martinii
"not responding" - f.k.a. SA Query timeout
Thu Aug 17, 2023 10:53 pm
Hi all,
I have problem with my father's phone (Samsung A3 2016, stock OS) in my wifi network. I had Mikrotik hAP lite before and there was absolutely no problems! Now I have Mikrotik hAP ax2 and my Dad can't connect to my wifi because of SA Query timeout error. I have few devices (phones, laptops and TV) in my wireless network and there is problem ONLY with this one device... I upgraded router os few times and now i'm on 7.11 stable. I tried Disable PMKID = YES but without success either. Look:
This is part of my configuration:
# 2023-08-17 21:35:25 by RouterOS 7.11
# software id = **ELIDED**
# model = C52iG-5HaxD2HaxD
# serial number = XXXXXXXXXXXX
add name=bridge-LAN
set [ find default-name=ether1 ] mac-address=XX:XX:XX:XX:XX:XX
/interface wifiwave2 channel
add band=2ghz-n disabled=no frequency=2447 name=channel-2.4GHz \
    skip-dfs-channels=all width=20mhz
add band=5ghz-ax disabled=no frequency=5280 name=channel-5GHz width=20/40mhz-eC
/interface wifiwave2 security
add authentication-types=wpa2-psk disable-pmkid=yes disabled=no encryption="" \
    name=sec-profile
/interface wifiwave2 configuration
add channel=channel-2.4GHz country=Poland disabled=no mode=ap name=cfg-2.4GHz \
    security=sec-profile ssid=KMPM_nomap
add channel=channel-5GHz country=Poland disabled=no mode=ap name=cfg-5GHz \
set [ find default-name=wifi2 ] channel=channel-2.4GHz channel.frequency=2447 \
    configuration=cfg-2.4GHz configuration.mode=ap disabled=no name=2.4GHZ
set [ find default-name=wifi1 ] channel=channel-5GHz configuration=cfg-5GHz \
    configuration.mode=ap disabled=no name=5GHz
add name=pool-dhcp ranges=192.168.44.10-192.168.44.35
add name=dhcp_pool1 ranges=192.168.44.2-192.168.44.254
add address-pool=pool-dhcp insert-queue-before=bottom interface=bridge-LAN \
    lease-time=3d name=dhcp1
add bridge=bridge-LAN interface=ether2
add bridge=bridge-LAN interface=ether3
add bridge=bridge-LAN interface=ether4
add bridge=bridge-LAN interface=ether5
add bridge=bridge-LAN interface=5GHz
add bridge=bridge-LAN interface=2.4GHZ
/ip dhcp-server lease
add address=192.168.44.24 client-id=1:a8:9c:ed:4e:b3:ad mac-address=\
    XX:XX:XX:XX:XX:XX server=dhcp1
add address=192.168.44.23 client-id=1:94:be:46:cf:1:76 comment="Tablet Matika" \
    mac-address=XX:XX:XX:XX:XX:XX server=dhcp1
add address=192.168.44.21 client-id=1:78:af:8:80:97:b5 mac-address=\
add address=192.168.44.20 client-id=1:20:34:fb:cb:e2:f8 mac-address=\
add address=192.168.44.19 client-id=1:8c:c8:cd:59:a2:99 comment="TV SAMSUNG" \
add address=192.168.44.18 client-id=1:bc:60:a7:cd:db:c5 comment=PS4 \
add address=192.168.44.0/24 gateway=192.168.44.1
Help needed.... :(
tangent
Re: SA Query timeout
Fri Aug 18, 2023 12:22 am
I'm terrible at RouterOS WiFi, but a few things in your config raised questions:
1. Why disable PMKID? According to the docs, "Disabling PMKID can cause compatibility issues with client devices which make use of it."
2. encryption=""? Is that just you being over-zealous with the config sanitization, or do you really have all encryption methods disabled?
gigabyte091
Fri Aug 18, 2023 6:29 am
I suggest you to send supout file and log to the support. I had similar problem and i sent them file and log but my AC but problem fixed itself...
holvoetn
Fri Aug 18, 2023 8:24 am
Quick response before leaving for the road trip to France...
If you use WInbox, make sure that section is folded in.
NOT opened and nothing selected. Is not the same.
nescafe2002
Forum Veteran
Forum Veteran
Fri Aug 18, 2023 12:15 pm
Try disabling band steering. I noticed these SA Query Timeout messages just before re-associating with another radio.
https://help.mikrotik.com/docs/display/ ... properties
/interface wifiwave2 configuration set [find] rrm=no wnm=no
martinii
Fri Aug 18, 2023 10:54 pm
1. It was only for testing. But without success so returned to default.
2. I missed it out! I had nothing checked indeed... Now i have CCMP and GCMP.
So you suggest to leave only frequencies?
İmposss
Sat Aug 19, 2023 1:01 am
An issue that came with version 7.11. I reverted to version 7.10.2
nescafe2002
Forum Veteran
Forum Veteran
Sat Aug 19, 2023 3:16 pm
I suggested to disable band steering, as this was introduced in 7.11:
*) wifiwave2 - added "steering" parameters and menu to set up and monitor AP neighbor groups (CLI only)
Again, band steering is introduced in 7.11, therefore may be related to these issues.
İmposss
Mon Aug 21, 2023 3:20 am
Hi i tried it doesn't work
/interface wifiwave2 configuration set [find] steering.rrm=no steering.wnm=no
gigabyte091
Mon Aug 21, 2023 6:41 am
Did you try to contact Mikrotik support ? At this point they maybe can help you more.
martinii
Mon Aug 28, 2023 6:47 pm
I tried disable steering but no luck... Well I feel it doesn't matter what I do - it always doesn't work... On hAP ac lite no problems, on ax2 it still doesn't work...
holvoetn
Mon Aug 28, 2023 7:31 pm
Best recommendation to get... create supout.rif, contact support.
İmposss
Mon Aug 28, 2023 7:34 pm
I did, waiting for support
maigonis
Tue Aug 29, 2023 1:44 am
Try WPA2 only to isolate issue to security settings.
martinii
Tue Aug 29, 2023 10:47 am
I tried WPA2 only. As well as firmware upgrading, disabling band steering, disabling PMKID, turning off encription, disabling 5GHz radio and rebooting donzens times....
Rox169
Tue Aug 29, 2023 11:04 am
did you tried to delete/forget the network in mobile and do new connect???
martinii
Tue Aug 29, 2023 2:00 pm
Every time when I made some changes in router settings.
İmposss
Fri Sep 01, 2023 4:02 pm
solution for me:
/interface/wifiwave2/configuration> set [find] security.connect-priority=0/1
alibloke
Mon Sep 25, 2023 10:12 am
This appears to work, my laptop has been able to fast roam for the first time and the dreaded SA Query Timeout message is gone. I must admit I don't understand why and I'm concerned that it's working at the cost of security, specifically MacStealer attacks as per this post:
viewtopic.php?t=198228#p1016424
Can anyone elaborate on what this setting actually does?
ToTheFull
Mon Sep 25, 2023 1:01 pm
solution for me:
Yes please do, tired of this in my logs all the time when someone walks into the kitchen.
/log print where message~"C6"
 09-22 12:24:54 wireless,info C6:6B:0C@wifi1 connected, signal strength -61
 09-22 12:26:44 wireless,info C6:6B:0C@wifi1 disconnected, SA Query timeout, signal strength -73
 09-22 12:26:44 wireless,info C6:6B:0C@wifi1 connected, signal strength -75
 09-22 12:27:26 wireless,info C6:6B:0C@wifi1 disconnected, SA Query timeout, signal strength -68
 09-22 12:27:27 wireless,info C6:6B:0C@wifi1 connected, signal strength -71
 09-22 12:27:55 wireless,info C6:6B:0C@wifi1 disconnected, SA Query timeout, signal strength -69
 09-22 12:27:55 wireless,info C6:6B:0C@wifi1 connected, signal strength -71
 09-22 12:29:58 wireless,info C6:6B:0C@wifi1 disconnected, SA Query timeout, signal strength -68
 09-22 12:30:22 wireless,info C6:6B:0C@wifi1 connected, signal strength -68
 09-22 12:31:44 wireless,info C6:6B:0C@wifi1 disconnected, SA Query timeout, signal strength -71
 09-22 12:31:55 dhcp,info defconf deassigned 192.168.0.106 for C6:6B:0C
 09-22 12:31:56 dhcp,info defconf assigned 192.168.0.106 for C6:6B:0C
 09-22 12:31:58 wireless,info C6:6B:0C@wifi1 connected, signal strength -71
 09-22 12:32:24 wireless,info C6:6B:0C@wifi1 disconnected, SA Query timeout, signal strength -73
 09-22 12:32:24 wireless,info C6:6B:0C@wifi1 connected, signal strength -75
 09-22 12:32:33 wireless,info C6:6B:0C@wifi1 disconnected, SA Query timeout, signal strength -72
 09-22 12:32:34 wireless,info C6:6B:0C@wifi1 connected, signal strength -75
 09-22 12:32:38 dhcp,info defconf deassigned 192.168.0.106 for C6:6B:0C
 09-22 12:32:39 dhcp,info defconf assigned 192.168.0.106 for C6:6B:0C
 09-22 12:32:49 wireless,info C6:6B:0C@wifi1 disconnected, SA Query timeout, signal strength -70
 09-22 12:32:50 wireless,info C6:6B:0C@wifi1 connected, signal strength -73
 09-22 12:34:18 wireless,info C6:6B:0C@wifi1 disconnected, SA Query timeout, signal strength -77
 09-22 12:34:19 wireless,info C6:6B:0C@wifi1 connected, signal strength -76
 09-22 12:38:17 wireless,info C6:6B:0C@wifi1 disconnected, SA Query timeout, signal strength -71
 09-22 12:38:17 wireless,info C6:6B:0C@wifi1 connected, signal strength -70
 09-22 12:42:13 wireless,info C6:6B:0C@wifi1 disconnected, SA Query timeout, signal strength -70
 09-22 12:42:20 wireless,info C6:6B:0C@wifi1 connected, signal strength -65
 09-22 12:47:26 wireless,info C6:6B:0C@wifi1 disconnected, connection lost, signal strength -64
 09-22 14:48:23 wireless,info C6:6B:0C@wifi1 connected, signal strength -62
 09-22 14:55:07 wireless,info C6:6B:0C@wifi1 disconnected, connection lost, signal strength -68
 09-22 16:47:44 wireless,info C6:6B:0C@wifi1 connected, signal strength -62
 09-22 16:52:48 wireless,info C6:6B:0C@wifi1 disconnected, connection lost, signal strength -72
 09-22 17:00:05 wireless,info C6:6B:0C@wifi1 connected, signal strength -68
 09-22 17:01:09 wireless,info C6:6B:0C@wifi1 disconnected, SA Query timeout, signal strength -58
 09-22 17:01:10 wireless,info C6:6B:0C@wifi1 connected, signal strength -66
 09-22 17:01:36 wireless,info C6:6B:0C@wifi1 disconnected, SA Query timeout, signal strength -71
 09-22 17:01:37 wireless,info C6:6B:0C@wifi1 connected, signal strength -67
 09-22 17:01:53 wireless,info C6:6B:0C@wifi1 disconnected, SA Query timeout, signal strength -70
 09-22 17:01:59 wireless,info C6:6B:0C@wifi1 connected, signal strength -66
 09-22 17:45:29 wireless,info C6:6B:0C@wifi1 disconnected, SA Query timeout, signal strength -67
 09-22 17:45:29 wireless,info C6:6B:0C@wifi1 connected, signal strength -68
 09-22 17:51:25 wireless,info C6:6B:0C@wifi1 disconnected, connection lost, signal strength -70
 09-22 19:00:20 wireless,info C6:6B:0C@wifi1 connected, signal strength -63
 09-22 19:06:08 wireless,info C6:6B:0C@wifi1 disconnected, connection lost, signal strength -85
 09-22 22:43:48 wireless,info C6:6B:0C@wifi1 connected, signal strength -52
 09-22 22:44:39 wireless,info C6:6B:0C@wifi1 disconnected, SA Query timeout, signal strength -66
 09-22 22:44:40 wireless,info C6:6B:0C@wifi1 connected, signal strength -65
 09-22 22:45:01 wireless,info C6:6B:0C@wifi1 disconnected, SA Query timeout, signal strength -62
 09-22 22:45:01 wireless,info C6:6B:0C@wifi1 connected, signal strength -68
 09-22 22:45:11 wireless,info C6:6B:0C@wifi1 disconnected, SA Query timeout, signal strength -68
 09-22 22:45:12 wireless,info C6:6B:0C@wifi1 connected, signal strength -67
 09-22 22:51:14 wireless,info C6:6B:0C@wifi1 disconnected, connection lost, signal strength -78
 09-23 11:06:06 wireless,info C6:6B:0C@wifi1 connected, signal strength -70
 09-23 11:09:13 wireless,info C6:6B:0C@wifi1 disconnected, SA Query timeout, signal strength -66
 09-23 11:09:14 wireless,info C6:6B:0C@wifi1 connected, signal strength -70
 09-23 11:12:12 wireless,info C6:6B:0C@wifi1 disconnected, group key timeout, signal strength -74
 09-23 11:14:23 wireless,info C6:6B:0C@wifi1 connected, signal strength -73
 09-23 11:21:47 wireless,info C6:6B:0C@wifi1 disconnected, connection lost, signal strength -87
 09-23 11:42:52 wireless,info C6:6B:0C@wifi1 connected, signal strength -59
 09-23 11:48:11 wireless,info C6:6B:0C@wifi1 disconnected, connection lost, signal strength -79
 09-23 15:59:09 wireless,info C6:6B:0C@wifi1 connected, signal strength -66
 09-23 16:08:07 wireless,info C6:6B:0C@wifi1 disconnected, connection lost, signal strength -74
 09-23 19:31:54 wireless,info C6:6B:0C@wifi1 connected, signal strength -60
 09-23 19:37:45 wireless,info C6:6B:0C@wifi1 disconnected, connection lost, signal strength -72
 09-23 23:46:56 wireless,info C6:6B:0C@wifi1 connected, signal strength -68
 09-23 23:51:58 wireless,info C6:6B:0C@wifi1 disconnected, connection lost, signal strength -69
 09-24 10:49:40 wireless,info C6:6B:0C@wifi1 connected, signal strength -67
 09-24 10:55:48 wireless,info C6:6B:0C@wifi1 disconnected, SA Query timeout, signal strength -73
 09-24 10:56:45 wireless,info C6:6B:0C@wifi1 connected, signal strength -68
 09-24 11:07:30 wireless,info C6:6B:0C@wifi1 disconnected, SA Query timeout, signal strength -73
