether4-SERVER network=192.168.0.0
add address=192.168.0.1 interface=DHCP-Server network=192.168.0.0
/ip dhcp-client
add disabled=no interface=ether2-LINK1
add address=192.168.0.0/24 gateway=192.168.0.1
add check-gateway=ping distance=1 dst-address=192.168.1.0/24 gateway=\
ether3-LINK-L2
/system identity
set name=RB-Loja1
I need just a north about how to do the rest. Wich protocols should i focus to study and make this happen?I see no clear definition of TWO WANS.
Nor do I see any load balancing config ie mangling???
It's just for fun and knowledge. I already solved the problem about communication between the networks 0.0 and 1.0 adding static route.Is this a business? If so, then get some proper training MT courses, or hire a consultant.
I am not the one to teach you all about MT configurations for such a venture, especially when you have seemingly no MT knowledge.
If you are a home owner different case.
