i went through other topics, but not found any idea how to solve my issue
Till now, i was using OSPF on ROS6.x for couple years now, and it works like a charm.
Recently i upgraded to ROS7 and "things" started, but it looks like a config issue for me. I did inplace upgrade, so everything(config) should stays the same, but in ROS7 there are slightly different UI / CLI for OSPF than it was in ROS6.
So, my situation: From NW perspective, i have one central router with static IP and several remote routers in different locations (always 1 rb in 1 location) with dynamic IP. I am using SSTP to connect all those remotes to central.
Running version of all RBs is 7.10.2 - different platforms tested - chr, arm, mmips, mipsbe
Central config:
Code: Select all
/ppp/profile/print
1 name="vpn_ring" bridge=br_vpn bridge-learning=default use-ipv6=no
use-mpls=default use-compression=default use-encryption=required
only-one=default change-tcp-mss=default use-upnp=default address-list=""
on-up="" on-down=""
/interface/bridge/print
0 R name="br_vpn" mtu=auto actual-mtu=1500 l2mtu=65535 arp=enabled
arp-timeout=auto mac-address=FA:64:9F:3A:A7:B0 protocol-mode=rstp
fast-forward=yes igmp-snooping=no auto-mac=yes ageing-time=5m
priority=0x8000 max-message-age=20s forward-delay=15s
transmit-hold-count=6 vlan-filtering=no dhcp-snooping=no
So anytime sstp is established, it is automatically assigned to this bridge as slave. Client remotes have different accounts, so different sstp tunnels are established and all of them are in this bridge.
Clients have same bridge with static adresses from 172.20.1.0/28 range.
As all the sites have several subnets (no overlaping), i decided to run ospf several years ago. But what started to happen after upgrade to ROS7 is, that anytime there is a change state on any tunnel (down/up ... disconnect, connect), all the ospf routes are dropped from all tables, i mean, also those which are not relevant/affected by the tunnel which is changing state.
OSPF config after upgrade:
Code: Select all
area/print
Flags: X - disabled, I - inactive, D - dynamic; T - transit-capable
0 name="backbone-v2" instance=default-v2 area-id=0.0.0.0 type=default
instance/print
0 name="default-v2" version=2 vrf=main router-id=172.20.1.1 redistribute=connected
interface-template/print
0 area=backbone-v2 interfaces=br_vpn instance-id=0 networks=172.20.1.0/28 type=broadcast
retransmit-interval=5s transmit-delay=1s hello-interval=10s dead-interval=40s priority=1 cost=10 auth=md5
auth-key="*********" auth-id=3
When everything is stable, it is working. Anytime there is state change on interface, everything is dropped and recalculated - so it tooks several seconds without any routes.
Any ideas?
Thank you