 09-24 11:07:30 wireless,info C6:6B:0C@wifi1 connected, signal strength -74
 09-24 11:12:18 wireless,info C6:6B:0C@wifi1 disconnected, group key timeout, signal strength -72
 09-24 11:49:45 wireless,info C6:6B:0C@wifi1 connected, signal strength -70
 09-24 11:51:22 wireless,info C6:6B:0C@wifi1 disconnected, SA Query timeout, signal strength -72
 09-24 11:51:22 wireless,info C6:6B:0C@wifi1 connected, signal strength -70
 09-24 11:52:27 wireless,info C6:6B:0C@wifi1 disconnected, SA Query timeout, signal strength -65
 09-24 11:52:27 wireless,info C6:6B:0C@wifi1 connected, signal strength -55
 09-24 11:58:33 wireless,info C6:6B:0C@wifi1 disconnected, connection lost, signal strength -86
 09-24 12:23:19 wireless,info C6:6B:0C@wifi1 connected, signal strength -67
 09-24 12:23:54 wireless,info C6:6B:0C@wifi1 disconnected, SA Query timeout, signal strength -69
 09-24 12:23:54 wireless,info C6:6B:0C@wifi1 connected, signal strength -71
 09-24 12:23:58 wireless,info C6:6B:0C@wifi1 disconnected, SA Query timeout, signal strength -71
 09-24 12:23:59 wireless,info C6:6B:0C@wifi1 connected, signal strength -69
 09-24 12:26:16 wireless,info C6:6B:0C@wifi1 disconnected, SA Query timeout, signal strength -69
 09-24 12:26:17 wireless,info C6:6B:0C@wifi1 connected, signal strength -71
 09-24 12:29:21 wireless,info C6:6B:0C@wifi1 disconnected, SA Query timeout, signal strength -71
 09-24 12:29:22 wireless,info C6:6B:0C@wifi1 connected, signal strength -72
 09-24 12:36:25 wireless,info C6:6B:0C@wifi1 disconnected, connection lost, signal strength -70
 09-24 14:46:34 wireless,info C6:6B:0C@wifi1 connected, signal strength -57
 09-24 14:52:05 wireless,info C6:6B:0C@wifi1 disconnected, connection lost, signal strength -71
 09-24 17:37:33 wireless,info C6:6B:0C@wifi1 connected, signal strength -67
 09-24 17:37:37 wireless,info C6:6B:0C@wifi1 disconnected, SA Query timeout, signal strength -70
 09-24 17:37:37 wireless,info C6:6B:0C@wifi1 connected, signal strength -75
 09-24 18:05:15 wireless,info C6:6B:0C@wifi1 disconnected, connection lost, signal strength -82
 09-24 18:28:54 wireless,info C6:6B:0C@wifi1 connected, signal strength -56
 09-24 18:34:35 wireless,info C6:6B:0C@wifi1 disconnected, SA Query timeout, signal strength -72
 09-24 18:34:35 wireless,info C6:6B:0C@wifi1 connected, signal strength -74
 09-24 18:36:03 wireless,info C6:6B:0C@wifi1 disconnected, SA Query timeout, signal strength -74
 09-24 18:36:03 wireless,info C6:6B:0C@wifi1 connected, signal strength -71
 09-24 18:40:44 wireless,info C6:6B:0C@wifi1 disconnected, SA Query timeout, signal strength -68
 09-24 18:40:44 wireless,info C6:6B:0C@wifi1 connected, signal strength -69
 09-24 18:41:10 wireless,info C6:6B:0C@wifi1 disconnected, SA Query timeout, signal strength -73
 09-24 18:41:10 wireless,info C6:6B:0C@wifi1 connected, signal strength -70
 09-24 18:41:13 wireless,info C6:6B:0C@wifi1 disconnected, SA Query timeout, signal strength -69
 09-24 18:41:14 wireless,info C6:6B:0C@wifi1 connected, signal strength -71
 09-24 18:42:59 wireless,info C6:6B:0C@wifi1 disconnected, SA Query timeout, signal strength -69
 09-24 18:42:59 wireless,info C6:6B:0C@wifi1 connected, signal strength -69
 09-24 18:45:31 wireless,info C6:6B:0C@wifi1 disconnected, SA Query timeout, signal strength -68
 09-24 18:45:32 wireless,info C6:6B:0C@wifi1 connected, signal strength -71
 09-24 18:47:16 wireless,info C6:6B:0C@wifi1 disconnected, SA Query timeout, signal strength -74
 09-24 18:47:17 wireless,info C6:6B:0C@wifi1 connected, signal strength -68
 09-24 18:48:03 wireless,info C6:6B:0C@wifi1 disconnected, SA Query timeout, signal strength -76
 09-24 18:48:03 wireless,info C6:6B:0C@wifi1 connected, signal strength -72
 09-24 18:50:56 wireless,info C6:6B:0C@wifi1 disconnected, SA Query timeout, signal strength -69
 09-24 18:50:56 wireless,info C6:6B:0C@wifi1 connected, signal strength -68
 09-24 18:57:22 wireless,info C6:6B:0C@wifi1 disconnected, SA Query timeout, signal strength -67
 09-24 18:57:23 wireless,info C6:6B:0C@wifi1 connected, signal strength -68
 09-24 18:58:50 wireless,info C6:6B:0Cwifi1 disconnected, SA Query timeout, signal strength -69
 09-24 18:58:51 wireless,info C6:6B:0C@wifi1 connected, signal strength -69
 09-24 19:04:56 wireless,info C6:6B:0C@wifi1 disconnected, connection lost, signal strength -70
 09:20:40 wireless,info C6:6B:0C@wifi1 connected, signal strength -66
 09:23:00 wireless,info C6:6B:0C@wifi1 disconnected, SA Query timeout, signal strength -71
 09:23:00 wireless,info C6:6B:0C@wifi1 connected, signal strength -69
 09:25:21 wireless,info C6:6B:0C@wifi1 disconnected, SA Query timeout, signal strength -72
 09:25:21 wireless,info C6:6B:0C@wifi1 connected, signal strength -72
brg3466
Thu Sep 28, 2023 5:17 am
anyone has solution ?
It is weird that in our house, only iPhone14 pro has this "SA query timeout" issue. All other apple devices ( macbook, macbook air, ipad or iphone 12) don't behave like this.
martinii
Mon Oct 02, 2023 4:38 pm
In my case it still doesn't work... The only solution I can see is to give my Dad a new phone.
Santi70
Fri Nov 17, 2023 2:10 pm
I also have that problem, but only with an iPhone 13, all other devices work fine
jugernautas
Thu Dec 07, 2023 4:18 pm
First time here. I have upgraded my cAP ax device from v7.8 to v7.12 and one "Lenovo" laptop started disconnecting often.
Looking at the log I have determined that the problem could be that laptop changes wifi frequencies from 5Ghz to 2Ghz and therefore cAP device waits until it can no longer determine that laptop is connected. After then it lets connect to AP. The duration time offline was about 1 minute.
I could not find any sophisticated information, so I tried changing these 2 values on each frequency radio interface:
connect-group ( string )
APs within the same connect group do not allow more than 1 client device with the same MAC address. This is to prevent malicious authorized users from intercepting traffic intended to other users ('MacStealer' attack) or performing a denial of service attack by spoofing the MAC address of a victim.
Handling of new connections with duplicate MAC addresses depends on the connect-priority of AP interfaces involved.
By default, all APs are assigned the same connect-group.
connect-priority (accept-priority/hold-priority (integers))
Theese parameters determine, how a connection is handled if the MAC address of the client device is the same as that of another active connection to another AP.
If (accept-priority of AP2) < (hold-priority of AP1), a connection to AP2 wil cause the client to be dropped from AP1.
If (accept-priority of AP2) = (hold-priority of AP1), a connection to AP2 will be allowed only if the MAC address can no longer be reached via AP1.
If (accept-priority of AP2) > (hold-priority of AP1), a connection to AP2 will not be accepted.
If omitted, hold-priority is the same as accept-priority.
By default, APs, which perform user authentication, have higher priority (lower integer value), than open APs.
On 2Ghz - Security - Connect Group ("Grupe2") and Connect Priority (0/1)
On 5Ghz - Security - Connect Group ("Grupe5") and Connect Priority (0/1)
For now the laptop works ok, no long disconnections from Wifi. It would be great if someone can explain if this is right way to configure it.
tinodj
Tue Jan 16, 2024 9:28 am
Hit this problem after upgrading from 6 to 7. Was very stable with 6, now on ROS7 is frustrating with this. Happens on iPhone and Mac. Happens on cAP ax and Audience. Solutions here didn’t help :( Have anyone found something else?
kurio
Fri Jan 19, 2024 11:05 am
Started having this problem with i don't know which version of ROS 7.xx, now running the latest 7.13.2.
Impossible to roam from independent AX2 to AX3: simple connects/disconnects, SA timeouts, no IPv4 DHCP replies, all kinds of crap.
I have tried all the suggestions here and there, but they do not work. All smartphones are android, most of them have issues staying connected when moving from floor to floor (from one hap ax to another).
However, i have noticed a workaround which works on some phones: instead of static phone MAC address switch to randomized MAS addresses.
Is this whole issue is related to the client MAC addresses?
Do i need to configure and run capsman to overcome this critical connectivity problem?
ToTheFull
Fri Jan 19, 2024 12:31 pm
CAPsMAN wont help, also the same on 7.14Beta7 maybe slightly worse than 7.14Beta6.
Anyway, I'm sure someone will be along soon to say it's your config etc...........
erlinden
Fri Jan 19, 2024 2:52 pm
How do you know his config is correct. There are not a lot of topics where, after sharing the config, there are no improvements to make on the config.
@kurio: As far as I know the client will always use the same MAC address (per SSID), even if it is randomized. No clue why you think it is helping...
In regards to the SA Query timeout problem, it has been solved for me (using CAPsMAN) by setting the connect-priority.
masseselsev
Fri Jan 19, 2024 2:54 pm
Same here on Chateau 18 (7.13.2) with all my AX diveces that are trying to connect to 2Ghz, 5Ghz connections are fine though.
No CAPsMAN, just a single(dual actually) raido.
The devices namely are a couple of Google pixel (6&7) phones, and a pair of laptops with AX211 wifis'.
Also, the devices that are not capable of AX seem to de working just fine,
And it happens randomly -- not all the devices at once.
Maybe the matter does deserve some comment from the staff?
edit. persuaded a part of the devices to connect to 5g only, now this happens both with 2 and 5 ghz (((
holvoetn
Fri Jan 19, 2024 2:57 pm
Then it might be better to create a ticket with supout right after you see it happening.
Because staff does not frequent these forums that often (they sometimes do).
ToTheFull
Fri Jan 19, 2024 3:56 pm
Deployed... i'll let YOU Know!
2 name="wifi1" l2mtu=1560 mac-address=18:FD arp-timeout=auto radio-mac=18:FD
   configuration.mode=ap .ssid="002" .country=United Kingdom
   security.authentication-types=wpa2-psk .encryption=ccmp .passphrase=""
   .management-protection=allowed .wps=disable .connect-priority=0/1
   channel.frequency=5180 .band=5ghz-ax .width=20/40/80mhz .skip-dfs-channels=10min-cac
If that isn't correct please do share what needs to be done.
fronik
Thu Feb 29, 2024 7:27 pm
Faced the same problem
On 5Ghz - Security - Connect Priority (0/1) It worked until firmware 7.14, but on 7.14 the network on the laptop began to fall off constantly. Connected \ Disconnected...
back to 7.13.4 (and definitely System\RouterBOARD\Upgrade firmware to 7.13.4) - good work for me
Neolo
Sat Mar 02, 2024 2:18 am
Priority does not do anything, 7.14. Log is flooded with SA Query timeouts. Clients have terrible experience using wifi. What is going on??
Kanzler
Sat Mar 02, 2024 7:56 am
@Neolo,
Could you please show your configuration?
fronik
Sat Mar 02, 2024 4:54 pm
RouterOS and firmware ver <= 7.13.4 - normal work
RouterOS and firmware ver = 7.14 - clients disconnected and logs: "... disconnected, SA Query timeout ..."
My config:
/interface wifi configuration
add channel.band=2ghz-ax .frequency=2412 .skip-dfs-channels=10min-cac .width=20mhz country=Russia datapath.bridge=bridge disabled=no mode=ap name=2Ghz security.authentication-types=wpa2-psk,wpa3-psk .connect-priority=0/1 .passphrase=WiFiPass124 .wps=disable ssid=WiFiName123
add channel.band=5ghz-ax .frequency=5640-5725 .skip-dfs-channels=10min-cac .width=20/40/80mhz country=Russia datapath.bridge=bridge disabled=no mode=ap name=5Ghz security.authentication-types=wpa2-psk,wpa3-psk .connect-priority=0/1 .passphrase=WiFiPass124 .wps=disable ssid=WiFiName123-5GHz
/interface wifi cap
set caps-man-addresses=127.0.0.1 enabled=yes
/interface wifi capsman
set enabled=yes package-path="" require-peer-certificate=no upgrade-policy=none
/interface wifi provisioning
add action=create-dynamic-enabled disabled=no master-configuration=2Ghz supported-bands=2ghz-ax
add action=create-dynamic-enabled disabled=no master-configuration=5Ghz supported-bands=5ghz-ax
My clients: phones, tv, ps5, smarthome devices notebooks
MaxwellsEq
Sun Mar 03, 2024 1:02 am
I didn't see any mention of disabling Frame Protection. Did this not have any effect?
