Hi, after problem solving and reading for the past couple of days I have to try the forum. What am I missing?
My setup:
- Sierra Wireless MC7700 mpcie (unlocked according to DC-unlocker, and I have two MC7700 I am playing with)
- RB922UAGS-5HPacD running ROS 7.10.2 (I have two of these as well)
- Winbox
- Sierra Wireless DIP-QMI switcher
- USB to mpcie adapter for Windows firmware flashing
Many of the guides and previous solutions don't work anymore, as MT has moved and renamed a lot of the LTE commands.
MC7700 Firmware:
Tried a lot of different firmware, and no difference, all of the DIP type:
- 03.05.20.03
- 03.05.23.02 (MC7710 just for kicks)
- 03.05.19.00
- 03.05.29.03
- 03.05.14.00
I can't flash if the modem if it is in DIP mode, I have to switch to QMI, flash and then switch back to DIP.
Using DIP (mbim)
- I can see the lte1 interface, but nothing happens when I enable it. LTE log shows nothing other than device enabled/disabled
- Trying some AT commands gives me the error "modem not ready"
Using serial mode
- ppp-out1 is created, and i can read the info of the modem from channel 3, most times
- I can establish a connection from channel 2, but no ip nor traffic is showing, but the status is connected and info show "GSM compact"
- IMSI says "Error"
- Operator is "Telenor Telenor (cellid: 17cf, lac: 2f4f"