Neolo
Sun Mar 03, 2024 4:37 am
@Neolo,
Which configuration are you asking about?
Everything is default except for it's an open network with OWE enabled.
Neolo
Sun Mar 03, 2024 4:38 am
The only effect it makes is rendering WPA3 and OWE inoperable. And I don't want that.
Neolo
Sun Mar 03, 2024 4:42 am
No it wasn't. I just upgraded from 7.13.4 to 7.14, both have the same problem. Trust me, I have a public place to test with 200 people connecting, not just own laptop and a phone.
Kanzler
Sun Mar 03, 2024 7:51 am
@Neolo
Very strange, I don't experience such an issue myself. Have you tried enabling FT? Maybe that will help?
MaxwellsEq
Sun Mar 03, 2024 9:53 am
Lots of non-compute devices (TVs, cameras, doorbells etc.) which don't support Frame Protection also don't seem to properly ignore its presence. If you Google SA Query Timeout, you will find this also an issue with non-Mikrotik Wireless setups. We seem to have two choices, only have very modern non-compute devices (fully WPA3 compliant) or run a Wireless radio setup which has no WPA3 elements including Frame Protection (with the small security risk this implies).
ToTheFull
Sun Mar 03, 2024 10:59 am
SNIP: Trust me, I have a public place to test with 200 people connecting, not just own laptop and a phone.
From my point of view that would look painfull on the eyes.
I have tried the "Connect Priority 0/1" trick and although it seems to help (not cure) it causes unexplained speed drops on both my AX devices.
Neolo
Sun Mar 03, 2024 10:34 pm
I have that priority in place, it makes zero effect, timeouts still written in log.
Neolo
Sun Mar 03, 2024 10:35 pm
@Neolo
What's FT?
Neolo
Sun Mar 03, 2024 10:38 pm
Nope, in the environment I have there is no TVs or doorbells, but phones and tablets.
Mikrotik should fix the firmware to accommodate all models properly, it's all it is.
Kanzler
Sun Mar 03, 2024 10:44 pm
set ft=yes and ft-over-ds=yes in security profile to enable 802.11r fast BSS transitions (roaming)
tangent
Mon Mar 04, 2024 12:33 am
What's FT?
Fast Transitions, a recently added feature. Disabled by default. “FT” is the tab name in WinBox.
Neolo
Tue Mar 05, 2024 9:15 pm
What's FT?
I have enabled it in my security template, but it doesn't do anything about SA Query timeouts alone.
However, when I have connected all APs via Capsman and enabled FT and FT over DS, that seems stopped SA Query Timeout errors.
robmaltsystems
Forum Veteran
Forum Veteran
Sun Apr 07, 2024 11:32 pm
solution for me:
How do you query this setting? /interface/wifi/configuration/print doesn't show anything. It doesn't appear in /export either.
ToTheFull
Sun Apr 07, 2024 11:35 pm
I think they added it to this, if thats what you mean?
interface/wifi/monitor 0,1,2,3
                 state: running        running   running        running
               channel: 5500/ax/Ceee   2412/ax   5180/ax/Ceee   2462/ax
      registered-peers: 3              0         1              2
      authorized-peers: 3              0         1              2
              tx-power: 22             14        18             15
    channel-priorities: 0:5500/ax/Ceee 0:2412/ax 0:5180/ax/Ceee 0:2462/ax
chechito
Sun Apr 07, 2024 11:46 pm
try this security settings for compatibility
security.authentication-types=wpa2-psk .disable-pmkid=yes .encryption=ccmp .group-encryption=ccmp .group-key-update=1d .passphrase=xxxxxxxxxxxx .wps=disable
PD: i dont have any ax device for testing, this config i use it on hap-ac2 and audience, with routeros 7.13.5 and 7.14.2 working ok
robmaltsystems
Forum Veteran
Forum Veteran
Mon Apr 08, 2024 12:07 am
Thanks, will do but another time - it's late in UK and I've spent more hours than I really wanted to on this.
infabo
Mon Apr 08, 2024 12:22 am
I'll go through docs:
That's already the defaults.
disable-pmkid=yes
If unsure this rather lowers compatibility.
wps=disable
Sure, good idea. But I think this not increase/decrease compatibility.
robmaltsystems
Forum Veteran
Forum Veteran
Mon Apr 08, 2024 3:45 pm
I'm going to do some more reading up on this before I start making any changes.
For the record, the device I'm having trouble with is an Lenovo V15 G2-ALC laptop, Windows 10, Realtek 882CE 802.11ac wireless chip. Using WPA2/3 authentication with defaults for everything else. Not tried the FT switches yet or any other tweaks.
Connects fine with no SA Query timeout errors in the log when sat on the coffee table about 1.5m away. Move it onto the bench about 3m away and unable to connect to 5GHz with SA Query Timeout in log. There is a partial 20m stone wall in the way and often me :-)
When 1.5m from the hAP ax2, the router reports signal strength -54. The laptop reports a signal strength of -37. That -54 is "interesting", i.e. it being so low - suggests poor signal from the laptop? Connected to timeout errors? Never had any problem with old Virgin Media router.
I bought a cheap Wi-Fi 6 USB adapter for testing purposes. Signal strengths are -44 at router and -47 on laptop. When using this, it also works fine on the bench.
The SA query time errors occur both with WPA2 and WPA3. I thought it was a WPA3 "thing" but clearly not hence the reason for wanting to read up more.
robmaltsystems
Forum Veteran
Forum Veteran
Mon Apr 08, 2024 4:39 pm
I left the laptop on the coffee table, connected to 5GHz using the Wi-Fi 6 USB network adapter and came back about an hour later and it too had got SA Query timeout errors and had fallen back to 2.4GHz:
Something isn't right here. This is sat 1.5m from the router with very little else going on. I've restarted the adapter and it's reconnected at 5GHz...
MikrotikUser100
SA query timeout
Tue Apr 30, 2024 3:09 pm
We are having hard times "enjoying" our mikrotik hardware.
Despite numerous software upgrades, we are still experiencing "SA Query Timeout" on several devices in our network.
I really don't understand, this problem has been reported like a year ago, and still Mikrotik did NOTHING to help their customers. Don't you think it's kinda wrong?
We spent 500 EUR in hardware. Obviously it's my last mikrotik, but since I cannot return it anymore, I need to fix the problem.
The same client works perfectly on another wifi from another vendor. So the problem is purely in mikrotik and their software/hardware (and mine is hAP ax^3 - which is pretty expensive and at least SOHO level, not a cheap home device)
Please PROVIDE SOLUTION ASAP. I don't understand what did I pay for.
akakua
Tue Apr 30, 2024 6:37 pm
has anyone tried to set "disabled" for management protection?
robmaltsystems
Forum Veteran
Forum Veteran
Re: SA query timeout
Tue Apr 30, 2024 6:43 pm
I tend to agree. The Lenovo laptop I mentioned above really struggles to maintain a 5G connection and it's in the same room. I'm keeping totally away from AX range in the commercial space. This is just my home/office setup.
I wonder if Mikrotik is spread too thin on the development team? I must admit the range of devices available does seem a lot. I wonder if the development team keep going to the hardware guys "STOP!!! We need to get the existing kit working first" ;-)
robmaltsystems
Forum Veteran
Forum Veteran
Tue Apr 30, 2024 6:44 pm
No but I will have a go. Doesn't that reduce security?
infabo
Tue Apr 30, 2024 6:51 pm
@MikrotikUser100
Besides the log message on your mikrotik device (SAQuery timeout...): how do you experience the problem on your client device?
MikrotikUser100
Wed May 01, 2024 2:00 pm
@MikrotikUser100
It's unusable, as we use it remotly.
It's not just a log message, it's a total disconnection from the network and hence complete instability and inability to use the device.
I have tried to disable WPA3 leaving only WPA2 on my wifi interfaces with no luck, didn't help at all. And what makes it worse, is when the laptop is close to the mikrotik (like 1-2 meters) it works.
ivicask
Wed May 01, 2024 2:31 pm
@MikrotikUser100
This fixed my query errors, try set it exactly like this.
akakua
Wed May 01, 2024 2:41 pm
sa query is part of protected management frames (802.11w), so you won't get any timeouts, if it disabled:)
robmaltsystems
Forum Veteran
Forum Veteran
Thu May 02, 2024 5:06 pm
Okay, got a few minutes spare to have a look at this. Laptop is back in the location where it gets SQ query timeouts. About to disable management protection.
Got a warning but assume that's okay. Have disabled WPS as well but assume that's unconnected.
Later... hmm maybe I'll turn off WPA3 as well as I don't seem to be able to connect at 5GHz. Keeps falling back to 2.4GHz. Maybe that warning means that 5Ghz won't work?
infabo
Thu May 02, 2024 5:33 pm
Management protection is required for WPA3. So according to the red message I assume you have configured wpa2-psk/wpa3-psk mode (or even "better": wpa3-psk alone). In a "mixed" mode you need to at least set management protection to "allowed". As WPA3 requires it. And your laptop now maybe wants to connect using WPA3 and fails terribly.
robmaltsystems
Forum Veteran
Forum Veteran
Thu May 02, 2024 6:52 pm
Okay, have turned WPA3 off and switched back to just WPA2. Devices now connected at 5G except the laptop is still preferring to fall back to 2.4GHz. I suspect we may be barking up the wrong tree here and the problem with this specific Lenovo laptop is it's transmit power. This is what the laptop reports from inSSIDer:
However, this is a log entry from the hAP ax2:
00:45:E2:81:E4:61@private-5g connected, signal strength -67
So the hAP ax2 is reporting a signal from the laptop of -67 which is borderline poor.
So maybe the SA Query Timeout log entries are because the transmit power is relatively poor. I'll split the SSID into 2 and 5GHz so I can force it to try and connect to 5GHz.
Later... when SSID is different between 2.4GHz and 5GHz, laptop will connect to 5GHz quite happily and reports connection speed of 390Mbps both directions. hAP ax2 reports a signal of -65. I'll turn WPA3 back on and reset management protection.
Last edited by robmaltsystems on Thu May 02, 2024 7:15 pm, edited 1 time in total.
robmaltsystems
Forum Veteran
Forum Veteran
Thu May 02, 2024 7:07 pm
A question - in terms of deciding whether to connect at 2.4GHz or 5GHz, is it the client (Windows/laptop) that decides? Or does the access point get involved?
erlinden
Fri May 03, 2024 12:08 am
It is up to the client. I tend to lower Tx Power of the 2.4GHz radio to have clients prefer 5GHz over 2.4GHz.
Turn on wireless debug logging to get more insights of the cause.
ulysses
Wed May 15, 2024 11:07 pm
I also have this issue, also with a Lenovo laptop. Other devices, including Apple and Android phones, and a MacBook, work well.
I have twp capsman managed Cap AX with WPA2+3 and FT enabled
infabo
Thu May 16, 2024 2:18 am
You can deactivate FT. It's also not activated by default. Other manufacturers prioritize maximum compatibility, so most features that could cause issues with clients are inactive. You can only activate features like FT after clicking "yes, please, advanced settings, no auto mode, and yes, I understand it can cause problems, thanks for the heads up" five times. With Unifi, you only get WPA2 and maybe 802.11v (if at all) in "Auto" mode. Just because ROS doesn't bombard you with warnings about potential problems with WPA3 or FT doesn't mean ROS is Satan incarnate for not informing you about the consequences. And if a red warning does pop up, people freak out, open forum topics, and want to know how to get rid of those ugly red messages. They're not interested in solving the problem; they just want to hide the message because it's ugly.
robmaltsystems
Forum Veteran
Forum Veteran
Mon Aug 26, 2024 6:35 pm
Resurrecting this post so not the hijack the other post. I've just done some very unscientific testing (but arguably valid) of a hAP ac lite and my new hAP ax2. Top line - the hAP ax2 receives a signal that's 10dB worse than the hAP ac lite. During the test, only one device's Wi-Fi was enabled at once.
For the hAP ax2, it's receiving a signal strength of -70dB from the laptop - this is borderline and most likely results in the SA Query timeout situation. The hAP ac lite receives a signal of ~60dB. The laptop receives a signal of -50dB for both devices.
-10dB difference is IMO a big enough difference to raise eyebrows. The hAP ax2 is Wi-Fi 6 enabled with WPA2/WPA3 PSK encryption whereas the hAP ac lite is Wi-Fi 5 enabled with WPA/WPA2 PSK. I'll do some mores tests by changing the hAP ax2 to Wi-Fi 5 and same WPA.
jaclaz
Mon Aug 26, 2024 6:52 pm
I wonder why the Ax2 is always represented as standing ... :?
AFAIK it needs to be standing because of better heat dissipation, but it is possible that the internal antennas are designed to work with the device standing and having it flat on the table reduces their efficiency (or you have a lot of signal at an upper floor and in the basement :wink: ) .
You should try with the Ax2 in the recommended orientation, it may make a difference (or maybe not?).
In theory the ac lite has lower gain antennas (1.5/2 db) whilst the Ax2 has higher gain antennas (4/4.5 db) so reception should be better on the Ax2, the opposite of what you measured.
infabo
Mon Aug 26, 2024 7:07 pm
Legacy wireless driver does not support 802.11w. So you won't spot a SA query timeout in HAP AC lite logs.
robmaltsystems
Forum Veteran
Forum Veteran
Mon Aug 26, 2024 7:12 pm
Same thought crossed my mind. I put it horizontal because that's the natural orientation of the hAP ac lite. But I've also just tried vertical - no difference. Whilst vertical, tried rotating 90 degrees. No difference. Flat on it's back. No difference. Switch to AC with WPA/WPA2. No difference. Signal strength stubbornly sticks around -70dB whereas the hAP ac lite is around -60dB. The only way to get 5GHz to work is to be sat in clear sight about 2m away from the hAP ax2.
If it looks like a duck, swims like a duck, and quacks like a duck, then it probably is a duck. Having spent hours fiddling with this, my gut instinct is that the RX antenna/signal in the hAP ax2 is weaker than the previous hAP ac range and therefore this leads SA Query timeouts and fall-back to 2.4GHz band.
PS. Before I tried the tests today, it's been vertical since I installed it.
Last edited by robmaltsystems on Mon Aug 26, 2024 7:16 pm, edited 2 times in total.
robmaltsystems
Forum Veteran
Forum Veteran
Quite... that are many, many posts around AX signal strength on here that the gun isn't just smoking, it's firing.
robmaltsystems
Forum Veteran
Forum Veteran
Mon Aug 26, 2024 7:15 pm
Understood but I was mainly looking the receive signal strength of the hAP devices for comparison.
robmaltsystems
Forum Veteran
Forum Veteran
Mon Aug 26, 2024 7:22 pm
Another observation. Normally, the SSID for 2.4GHz and 5GHz are identical. However, for this test, I added "5G" on the end of the SSID so I could force it onto one band or another. When the SSIDs are different, the SA Query timeout errors never occur. Even though the RX signal is poor, it's still managing pretty decent speeds:
I'm going to bet that when I remove the "5G" tag, I'll start getting the timeouts and it'll fall back to 2.4GHz. IMO a Tx Rate of ~800Mbps and Rx rate of ~500Mbps doesn't merit a fall back to 2.4GHz. I asked above whether the decision to fall back is triggered by the router, the client or both.
infabo
Mon Aug 26, 2024 7:25 pm
Easy bet. It is already known this is the root of the issue. That's why people commonly tinker around with connect-priority.
jaclaz
Mon Aug 26, 2024 7:32 pm
This is very interesting :) , it may connect this SA Query Timeout to a "decision" to be made either on the Mikrotik or on the client about which frequency to use within a same SSID.
Obviously if the SSID's are different such a decision needs not to be taken, i.e.it is taken manually before when choosing one of the two SSID's.
robmaltsystems
Forum Veteran
Forum Veteran
Mon Aug 26, 2024 7:38 pm
Giving this a go! Disabled it on 5Ghz interface and switched back from WPA2/3 to WPA/WPA2.
erlinden
Mon Aug 26, 2024 7:43 pm
Why use WPA (when you can use open)?
8)
jaclaz
Mon Aug 26, 2024 7:52 pm
I thought that was related to issues when roaming with two or more different AP's?
viewtopic.php?p=1093107#p1093107
infabo
Mon Aug 26, 2024 8:59 pm
Switching between bands on same AP is also called roaming AFAIK.
jaclaz
Mon Aug 26, 2024 11:34 pm
I see now, so in the referenced post the new and old AP are to be intended as same AP but new and old bands.
litvcom
Fri Aug 30, 2024 1:16 am
Similar behavior on my AX3, hopefully in RouterOS 7.16.x they will bring the work to the desired level.
Parking4754
Thu Sep 05, 2024 11:45 am
Same problem here, setup as follows:
- 4009 as CAPsMAN
- CAP XL, ax2 and ax3 as AP’s
- Running 7.15.3
FT roaming works but clients regularly lose their connection to an AP and reconnect seconds later. Logs mention SA Query timeout. Only WPA2 and CCMP configured.
gigabyte091
Thu Sep 05, 2024 2:43 pm
After disabling WPA3 I don't have wifi issues anymore, timeouts happens only when signal is weak.
robmaltsystems
Forum Veteran
Forum Veteran
Wed Sep 18, 2024 11:48 pm
I concur with the weak signal observation. Problem is that one doesn't feel the signal is weak when the SA Query timeout occurs.
ToTheFull
Thu Sep 19, 2024 12:26 am
Depends what you define as weak, the following cuulmination of events goes from conncted to my cAP ax upstairs roaming to my hAP ax2 Downstairs then going outside my house to another building with double layer brick walls which disconnects after a period and then re-joins. That would be a mobile phone in a pocket. if you call that not great I just can't agree. that would mean I just need an external AP?
19:36:46 wireless,info 9E:@cap-wifi1 roamed to 9E::DB@wifi2, signal strength -48
19:49:52 wireless,info 9E:@wifi2 disconnected, SA Query timeout, signal strength -71
19:49:57 wireless,info 9E:@wifi2 connected, signal strength -71
litvcom
Tue Sep 24, 2024 10:53 pm
This happens even a few meters away from the router, so it's definitely not due to a weak signal. I just upgraded to 7.16, but I don't see any fixes in the changelog, so I don't think anything has changed.
Coughy
Wed Sep 25, 2024 8:38 am
i have roaming working and no sa timeouts
and very little disconects
i have been playing with the config for minths now and i think i have it working pretty good
this is the best i can get it
Serge
Wed Sep 25, 2024 11:55 am
cAP ax
7.14.3 - free from this bug
7.15.x - BUG present
Whats about 7.16?
Sirafim
Thu Sep 26, 2024 12:15 pm
cAP ax
Whats about 7.16?
Nothing.
Until yesterday I had firmware 7.14.3 installed on AX3 - everything worked without a single problem.
Yesterday I installed 7.16 - again there were constant disconnections, SA and a new problem: AX3 unavailability for connection after disconnection.
AX3 is paired with hAP AX Lite. hAP AX Lite - no problems after upgrading to 7.16.
As a result: I returned firmware 7.14.3 on AX3
infabo
Thu Sep 26, 2024 1:38 pm
It is probably all because of this innocent changelog line in ROS 7.15 changelog:
*) wifi-qcom - updated driver;
Jeez, why Mikrotik not reverting this change and re-introduce updated drivers once they got the issues fixed? Instead they take into account people having issues by running latest version of ROS.
Coughy
Thu Sep 26, 2024 2:06 pm
running 7.16.rc4 , runing 7.16.rc4 firmware
no sa querys, time outs or really any of the sort like it used to yes i do get a couple disconects but noithing like what it use to be like
no real issues at moment , i did have the authentisicate loop bug but i have got that to dissapear
hapax3 , hapax2, capax x 3 all running 7.16.rc4 firmware
all roaming and working yes i do get a couple of disconects and stuff high signals but it is getting better
i have tweaked the config file a bit but seems to be working for me
i have started a complete new config as i found that a restored config made issues and bugs
so i update and make a completely new config for that base ros and i dont really have issues anymore learnt this over the last few months of fault finding and testing settings.
im happy to share my config and for some to try and see if it helps out as i have been useing bits and pieces from here to try and test out as well
cAP ax
Whats about 7.16?
Nothing.
neki
Thu Sep 26, 2024 3:20 pm
cAP ax
Whats about 7.16?
Nothing.
Can you share your config please? Same applies to you @infabo
Sirafim
Thu Sep 26, 2024 4:51 pm
Nothing.
No problem.
This is one variant that works fine on 7.14.3, but doesn't work on 7.15+
/interface wifi channel
add band=5ghz-ax disabled=no frequency=5220,5240 name=channel.ax width=20/40/80mhz
add band=5ghz-ac disabled=no frequency=5220,5240 name=channel.ac width=20/40/80mhz
/interface wifi security
add authentication-types=wpa2-psk connect-priority=0/1 disable-pmkid=yes disabled=no ft=no ft-over-ds=no group-encryption=ccmp \
    group-key-update=12h management-protection=disabled name=security.b1 wps=disable
/interface wifi
set [ find default-name=wifi1 ] channel.frequency=5220 comment="WIFI AX" configuration=cfg.ax configuration.mode=ap disabled=no
add channel.frequency=5220 comment="WIFI AC" configuration=cfg.ac configuration.mode=ap disabled=no mac-address=XX:XX \
    master-interface=wifi1 name=wifi3 security=security.b1
add channel=channel.ax country=Ukraine datapath=datapath.b1 disabled=no mode=ap multicast-enhance=enabled name=cfg.ax security=\
    security.b1 ssid=AX
add channel=channel.ac country=Ukraine datapath=datapath.b1 disabled=no mode=ap multicast-enhance=enabled name=cfg.ac security=\
    security.b1 ssid=AC
/interface wifi datapath
add bridge=bridge.b1 disabled=no name=datapath.b1
neki
Thu Sep 26, 2024 9:15 pm
This is weird, as it was already mentioned here, SA Query is part of 802.11w (protected management frames), so this shouldn't be even possible with management-protection=disabled.
I also had this issue, but it was caused by misconfiguration on my side. Anyway, I also encountered another bug when my security settings weren't properly applied. Counldn't this be the issue?
ToTheFull
Thu Sep 26, 2024 9:19 pm
Flapping problem has returned with 7.16
Sirafim
Sat Sep 28, 2024 1:09 pm
Mediabox TOX1 on RoS 7.15+ firmware was losing connection with AX3 on 5GHz every 2-5 minutes. After returning to firmware 7.14.3, everything started working stably again.
At the same time connection to hAP AX lite on 2GHz via N protocol works stably on TOX1 media box.
About TOX1 media box https://techxreviews.com/tox1-tv-box-review/
POCO F4 smartphone refused to connect to the AP after losing connection with AX3 on RoS 7.15+ firmware. No problem occurred on firmware 7.14.3 with the same configuration.
The same happens on ASUS laptop on AX, on HP laptop on AC.
Also checked on TP-Link DWA-185 (Linux,Windows) same problems on firmware 7.15+.
zubrev
Sat Sep 28, 2024 2:04 pm
Use only wpa2!
management protection - disable!
the problem seems to have disappeared (No SA query timeout messages in log, roaming messages between AP appeared)!
neki
Sat Sep 28, 2024 11:30 pm
7.17beta2
*) wifi - re-word the "SA Query timeout" log message to "not responding";
flynno
Sat Sep 28, 2024 11:51 pm
7.17beta2
Fixing typo's
MrRobotdev
Sun Sep 29, 2024 8:35 am
I had the same problem with hap ax2 only with my win10 laptops. No problem with mobiles.
I was using WPA2 and WPA3.
When i select only WPA3, problem disappeared.
Probable works with only WPA2.
Not an expert to know the details why this is happening but right now i have zero problems.
Sirafim
Sun Sep 29, 2024 11:11 am
7.17beta2
Fixing typo's
The problem will remain, but it will be called something else?
infabo
Sun Sep 29, 2024 12:03 pm
According to Mikrotik it is not a problem. It is just a notice. "wireless,info" gives the severity already
flynno
Sun Sep 29, 2024 1:48 pm
This has been going on since installed, capsmanv2 with 2x cAPGi-5HaxD2HaxD and 1x C52iG-5HaxD2HaxD
All running 7.15.3
10 wireless devices have no issue and do not disconnect and about 4-5 devices keep disconnecting and reconnecting,
Basic settings applied below
add band=2ghz-ax comment="1, 6, 11 = 2.4G" disabled=no frequency=2412 name=\
channel1_2,4G skip-dfs-channels=all width=20/40mhz-Ce
add band=2ghz-ax disabled=no frequency=2437 name=channel6_2.4G \
skip-dfs-channels=all width=20/40mhz-eC
add band=2ghz-ax disabled=no frequency=2462 name=channel11_2.4G \
add band=5ghz-ax comment="indoor channels 36, 40, 44, 48 = 5G" disabled=no \
frequency=5180 name=channel36_5G skip-dfs-channels=all width=20/40/80mhz
add band=5ghz-ax disabled=no frequency=5200 name=channel40_5G \
add band=5ghz-ax disabled=no frequency=5220 name=channel44_5G \
add band=5ghz-ax disabled=no frequency=5240 name=channel48_5G \
add authentication-types=wpa2-psk disabled=no ft=yes ft-over-ds=yes \
group-encryption=ccmp group-key-update=40m name=local_sec
group-encryption=ccmp group-key-update=40m name=mgmt_sec
group-encryption=ccmp group-key-update=40m name=secondary_sec
pdrsks
Tue Oct 01, 2024 5:44 pm
Hi guys, I had this problem with a cap ax on 7.16 and an intel ax200 wifi card, with Windows 10 (not 11) on the last wifi drivers. After trying different things, including using only WPA2, disabling fast roaming, downgrading to 7.14.3 (this one worked), the solution was to modify an advanced parameter on the driver settings.
In device manager, go to network adapters, properties, advanced properties and in MIMO power save mode select No SMPS. With this, all my disconnections dissapeared, I hope this also works for someone else.
MrRobotdev
Wed Oct 02, 2024 6:50 am
Unfortunately the problem reappeared after 2 days on WPA3 only. So i really dont know what the solution would be...
Thats why nobody recommends Mikrotik for WiFi - AP... this is a major problem, not be able to connect steady one laptop
macgaiver
Wed Oct 02, 2024 8:53 am
I have 10 AP roaming setup here, all devices but one are working just fine, the only one with issue is with intel ax200/201 wifi card and windows 11, it randomly decides to disconnect form the closest/best AP (signal level -50) and roam to worst possible AP (signal level -86/-90) for absolutely no reason, while stacionary on the table....
all indications are that it is client decision to disconnect and move.
I have tried latest driver, changed few settings (fast roaming, wpa3 disabled etc). Internet shows that there are lots of similar problems with that intel card on different vendors also...
infabo
Wed Oct 02, 2024 9:17 am
Interesting.
"Some legacy APs may have compatibility issue with supporting the SMPS mode and may cause various link quality problems such as low throughput. Change this setting to No SMPS may help to work around the issue"
https://www.intel.com/content/www/us/en ... he%20issue
And already one report on the forum on this: viewtopic.php?t=207037
woland
Wed Oct 02, 2024 10:44 am
Nice input, thanks I´ll try disabling SMPS.
The link Infabo provided clearly shows , that this should only happen on "legacy APs" .
I only have trouble with this on my CAPax, which I did not consider legacy up until now. It only happens with one laptop I use. I never have any problems on other APs with this device.
I think MT Wifi will be considered legacy for me as well soon, but I stil wish MT wakes up and puts more efforts to resolve this issue!
infabo
Wed Oct 02, 2024 11:12 am
Indeed. MIMO SMPS is as old as 802.11n. See https://dot11ap.wordpress.com/spatial-m ... save-smps/
But maybe some kind of bug in either Intel drivers or on Mikrotik AP side. Given that disconnecting clients issue is really related to Intel SMPS setting at all.
dmfr
Wed Oct 02, 2024 5:36 pm
From my side, on 7.17beta2, using
- security.authentication-types=wpa2-eap
- security.management-protection=disabled
So far, the issue does not occur anymore, on any wifi adapter (low-end RTL8821 or high-end Intel AX201)
litvcom
Wed Oct 02, 2024 9:35 pm
I tried it on RouterOS 7.16, but it didn't help, so it looks like I'll have to go back to RouterOS 7.14.3 and forget about the update.
inray
Thu Oct 03, 2024 12:21 am
This is unfortunately not a windows driver problem as the same issues exist with Linux clients.
It is a known interoperability problem of RouterOS with the specific Intel WiFi chipsets (AX2xx) used in the vast majority of laptops and motherboards.
Only functional workaround known so far is to disable WPA3 and management protection on ROS side.
Certainly not the ideal solution but the only one until Mikrotik developers find and fix the issue.
MrRobotdev
Mon Oct 07, 2024 9:04 am
@normis
You asked for my support ticket regarding the SA query timeout and the inability to connect different business laptops to wifi since 7.15 version.
Some expert users have found the problem and MIkrotik still in 7.17 beta version has no fix.
Really? Take a Lenovo L13 laptop and setup a wifi with wpa3 configuration and you will understand what i mean.
BEFORE proceeding to feature development you all must fix the important problems like that. Users cannot connect to wifi - this should be a priority i think.
Please read the posts above regarding the problem.
woland
Mon Oct 07, 2024 3:00 pm
Agree with @MrRobotdev, but could you just post your WiFi Adapter type? Most Lenovos come in lots of different variants with possibly different WLAN chipsets.
My Lenovo YogaPro 9 can be added to the list. It has the latest drivers installed and has no issues with TPLink Omada, Unify, Cisco APs using WPA3 PSK or WPA3 Enterprise. There are no issues with CAPac APs running WPA2. But on my CAPax with 7.16: unusable.
WIFI Chipset:
Intel WiFi 6E AX211
infabo
Mon Oct 07, 2024 3:56 pm
I agree. Let's collect the affected client chipsets here. Once there is a larger list collected: Mikrotik can invest ~20$ for that wireless card that appear most frequent in that list. Put this card into some old notebook and start debugging happily. Hopefully resulting in a fix soon.
pdrsks
Mon Oct 07, 2024 8:12 pm
I thought that I solved the problem with the intel ax200 chipset with the no SPMS parameter but unfortunately I still had disconnects. I have switched to a Realtek based card for 22 euros, in particular based on the chipset 8852BE and all my problems are gone and the signal is a little better. For me, it was not worth spending so much time diagnosing the problem insted of buying a new card. I hope the problem can be fixed for intel cards.
woland
Mon Oct 07, 2024 8:23 pm
Well replacing the WLAN adapter in my company issued laptop is not the way I want to go. My Intel card is working perfectly well with every other AP I tried. Also some Lenovos simply refuse WLAN adapters which they don´t get shipped with (don´t ask me why, dumbness of Lenovos policies?).
Also I have one more suspect, but I could not fully confirm it yet: my sons Laptop has a Realtek 8822CE. He complained a lot last summer about the connectivity to the CAPax. So maybe this bug doesn´t only affect Intel cards.
dmfr
Tue Oct 08, 2024 1:54 am
my sons Laptop has a Realtek 8822CE...
It doesn't. Realtek's 88xx are affected as well.
Side note, these series have a history of problems with APs powered by (some) Mediatek chipsets. Ubiquiti Nano HDs were a total disaster with Realtek clients.
So I thought at first the same was happening with new Qualcomm firmware (ROS > 7.14.3)... until we experienced same issues with Intel AXs and discovered how global that problem is..
woland
Tue Oct 08, 2024 10:04 am
Thanks @dmfr! But to me it looks like not all RTL88xx are affected, as @pdrsks wrote, that his 8852BE works flawlessly.
Still good to know the issues are complicated at does not only affect MT.
MrRobotdev
Tue Oct 08, 2024 10:04 pm
WIFI Chipset:
Intel WiFi 6E AX211
Same exactly WIFI adapter here, Intel Wifi 6E AX211 on a Lenovo L13
woland
Thu Oct 10, 2024 12:31 am
Thanks @MrRobotdev, so until now we have:
Intel WiFi 6E AX211
Realtek 8822CE
Those are affected, if WPA3 is used.
Any other chipsets?
inray
Thu Oct 10, 2024 12:03 pm
Thoroughly tested by me and affected when WPA3 is used
Intel WiFi 6E AX201
Intel WiFi 6E AX210
Intel® WiFi 7 BE200
and of course Intel WiFi 6E AX211
dmfr
Thu Oct 10, 2024 1:42 pm
Bad news, below is my last update to support ticket
After more testing in living conditions with :
- 7.17beta2 or 7.16 stable
- wpa2 only + management protection disabled
- additionally, band steering disabled
- various chipsets (Realtek 8821, Intel AX201, Google Pixel 4/6)
it seems that unfortunately the problem is deeper than management protection frames and/or wpa3.
Unexplained connectivity drops still happens under some conditions.
Example :
- 2 (or more) stations with busy, continuous traffic (ex UDP or websocket video streaming)
- other stations almost idle
- at some point, at the same time :
- - connectivity breaks on one of the active stations...
- -... and connectivity breaks as well on one (or more) random idle station(s)
- affected stations will eventually reconnect after several attempts
- no relevant messages in log, except disconnect / connect
Revert to 7.14.3, no more issues. Stress tests such as above always pass.
"SA Query timeout" might be one of the symptoms when mgmt protection enabled, but it is definitely not the root cause.
As of today any potential workaround mentionned does not entirely clear the problem, except revert to 7.14.3
ivicask
Thu Oct 10, 2024 1:59 pm
This is exactly my observation with same settings tried.
For example yesterday i tried to watch movie and my LG OLED and Samsung soundbar disconnected with connection lost 4 times in 2 hours while i try to watch a movie...
Most of the time router kicks all clients same time with query timeout (or connection lost on 7.17)
Zero problems on 7.14.3.
I think at this point Mikrotik should just revert new Qualcomm drivers they added in 7.15 until they figure whats wrong...
infabo
Thu Oct 10, 2024 2:59 pm
it is known to be issues since many months. not even reverted in 7.17beta2. so won't happen.
woland
Thu Oct 10, 2024 7:39 pm
Thanks for your inputs!
So we have issues with WPA3 with the new WIFI AX Drivers at least with the following chipsets:
Intel WiFi 6E AX201
Intel WiFi 6E AX210
Intel WiFi 6E AX211
Intel WiFi 7 BE200
Realtek 8822CE
Unfortunately these are very common chipsets!
I hope MT wakes up and gives us some hints? This must affect lots of users, MT looses lots of reputation here. @Normis ?
infabo
Thu Oct 10, 2024 7:55 pm
Intel ax200 also reported by some.
dmfr
Thu Oct 10, 2024 8:03 pm
"SA query timeout" is a symptom, not the root cause.
The problem occurs as well with wpa2 + no mgmt protection.
WPA3 just makes is more obvious.
I am not sure chipset vendor / model really matters anyway.
Reviewing logs from controller I've seen "drops" from Iphone, Pixel, Intel AX, Realtek 88xx...
One thing, the drop have a tendancy to occur on APs with more than one active (significant traffic) station.
It never happens if there's only one station registered to the AP.
Sddaw
Thu Oct 10, 2024 10:10 pm
dunno bout significant traffic but this! every second-third time i'm on a zoom call wifi drops! ax211 lap <-> hap ax3
robmaltsystems
Forum Veteran
Forum Veteran
Thu Oct 10, 2024 11:20 pm
Sounds like a very similar configuration to me. Same hAP ax2, only with Windows laptops.
woland
Fri Oct 11, 2024 10:39 am
Huhh, not easy to catch and we are probably talking about multiple bugs.
I never had issues with my previous laptop (gave that back, so Wifi chipset unknown) and my mobiles. Only my new laptop seems to be affected and my childs laptop. My previous laptop had Win10 my current one and also my childs laptop has Win11 installed.
I have WPA3 enabled.
Unfortunately I do only spend time around there where my CAPax is installed every 2-3Weeks, so I can´t test right now, but I´ll check tomorrow with WPA2/WPA3 and swithcing off/on management frame protection and then will roll back to 7.14.3, probably will try 7.17betaX as well.
I also have a few Linux laptops, I´ll check them too!
So for me those chips under Win11 are affected with 7.15.x-7.16 on my CAPax.
Intel WiFi 6E AX211
Realtek 8822CE
Thanks everyone for the infos!
MrRobotdev
Re: SA Query timeout
Sun Oct 13, 2024 7:29 am
If 7.14.3 works, why Mikrotik just revert the relevant drivers to that state until they figure out what is going on?
STOP feature development and start bug fix guys... simple as that...
What is the meaning of moving forward to 7.17 or 7.18 if we cannot connect with our business laptops to wifi?
HP also affected
netmn
Tue Oct 15, 2024 2:21 pm
The same issue on AX3, so using 7.14.3 version with Factory Firmware 7.15.2. :mrgreen:
Very sad issue.
luki
Wed Oct 16, 2024 10:20 am
7.17beta2
Unfortunately, the problem still exists, only the name has changed
Intel WiFi 6E AX211
alibloke
Wed Oct 16, 2024 11:23 am
We might have to rename this thread ;)
inray
Wed Oct 16, 2024 4:00 pm
Rewording a long-standing issue instead of fixing it. :?
Well done, Mikrotik!
holvoetn
Re: "not responding" - a.k.a. SA Query timeout
Wed Oct 16, 2024 4:03 pm
Done.
infabo
Wed Oct 16, 2024 4:05 pm
Nit picking: "f.k.a" instead of "a.k.a" ;)
"not responding" - f.k.a. SA Query timeout
holvoetn
Re: "not responding" - f.k.a. SA Query timeout
Wed Oct 16, 2024 4:06 pm
True ...
dmfr
Wed Oct 16, 2024 10:07 pm
Everyone can understand fixing such an issue is no trivial matter.
Especially as it involves a driver from third party (Qualcomm), maybe a binary blob driver,
and it sure takes some special conditions to reproduce,
- ie continuous traffic on several stations (video call is good example),
- plus chipset vendor/model might matter, or maybe not so much, anyway..
However if a few guys at Mikrotik are listening, maybe just a little bit, to their users, they cannot deny the fact that :
** there is something wrong with qcom driver >= 7.15beta **
.and it's not limited to WPA3 / mgmt protection
..and it's not limited to a few low-end chipsets
...and it's not limited to some niche usage
I pers. think (and i'm probably not alone on this) that time for agile testing/debugging based on "stable" releases is largely over now.
As a wifi equipment vendor, mikrotik should be able to build real-hard-life test beds in their own labs, instead on endlessly asking for pcaps and supouts.
In the meantime, for the sake of Mikrotik's reputation,
** please revert, one way or another, to a clean qcom driver (<= 7.14.3 like) ***
Message in a bottle ? Anyone reading this ?
hope so, because :
- users that -are- aware of the problem (a few percent) are legitimately excepting a fix from the vendor, so far the fix (and the vendor) are nowhere to be found, and this is bad
- users (the rest) that are just rolling equipment on production are experiencing everyday bad performance (disconnects, drops), and will legitimely blame mikrotik at the end, not without a lesson learned for their future investments. And this is even worse.
woland
Thu Oct 17, 2024 4:55 pm
Probably no use complaining, but it feels refreshing. After some horrible test results with 7.16.1, 7.17b2 last weekend. I was rolling back my CAPax to 7.14.3. Turns out that even then the results with the laptop of my son (RTL chipset) are still horrible. There are random interruptions, lot of jitter.
I got fed up and purchased TPLink Omada, I´ll replace my CAPax this weekend. I need stable WIFI and I can use my time better for more important things than to try to figure out the newest MT bugs.
Still got one installation based on CAPac/WAPac, but that´s my last one. Runs ROS7, but the old drivers. Lack of VLAN tagging on the driver side for the new drivers is a big no no.
The purchase of my CAPax was just money thrown out the window.
infabo
Thu Oct 17, 2024 5:50 pm
Good point. And given my findings today, it's time to evaluate the competition again. The reason: local flent tests (local test server) are suddenly performing terribly. The whole WiFi tilts and/or pings go beyond 1000ms during the test. Interestingly, the same flent test ran ~half year ago on version 7.13 flawlessly (including perfect prioritization). I have no idea where the problem is coming from now. The UniFi U6+ didn't convince me back then. TP-Link or Zyxel - though I’m leaning more towards Zyxel. I'm curious to see what these manufacturers can offer out of the box.
dmfr
Thu Oct 17, 2024 7:39 pm
Some good & bad probably.
Talking about Unifi, it's a Java controller, some devices have been brillant (AC long range), some devices a real disaster (Nano HD, drops & disconnects never solved)
The general chit-chat about promising competitors might feel good in a frustrating situation, but the focus here is to see the infamous problem fixed the quickest. :)
However, if it can help Mikrotik to realize how fast the house is burning...
WeWiNet
Long time Member
Long time Member
Thu Oct 17, 2024 7:50 pm
My own personal guessing is that additionally the steering (and other stuff) Mikrotik is doing, creates lot of issues. Since the recent ax drivers I see my devices hang, not respond on Wifi
while on 2.4G they should have at least decent coverage. Pages do not load, speed test failures etc. Something I never had before.
But as Mikrotik does not want to give you any meaningful logs for steering events (I asked for that long time ago) nor any other advanced Wifi mechanism, and as nothing can be tuned
its a failing black box.
I am in my last attempt to solve my Mikrotik Wifi network before going to some other brand.
woland
Thu Oct 17, 2024 10:41 pm
I got no real experience with Unify, but my current Omada setup has replaced a previous CAPac & Capsman based installation here (this is another flat, not the one where I was trying to use the CAPax). I had the CAPacs for a year. Before that I had different Openwrt based setups. I have spent so much more time with Capsman and the CAPac APs, than with all the other setups together for the last 15 years. I have high levels of interference here, a scan shows around 100 SSIDs. With CAPacs that was a problem, required continous optimizations. With my current setup which is installed a year ago, I spent maybe 3-4Hours configuring in total. It just works, has lots of nice features, I have no jitter, no disruptions, great performance, VLANs are easy to configure.
Well I still have lots of MT devices, and I love some aspects about them. So I definitely hope also some guys from MT are reading this thread and they do care. Except there were no signs of this yet.
ivicask
Fri Oct 18, 2024 10:19 am
After having months of constant disconnects and i tested every beta versions since 7.15 to 7.17 and tried every possible setting i may discovered something.
I changed wireless interfaces default queue type wireless default(SFQ) to CODEL ( /queue/interface>)
add fq-codel-ecn=no fq-codel-interval=60ms fq-codel-limit=800 kind=fq-codel name=fq
All problems stopped, got devices connected for 7 days now which was impossible before.(7.12 beta)
Can anyone else test this also to confirm?
dmfr
Fri Oct 18, 2024 11:33 pm
Just tried with 7.17beta2 and super-fresh 7.17beta4) with no luck.
Queues on wifi1 (5GHz) and wifi2 (2.4Ghz, not used, but anyway) as per your instructions, replacing wireless-default.
Exact same symptoms.
Test setup used :
- Realtek 8821ce / AX201 laptops, running bittorrent to generate bulk traffic
- Pixel 4a streaming video feed (webrtc like, continuous traffic, no buffering)
In matter of seconds : video stuttering and event. stops. Bit Torrent traffic falling to zero.
Controller log : connection lost / not responding / disconnect / reconnect
Tried again the same after 7.14.3 downgrade, and tried again, and again.
- BitTorrent at 15/20 MB/s (realtek AC max in real life)
- smooth video feeds (with strictly no buffering)
Josephny
Sat Oct 19, 2024 4:49 am
I just tried this (ax3, iPhone) and the frequent association/disconnection continues.
Thank you for the working on this!
ivicask
Sat Oct 19, 2024 5:36 am
Test setup used :
Yeah, "not responding" is another issue, I never saw this in my logs, my fix helped with "connection lost" or "query timeout" type of logs under full signal..
TikTime24
Sun Oct 20, 2024 2:53 pm
Hey Ivica, how did you calculate fq-codel-interval and fq-codel-limit? Why 60ms and 800?
dmfr
Sun Oct 20, 2024 9:15 pm
"Connection lost" is actually the 7.17 rename of the infamous "SA Query timeout".
Different log name, same disease.
Despite all potential fixes tried, it invariably narrows down to the bogus "qcom driver update" introduced in 7.15, which for some reason seem very hard to admit at Mikrotik.
woland
Mon Oct 21, 2024 1:46 pm
My replacement AP did not get delivered in time, so I thankfully tested the suggestion von @ivicask on 7.17b4. I tried testing with HW queue only and also with Codel. I did not notice any positive changes in behavior.
Too bad :(
infabo
Mon Oct 21, 2024 4:13 pm
@ anyone with wpa3-psk enabled and flapping clients: try to enable GCMP (in addition to CCMP). On security profile or directly on the wifi interface:
/interface wifi security set encryption=ccmp,gcmp
woland
Tue Oct 29, 2024 6:12 pm
Thanks @infabo !
Unfortunately I always had both (CCMP & GCMP) enabled.
netmn
Thu Oct 31, 2024 12:48 pm
so we must using 7.14.3 version for normal functionality, great
Santi70
Thu Oct 31, 2024 1:18 pm
I had that problem for a long time, it was removed by itself at some point with version 15
# 2024-10-31 12:13:09 by RouterOS 7.16.1
# software id = G48Y-1U35
# model = RBD52G-5HacD2HnD
# serial number = xxxx
add authentication-types=wpa2-psk,wpa3-psk disabled=no ft=yes ft-over-ds=yes name=sec1 wps=disable
/interface wifi
set [ find default-name=wifi1 ] channel.band=2ghz-n .frequency=2412 .width=20mhz \
    configuration.country=Spain .mode=ap .ssid=mired .tx-power=6 disabled=no security=sec1
set [ find default-name=wifi2 ] channel.band=5ghz-ac .frequency=5660,5220 .width=20/40mhz \
    configuration.country=Spain .mode=ap .ssid=mired .tx-power=18 disabled=no mtu=1500 security=\
    sec1
Jelezka
Sat Nov 02, 2024 9:42 pm
7.16.1 - same problem(( SA Query timeout
robmaltsystems
Forum Veteran
Forum Veteran
Sat Nov 02, 2024 11:22 pm
This topic has now been around for over a year. At some point, we all call it a day. I travel with my laptop to all sorts of places and rarely have an issue. Sure, we all end up in places where they're trying to use an underpowered access point and way too many clients. But generally I just connect and work.
But not at home with my hAP ax2 where I'm usually no more than a few metres away and there's only maybe 10 devices connected. Stability is poor.
Keep getting adverts for WiFi 7 routers. Seriously tempted. Doubt it's can be any worse.
Jef61
Sat Nov 02, 2024 11:34 pm
Tried 7.16.1 today but again many disconnects on WiFi, and back to 7.14.3 :(
woland
Mon Nov 04, 2024 11:37 am
I´m very sad, that I have to agree. Me and my family are using different laptops, from very cheap to very expensive, some old, some brand new. We almost never experience any issues with WLAN. It´s just the CAPax + WPA3.
Since last Friday, the issues are gone as I have given up and replaced the CAPax by a somewhat smaller, but similar in appearance device, which only costs slightly more.
Now we have perfect coverage in every corner of our flat, there is no jitter, no timeouts, no problems and no more time investment needed.
Of course: that device does not support SMB or running containers, but I could not care less. I needed a working AP!
MT has signalized not much interest into looking in this issue since 7.14.3!!!
infabo
Mon Nov 04, 2024 12:54 pm
Please provide a name of the new AP - or it did not happen. ;)
woland
Mon Nov 04, 2024 2:27 pm
Hmm, I did avoid it, so as to not make the MT fanatics too angry.
But since you don´t believe me otherwise: it´s a TP-Link Omada EAP673 with an OC200 controller (I might add some more APs in the future). They are both fed by a HEXPoE. Firewall/router is a an RB5009 here.
I´ve decided to not jump on the WIFI7 train yet and save some money, but also a lot of electric power.
On my other family site I have 2 slightly older EAP670 + a single EAP615 with the same controller. Switches are from MT, firewall is Opnsense.
This setup runs since 2 years, without any problems/tuning on the WIFI side. That´s something, because If I run a scan I get over 100 SSIDs (some have insane TX power) as this is located inside a courtyard. I get lots of noise from every direction.
I don't have any photos, but if I did, I'd probably be a bit embarrassed to show my sloppy cabling.
infabo
Mon Nov 04, 2024 2:52 pm
Thank you. There are not many Mikrotik wireless fanatics here. If any at all (maybe erlinden :P).
erlinden
Mon Nov 04, 2024 3:07 pm
8) 8)
eddieb
Tue Nov 05, 2024 7:57 am
/me too ...
running all MT wifi here
infabo
Tue Nov 05, 2024 8:33 am
I am running Mikrotik wireless as well. But I would not call me a die-hard fan of the gear. But I did not find anything better that matches my requirements. Always open for improvement.
infabo
Thu Nov 07, 2024 10:19 pm
So, now I have wap ax running for about a week and I can't seem to have any of the issues discussed here. I have it pretty much on default, meaning I have wpa2-psk/wpa3-psk enabled and all the other bells and whistles like FT and so on. No issues. Well, don't have fancy pants latest iPhones nor do I have any "smart" IOT wifi devices. Some AX200 cards (win10/linux) as well. But nothing exploded nor did something go crazy.
woland
Fri Nov 08, 2024 10:46 am
Strange, @infabo, maybe you are not running jitter/loss sensitive sessions and you did not look at the logs? Maybe you don´t have interference?
Maybe there was something in my config? But if that was the case, why did others report similar issues like mine. Anyway: I´m not going to throw out my CAPax, so for future reference:
give us your config or nothing happened. :)
Ps. there were no explosions on my side, just disconnects & jitter
seriquiti
Fri Nov 08, 2024 10:57 am
I'm on 7.16.1 on my HAP AX2 at home and still getting WIFI "Lockouts" too.
10-20 seconds of no data going through to wifi clients - totally unresponsive. 7.14.3 doesn't have the issue.
I don't even have WPA3 enabled. Have tried different frequences with no difference. It's at the point where I have installed an old HAP AC Lite where WIFI actually works.
infabo
Fri Nov 08, 2024 11:14 am
My log is flooded with "too strong signal" log entries ("xxxxxx@cap-wifi2 disconnected, too strong signal, signal strength 159"). But this is nothing ever reported here and I have already reported that to Mikrotik. SA query timeout only occasional, no more frequently than on cap ac running wifi-qcom-ac.
Regarding the interference: pretty sure I have no interference. 5ghz spectrum is clean as clean can get. Even on 2ghz I have only one neighbor AP in reach where I can easily use a different channel. Regarding the jitter thing I can't tell. I have no webrtc or any other kind of streams in use. So I can't say.
add frequency=2412,2442,2472 name=channel-2ghz reselect-interval=6h..12h
add frequency=5490-5710 name=channel-5ghz reselect-interval=6h..12h
add authentication-types=wpa2-psk,wpa3-psk encryption=ccmp,gcmp ft=yes ft-over-ds=yes name=foobar wps=disable
add authentication-types=wpa2-psk,wpa3-psk encryption=ccmp,gcmp name=foobar-guest wps=disable
set enabled=yes upgrade-policy=suggest-same-version
add country=Austria datapath=foobar-guest multicast-enhance=enabled name=foobar-guest security=foobar-guest ssid=foobar-guest
add channel=channel-2ghz country=Austria datapath=foobar multicast-enhance=enabled name=foobar-2ghz security=foobar ssid=foobar
add channel=channel-5ghz country=Austria datapath=foobar multicast-enhance=enabled name=foobar-5ghz security=foobar ssid=foobar
add bridge=bridge client-isolation=yes name=foobar-guest
add bridge=bridge name=foobar
add action=create-dynamic-enabled disabled=no master-configuration=foobar-2ghz slave-configurations=foobar-guest supported-bands=2ghz-n
add action=create-dynamic-enabled disabled=no master-configuration=foobar-5ghz supported-bands=5ghz-ac
woland
Fri Nov 08, 2024 11:45 am
Thanks @infabo! I don´t see any difference worth mentioning, but I don´t have access to my config now.
I have never seen that "too strong signal" entry.
Maybe your clients are only using WPA2?
The SA Query timeouts mostly happened to laptops further away from the AP, but not only.
As for the jitter, I spend a lot of time in teleconferences, so probably that´s the reason of my sensitivity.
Beste Grüße
tangent
Fri Nov 08, 2024 12:44 pm
I've got logs from my ax³ going back to August, and I see only 55 instances of "not responding" in that time, the first being 41 days ago, so roughly once a day. The only WiFi bug I'm experiencing is the one where it occasionally latches onto the 2.4GHz and won't switch to 5 until forced.
I'm in a small town, in a detached house, but not so far from neighbors that I'd make that claim. I can see a dozen other networks at the moment.
Okay.
woland
Fri Nov 08, 2024 2:40 pm
I appreciate your answer and your homepage @tangent!
I´m completely clueless, why these issues affect someone, while others don´t have them. It might have something to do with the fact, that in my 2 setups there is interference from many other APs, as both are located in a courtyard on the 2nd floor, facing many other flats.
I certainly had no day passing by without at least a few tens of timeouts.
I´ll certainly observe how MT WIFI makes progress, as the versatility of MT HW & SW is fascinating, but I don´t regret having been replaced it.
DesertDweller
Sun Nov 10, 2024 10:06 pm
Hopefully this helps someone. I simply changed the channel from 36 ( 5180 ) to 40 ( 5200 ) and the problem went away.
Edit: spoke too soon :/
MrRobotdev
Sat Nov 16, 2024 10:59 am
Still No solution for this problem.... An ideas how can solve it?
balu
Tue Nov 19, 2024 4:01 pm
What's new in 7.17beta5 (2024-Nov-13 12:51):
*) wifi - add information to each interface, showing which CAPsMAN manages it or which CAP hosts it when applicable;
*) wifi - added station-roaming support (additional fixes);
*) wifi - fixed failure with "auto" peer update on the OWE interface;
*) wifi-qcom-ac - fix possible conflict between radio and USB initialization on hAP ac2;
*) wifi-qcom-ac - improved CPU load balancing and system stability;
I think it's worth trying.
erlinden
Tue Nov 19, 2024 5:34 pm
Can you share your config?
I read a lot of people running into problems, while others have perfectly stable connections. It might be config related, at least that is pretty easy to analyse.
/interface wifi export
Remove serial and any other private info, post between code tags by using the </> button.
I used @tangent's config as baic config, it can be found here:
https://tangentsoft.com/mikrotik/wiki?n ... ome+WiFi&p
normis
Wed Nov 20, 2024 9:13 am
If the latest beta version does not solve your issue, please send supout.rif file to support, describing in detail about what happened.
Sheriff1972
Wed Nov 20, 2024 9:54 am
I am looking forward to the latest WiFi changes getting rolled into a stable release. At this point I will give it a try
balu
Wed Nov 20, 2024 11:04 am
So far it looks good - no drops all day. The logs are clear too. My device is AX3.
jdub88
Wed Nov 20, 2024 11:54 am
Just wanted to add my $0.02 here, too. This has been a huge problem for me for a while now. I have a hAP AX3. I work from home and regularly have to be on video calls, which is usually when this issue will rear it's head. I've tried skipping DFS channels, disabling WPA3..nothing seems to have helped. At the moment I have my work VLAN SSID running only on 2.4GHz which has been more stable. I am in the UK, so I've set the correct country.
Here's my wifi config - does anything look out of place here?
interface wifi
set [ find default-name=wifi1 ] channel.skip-dfs-channels=10min-cac comment=IOT configuration.country="United Kingdom" .mode=ap .ssid=IOT disabled=no security.authentication-types=wpa2-psk,wpa3-psk
set [ find default-name=wifi2 ] channel.skip-dfs-channels=10min-cac comment=IOT configuration.country="United Kingdom" .mode=ap .ssid=IOT disabled=no security.authentication-types=wpa2-psk,wpa3-psk .connect-priority=0
add comment=WORK configuration.hide-ssid=no .mode=ap .ssid=WORK mac-address=XX:XX:XX:XX:XX:XX master-interface=wifi1 name=wifi3 security.authentication-types=wpa3-psk .connect-priority=0
add comment=WORK configuration.hide-ssid=no .mode=ap .ssid=WORK disabled=no mac-address=XX:XX:XX:XX:XX:XX master-interface=wifi2 name=wifi4 security.authentication-types=wpa3-psk .connect-priority=0
add comment=GUEST configuration.mode=ap .ssid=GUEST disabled=no mac-address=XX:XX:XX:XX:XX:XX master-interface=wifi1 name=wifi5 security.authentication-types=wpa2-psk,wpa3-psk
add comment=GUEST configuration.mode=ap .ssid=GUEST disabled=no mac-address=XX:XX:XX:XX:XX:XX master-interface=wifi2 name=wifi6 security.authentication-types=wpa2-psk,wpa3-psk
add comment=HOME configuration.mode=ap .ssid=HOME disabled=no mac-address=XX:XX:XX:XX:XX:XX master-interface=wifi1 name=wifi7 security.authentication-types=wpa2-psk,wpa3-psk
add comment=HOME configuration.mode=ap .ssid=HOME disabled=no mac-address=XX:XX:XX:XX:XX:XX master-interface=wifi2 name=wifi8 security.authentication-types=wpa2-psk,wpa3-psk
The consensus here seems to be to downgrade to 7.14.3 - However given the big changes at 7.15 to wifi, is that as simple as installing the ros and qcom package for this version and hitting downgrade, or are there config changes/other caveats to be aware of? I am reluctant to try the beta version; I don't need or want latest and greatest, I just need my multiple VLANs & WiFi to be stable. My recent experience upgrading even on the stable channel has been....disappointing, shall we say!
I hope Mikrotik can fix this problem ASAP and turn that golden version that actually gives stable wifi into an LTS.
mainTAP
Wed Nov 20, 2024 1:44 pm
I am also experiencing this issue on AX2 and Chateau LTE18 ax both running 7.16.1 and it's quite frustrating.
balu
Wed Nov 20, 2024 1:57 pm
Do you even read what I wrote above, or are you just typing these posts to write something? @jdub88, have you tried the version I mentioned? On my AX3, the problem no longer occurs.
mndtrp
Wed Nov 20, 2024 2:10 pm
Can you share what change in beta5 is related to resolving this issue?
ateran
Wed Nov 20, 2024 3:01 pm
They renamed the log message so you are not going to see the "SA Query timeout" message.
It's in the changelog: wifi - re-word the "SA Query timeout" log message to "not responding";
So yeah, problem solved...
erlinden
Wed Nov 20, 2024 3:43 pm
FFS, creating a profile just to make fun.
@mndtrip:
In addition, I used the config supplied by @tangent:
You may want to try this to see if it helps.
infabo
Wed Nov 20, 2024 3:44 pm
Can you share the issue you are experiencing besides the log message? It is your first post in this topic.
ateran
Wed Nov 20, 2024 4:05 pm
I created the profile because I'm fed up with basic functionality not working in a wireless router.
I have a hAP ax³ and since I had it never worked well with multiple devices. But the worst thing is that I cannot even use the 5Ghz band with my notebook(having Intel AX200 card) because of the frequent disconnects, standing 2 meters away from the device. I tested it with the latest beta too, same issues present.
This forum, reddit etc. is full of these problems about Mikrotik wireless devices, but still some people like to blame the users
normis
Wed Nov 20, 2024 4:14 pm
I'm sorry about your experience, but as you can see in this thread, beta versions do solve most of the issues for many people.
If you are running the latest beta and stll have some issues, you have to post the full logs and problem descriptions, as we don't know if it's even related to what is being fixed in the betas.
mainTAP
Wed Nov 20, 2024 4:24 pm
Updated the AX2 to the beta5 but the issue is still present.
 2024-11-20 14:29:20 wireless,info 8C:17:59:xx:xx:xx@5ghz disconnected, not responding, signal strength -53
 2024-11-20 14:29:28 wireless,info 8C:17:59:xx:xx:xx@5ghz connected, signal strength -53
 2024-11-20 14:29:44 wireless,info 8C:17:59:xx:xx:xx@5ghz disconnected, not responding, signal strength -50
 2024-11-20 14:29:45 wireless,info 8C:17:59:xx:xx:xx@5ghz connected, signal strength -52
 2024-11-20 15:13:24 wireless,info 8C:17:59:xx:xx:xx@5ghz disconnected, connection lost, signal strength -54
 2024-11-20 15:13:25 wireless,info 8C:17:59:xx:xx:xx@2ghz connected, signal strength -46
 2024-11-20 15:16:31 wireless,info 8C:17:59:xx:xx:xx@2ghz disconnected, not responding, signal strength -47
 2024-11-20 15:16:33 wireless,info 8C:17:59:xx:xx:xx@2ghz connected, signal strength -49
 2024-11-20 15:19:35 wireless,info 8C:17:59:xx:xx:xx@2ghz disconnected, not responding, signal strength -47
 2024-11-20 15:19:37 wireless,info 8C:17:59:xx:xx:xx@2ghz connected, signal strength -47
 2024-11-20 15:21:40 wireless,info 8C:17:59:xx:xx:xx@2ghz disconnected, not responding, signal strength -48
 2024-11-20 15:21:40 wireless,info 8C:17:59:xx:xx:xx@5ghz connected, signal strength -56
jdub88
Wed Nov 20, 2024 4:50 pm
Not yet, no - I am rather reluctant to try betas when there's plenty of folks saying it hasn't addressed their issue. I can't mess about too much with this router for work reasons.
2.4Ghz is working well for me at the moment
alibloke
Wed Nov 20, 2024 5:27 pm
Does this setting help you guys?
security.connect-priority=0/1
mndtrp
Wed Nov 20, 2024 5:41 pm
Single HAP AX2 providing WIFI 2.4Ghz and 5GHz WIFI.
Seeing "disconnected, connection lost, signal strength -<number>
Persistent issues with MS Teams calls and casting to Chromecasts.
Mobile phone disconnects/reconnects.
Issues are only noticeable on 5Ghz.
It's been like this post 7.14.3 and I'm tired of testing builds. That is why I asked.
infabo
Wed Nov 20, 2024 6:20 pm
I have Intel AX200 card too in my notebook. Access point is wap ax right now though. Usually cap ac (with wifi-qcom-ac package) for a very long time. No, I do not have frequent disconnects. 5m and three brick walls away. Yes, 5ghz. Yes, it just works. What now? Maybe this is primarily all an AX3 issue?
But I can tell you one thing: Intel AX200 is a diva. At least the Linux drivers (written by Intel lol).
mainTAP
Wed Nov 20, 2024 6:34 pm
For me the 2ghz seems even worse than 5ghz :
 2024-11-20 16:55:00 wireless,info 8C:17:59:xx:xx:xx@5ghz disconnected, connection lost, signal strength -60
 2024-11-20 16:55:02 wireless,info 8C:17:59:xx:xx:xx@5ghz connected, signal strength -57
 2024-11-20 16:55:48 wireless,info 8C:17:59:xx:xx:xx@5ghz disconnected, connection lost, signal strength -52
 2024-11-20 16:55:48 wireless,info 8C:17:59:xx:xx:xx@2ghz connected, signal strength -47
 2024-11-20 16:58:51 wireless,info 8C:17:59:xx:xx:xx@2ghz disconnected, not responding, signal strength -48
 2024-11-20 16:59:00 wireless,info 8C:17:59:xx:xx:xx@2ghz connected, signal strength -48
 2024-11-20 17:02:02 wireless,info 8C:17:59:xx:xx:xx@2ghz disconnected, not responding, signal strength -47
 2024-11-20 17:02:13 wireless,info 8C:17:59:xx:xx:xx@2ghz connected, signal strength -46
 2024-11-20 17:04:23 wireless,info 8C:17:59:xx:xx:xx@2ghz disconnected, not responding, signal strength -47
 2024-11-20 17:04:26 wireless,info 8C:17:59:xx:xx:xx@2ghz connected, signal strength -47
 2024-11-20 17:07:29 wireless,info 8C:17:59:xx:xx:xx@2ghz disconnected, not responding, signal strength -47
 2024-11-20 17:07:38 wireless,info 8C:17:59:xx:xx:xx@2ghz connected, signal strength -47
 2024-11-20 17:10:40 wireless,info 8C:17:59:xx:xx:xx@2ghz disconnected, not responding, signal strength -47
 2024-11-20 17:10:47 wireless,info 8C:17:59:xx:xx:xx@2ghz connected, signal strength -46
 2024-11-20 17:13:50 wireless,info 8C:17:59:xx:xx:xx@2ghz disconnected, not responding, signal strength -47
 2024-11-20 17:13:52 wireless,info 8C:17:59:xx:xx:xx@2ghz connected, signal strength -48
 2024-11-20 17:16:55 wireless,info 8C:17:59:xx:xx:xx@2ghz disconnected, not responding, signal strength -48
 2024-11-20 17:16:57 wireless,info 8C:17:59:xx:xx:xx@2ghz connected, signal strength -484
 2024-11-20 17:20:00 wireless,info 8C:17:59:xx:xx:xx@2ghz disconnected, not responding, signal strength -49
 2024-11-20 17:20:08 wireless,info 8C:17:59:xx:xx:xx@2ghz connected, signal strength -48
 2024-11-20 17:23:11 wireless,info 8C:17:59:xx:xx:xx@2ghz disconnected, not responding, signal strength -47
 2024-11-20 17:23:13 wireless,info 8C:17:59:xx:xx:xx@2ghz connected, signal strength -47
 2024-11-20 17:26:16 wireless,info 8C:17:59:xx:xx:xx@2ghz disconnected, not responding, signal strength -45
 2024-11-20 17:26:23 wireless,info 8C:17:59:xx:xx:xx@2ghz connected, signal strength -44
 2024-11-20 17:29:25 wireless,info 8C:17:59:xx:xx:xx@2ghz disconnected, not responding, signal strength -47
 2024-11-20 17:29:36 wireless,info 8C:17:59:xx:xx:xx@2ghz connected, signal strength -46
woland
Thu Nov 21, 2024 1:32 pm
Sry. but not very useful, pls. give some details: ROS Version ? Config? Chipset in client?
infabo
Thu Nov 21, 2024 2:37 pm
"8C:17:59" belongs to "Intel Corporate". At lest we know this.
ateran
Thu Nov 21, 2024 2:58 pm
So I installed the new release: 7.17beta6. At first everything started in a similar fashion.
Nov/21/2024 09:00:05 memory	xx:3F@wifi1 disconnected, not responding, signal strength -74
Nov/21/2024 09:00:15 memory	xx:3F@wifi1 disconnected, not responding, signal strength -73
Nov/21/2024 09:03:51 memory	xx:3F@wifi1 disconnected, not responding, signal strength -71
Nov/21/2024 09:10:01 memory	xx:3F@wifi1 disconnected, not responding, signal strength -81
Nov/21/2024 09:59:27 memory	xx:3F@wifi1 disconnected, not responding, signal strength -81
I know the signal is not the best, but I was in a different room, although like 5 meters aways.
After this I tried out the following suggestion:
The issue no longer occurred up until now, but this does seem like a workaround and not a fix.
It seems to me that the client does not hang now at least and just roams to 2.4 and I do not notice the disconnect
infabo
Thu Nov 21, 2024 3:25 pm
just update your client device intel driver - probably more successful than running beta ROS. I have window 10 and Manjaro Linux both running AX200 cards and I dont have these disconnect logs. But I do keep my systems up2date.....
ateran
Thu Nov 21, 2024 3:29 pm
I'm on the latest driver(23.90.0.2) on Windows 11. Everything is up to date.
mainTAP
Thu Nov 21, 2024 3:50 pm
AX2 running the beta5, default config, the client is using AX211
After downgrading to 7.14.3, the client's uptime is 21hours
infabo
Thu Nov 21, 2024 4:41 pm
Interesting. Then it's maybe the different wireless AX chipsets in the MikroTik hardware.
woland
Thu Nov 21, 2024 5:28 pm
It might be: to my surprise CAPax & HAPax2 do share the same chips: QCN-5052 & QCN-5022 (my issues were with CAPax and also with AX211)
Thanks @mainTAP ! Can you pls add if you are using WPA3? Also do you see lots of other neighbors APs ?
Jef61
Thu Nov 21, 2024 7:46 pm
Oke, I have tested 7.17beta6 on ax2
Still a mess, audio stream keeps disconnecting
# 2024-11-21 18:32:44 by RouterOS 7.17beta6
# software id =
# model = C52iG-5HaxD2HaxD
# serial number =
/interface wifi> export
set [ find default-name=wifi1 ] configuration.country=Netherlands .mode=ap .ssid=Kraailook-5 disabled=no security.authentication-types=wpa2-psk
set [ find default-name=wifi2 ] configuration.country=Netherlands .mode=ap .ssid=Kraailook disabled=no security.authentication-types=wpa2-psk
Logging:
 2024-11-21 18:31:01 wireless,info FC:44:82:2A:33:A2@wifi1 disconnected, not responding, signal strength -52
 2024-11-21 18:31:10 wireless,info 2E:02:8A:32:B0:EA@wifi2 connected, signal strength -50
 2024-11-21 18:31:43 wireless,info FC:44:82:2A:33:A2@wifi1 connected, signal strength -53
 2024-11-21 18:31:48 wireless,info AC:67:84:37:E7:B0@wifi1 disconnected, connection lost, signal strength -75
 2024-11-21 18:32:00 wireless,info F8:5E:A0:8C:82:B4@wifi1 connected, signal strength -69
 2024-11-21 18:32:01 wireless,info AC:67:84:37:E7:B0@wifi1 connected, signal strength -66
 2024-11-21 18:33:37 wireless,info FC:44:82:2A:33:A2@wifi1 disconnected, not responding, signal strength -53
 2024-11-21 18:33:39 wireless,info FC:44:82:2A:33:A2@wifi1 connected, signal strength -53
 2024-11-21 18:33:45 wireless,info D8:8C:79:3B:62:9A@wifi1 disconnected, not responding, signal strength -60
 2024-11-21 18:33:49 wireless,info AC:67:84:37:E7:B0@wifi1 disconnected, not responding, signal strength -66
 2024-11-21 18:33:52 wireless,info F8:5E:A0:8C:82:B4@wifi1 disconnected, connection lost, signal strength -67
 2024-11-21 18:33:53 wireless,info D8:8C:79:3B:62:9A@wifi1 connected, signal strength -58
 2024-11-21 18:33:53 wireless,info 3E:2C:D4:47:54:4A@wifi1 disconnected, not responding, signal strength -47
 2024-11-21 18:33:56 wireless,info F8:5E:A0:8C:82:B4@wifi1 connected, signal strength -66
 2024-11-21 18:33:56 wireless,info AC:67:84:37:E7:B0@wifi1 connected, signal strength -76
 2024-11-21 18:35:05 wireless,info FC:44:82:2A:33:A2@wifi1 disconnected, not responding, signal strength -52
 2024-11-21 18:35:07 wireless,info D8:8C:79:3B:62:9A@wifi1 disconnected, not responding, signal strength -56
 2024-11-21 18:35:07 wireless,info FC:44:82:2A:33:A2@wifi1 connected, signal strength -53
 2024-11-21 18:35:11 wireless,info D8:8C:79:3B:62:9A@wifi1 connected, signal strength -57
 2024-11-21 18:35:12 wireless,info F8:5E:A0:8C:82:B4@wifi1 disconnected, not responding, signal strength -67
 2024-11-21 18:35:15 wireless,info F8:5E:A0:8C:82:B4@wifi1 connected, signal strength -68
 2024-11-21 18:36:10 wireless,info F6:49:C3:18:86:F4@wifi1 disconnected, connection lost, signal strength -54
 2024-11-21 18:36:47 wireless,info 70:EE:50:02:51:58@wifi2 connected, signal strength -73
 2024-11-21 18:36:56 wireless,info 70:EE:50:02:51:58@wifi2 disconnected, connection lost, signal strength -69
 2024-11-21 18:37:23 wireless,info F8:5E:A0:8C:82:B4@wifi1 disconnected, connection lost, signal strength -68
 2024-11-21 18:39:16 wireless,info 3E:2C:D4:47:54:4A@wifi1 connected, signal strength -46
 2024-11-21 18:39:19 wireless,info FC:44:82:2A:33:A2@wifi1 disconnected, not responding, signal strength -54
 2024-11-21 18:39:21 wireless,info FC:44:82:2A:33:A2@wifi1 connected, signal strength -57
 2024-11-21 18:39:25 wireless,info AE:64:64:88:EF:93@wifi2 disconnected, connection lost, signal strength -89
 2024-11-21 18:39:25 wireless,info 1E:24:A2:48:7D:81@wifi1 connected, signal strength -75
 2024-11-21 18:39:27 wireless,info F8:5E:A0:8C:82:B4@wifi1 connected, signal strength -67
 2024-11-21 18:41:00 wireless,info F8:5E:A0:8C:82:B4@wifi1 disconnected, connection lost, signal strength -66
 2024-11-21 18:41:07 wireless,info FC:44:82:2A:33:A2@wifi1 disconnected, not responding, signal strength -52
 2024-11-21 18:41:10 wireless,info FC:44:82:2A:33:A2@wifi1 connected, signal strength -57
 2024-11-21 18:41:13 wireless,info F8:5E:A0:8C:82:B4@wifi1 connected, signal strength -67
 2024-11-21 18:41:53 wireless,info FC:44:82:2A:33:A2@wifi1 disconnected, not responding, signal strength -52
 2024-11-21 18:41:53 wireless,info AE:64:64:88:EF:93@wifi2 connected, signal strength -47
 2024-11-21 18:42:04 wireless,info FC:44:82:2A:33:A2@wifi1 connected, signal strength -51
 2024-11-21 18:42:06 wireless,info F8:5E:A0:8C:82:B4@wifi1 disconnected, connection lost, signal strength -67
 2024-11-21 18:42:08 wireless,info D8:8C:79:3B:62:9A@wifi1 disconnected, not responding, signal strength -59
 2024-11-21 18:42:09 wireless,info AE:64:64:88:EF:93@wifi2 disconnected, connection lost, signal strength -41
 2024-11-21 18:42:10 wireless,info F8:5E:A0:8C:82:B4@wifi1 connected, signal strength -68
 2024-11-21 18:42:11 wireless,info 1E:24:A2:48:7D:81@wifi1 disconnected, not responding, signal strength -43
 2024-11-21 18:42:11 wireless,info AC:67:84:37:E7:B0@wifi1 disconnected, not responding, signal strength -71
 2024-11-21 18:42:13 wireless,info D8:8C:79:3B:62:9A@wifi1 connected, signal strength -60
 2024-11-21 18:42:18 wireless,info AC:67:84:37:E7:B0@wifi1 connected, signal strength -77
 2024-11-21 18:42:19 wireless,info AE:64:64:88:EF:93@wifi2 connected, signal strength -43
 2024-11-21 18:42:23 wireless,info F8:5E:A0:8C:82:B4@wifi1 disconnected, not responding, signal strength -67
erlinden
Thu Nov 21, 2024 7:56 pm
Could you give these settings a try, @Jef61:
/interface wifi configuration
  add name=homeapcfg country="Netherlands" mode=ap \
  ssid="Kraailook" channel.skip-dfs-channels=10min-cac \
  security.authentication-types=wpa2-psk,wpa3-psk \
  .passphrase="[Moet je nog even zelf invullen]" .ft=yes .ft-over-ds=yes
/interface wifi
  set [ find default-name=wifi1 ] name=wifi5 \
    configuration=homeapcfg channel.band=5ghz-ax .width=20/40/80mhz
  set [ find default-name=wifi2 ] \
    configuration=homeapcfg channel.band=2ghz-ax .width=20mhz
You might first need to forget the network/SSID on the device involved.
ateran
Thu Nov 21, 2024 8:17 pm
The hAP ax3 has the same chips according to product specifications.
Jef61
Thu Nov 21, 2024 8:49 pm
@erlinden, I have changed the configuration:
add channel.skip-dfs-channels=10min-cac country=Netherlands mode=ap name=homeapcfg security.authentication-types=wpa2-psk,wpa3-psk .ft=yes .ft-over-ds=yes ssid=Kraailook
/interface wifi
set [ find default-name=wifi2 ] channel.band=2ghz-ax .skip-dfs-channels=disabled .width=20mhz configuration=homeapcfg configuration.country=Netherlands .mode=ap .ssid=Kraailook \
set [ find default-name=wifi1 ] channel.band=5ghz-ax .skip-dfs-channels=10min-cac .width=20/40/80mhz configuration=homeapcfg configuration.country=Netherlands .mode=ap .ssid=\
    Kraailook-5 disabled=no name=wifi5 security.authentication-types=wpa2-psk,wpa3-psk
Logging:
 2024-11-21 19:39:48 wireless,info BA:01:EF:BB:6F:CF@wifi2 connected, signal strength -46
 2024-11-21 19:40:08 wireless,info FC:44:82:2A:33:A2@wifi5 disconnected, not responding, signal strength -58
 2024-11-21 19:40:08 wireless,info 3A:D6:A3:3B:C6:E6@wifi5 disconnected, connection lost, signal strength -49
 2024-11-21 19:40:09 wireless,info 3A:D6:A3:3B:C6:E6@wifi5 connected, signal strength -45
 2024-11-21 19:40:10 wireless,info FC:44:82:2A:33:A2@wifi5 connected, signal strength -58
 2024-11-21 19:40:11 wireless,info D8:8C:79:4B:CA:FF@wifi5 disconnected, not responding, signal strength -59
 2024-11-21 19:40:13 wireless,info AC:67:84:37:E7:B0@wifi5 disconnected, not responding, signal strength -74
 2024-11-21 19:40:18 wireless,info FC:44:82:2A:33:A2@wifi5 disconnected, not responding, signal strength -56
 2024-11-21 19:40:20 wireless,info D8:8C:79:4B:CA:FF@wifi5 connected, signal strength -52
 2024-11-21 19:40:20 wireless,info FC:44:82:2A:33:A2@wifi5 connected, signal strength -56
 2024-11-21 19:40:22 wireless,info D8:8C:79:3B:62:9A@wifi5 disconnected, not responding, signal strength -57
 2024-11-21 19:40:26 wireless,info FC:44:82:2A:33:A2@wifi5 disconnected, not responding, signal strength -55
 2024-11-21 19:40:31 wireless,info FC:44:82:2A:33:A2@wifi5 connected, signal strength -56
 2024-11-21 19:40:33 wireless,info BA:01:EF:BB:6F:CF@wifi2 disconnected, connection lost, signal strength -46
 2024-11-21 19:40:34 wireless,info BA:01:EF:BB:6F:CF@wifi2 connected, signal strength -47
 2024-11-21 19:40:43 wireless,info 3A:D6:A3:3B:C6:E6@wifi5 disconnected, connection lost, signal strength -49
 2024-11-21 19:40:47 wireless,info FC:44:82:2A:33:A2@wifi5 disconnected, not responding, signal strength -58
 2024-11-21 19:40:48 wireless,info D8:8C:79:3B:62:9A@wifi5 connected, signal strength -56
 2024-11-21 19:41:20 wireless,info FC:44:82:2A:33:A2@wifi5 connected, signal strength -56
 2024-11-21 19:41:29 wireless,info D8:8C:79:4B:CA:FF@wifi5 disconnected, not responding, signal strength -50
 2024-11-21 19:41:33 wireless,info AC:67:84:37:E7:B0@wifi5 connected, signal strength -79
 2024-11-21 19:41:39 wireless,info D8:8C:79:4B:CA:FF@wifi5 connected, signal strength -57
 2024-11-21 19:42:29 wireless,info F6:49:C3:18:86:F4@wifi5 connected, signal strength -40
 2024-11-21 19:42:36 wireless,info 3E:2C:D4:47:54:4A@wifi5 disconnected, not responding, signal strength -49
 2024-11-21 19:42:36 wireless,info 3E:2C:D4:47:54:4A@wifi5 connected, signal strength -52
 2024-11-21 19:43:00 wireless,info 2E:02:8A:32:B0:EA@wifi2 disconnected, connection lost, signal strength -50
 2024-11-21 19:43:13 wireless,info BA:01:EF:BB:6F:CF@wifi2 disconnected, connection lost, signal strength -45
 2024-11-21 19:43:13 wireless,info 3A:D6:A3:3B:C6:E6@wifi5 connected, signal strength -45
 2024-11-21 19:43:27 wireless,info BA:01:EF:BB:6F:CF@wifi2 connected, signal strength -47
 2024-11-21 19:43:33 wireless,info FC:44:82:2A:33:A2@wifi5 disconnected, not responding, signal strength -56
 2024-11-21 19:43:45 wireless,info AC:67:84:37:E7:B0@wifi5 disconnected, not responding, signal strength -74
 2024-11-21 19:43:46 wireless,info FC:44:82:2A:33:A2@wifi5 connected, signal strength -58
 2024-11-21 19:43:47 wireless,info BA:01:EF:BB:6F:CF@wifi2 disconnected, connection lost, signal strength -45
 2024-11-21 19:43:47 wireless,info 3A:D6:A3:3B:C6:E6@wifi5 disconnected, connection lost, signal strength -52
 2024-11-21 19:43:50 wireless,info 3A:D6:A3:3B:C6:E6@wifi5 connected, signal strength -46
Jef61
Thu Nov 21, 2024 8:55 pm
I'm going to switch back to 7.14.3 now, otherwise I'll get into a fight here :D :shock:
erlinden
Did you update both RouterOS and firmware?
Pretty sure support would like to have your supout file. If you have the chance...
Jef61
Thu Nov 21, 2024 9:07 pm
Yes, both updated.
kratos
Thu Nov 21, 2024 11:53 pm
I’m experiencing the same error on a new ‘cap ax’ device with the latest update, version 7.16.1. The devices keep disconnecting periodically, which is extremely annoying.
tangent
Fri Nov 22, 2024 2:59 am
You should read my guide more carefully. It goes to some trouble to explain how and why to solve the redundant and conflicting configuration you've got going on here, doubtless owing to use of WinBox instead of the CLI.
I wonder if this is part of the reason people are having trouble: WinBox makes it stupendously easy to cause this type of redundancy, which may then give RouterOS conflicting instructions, preventing things like FT from working properly because the configuration isn't the same for all radios on the same SSID. It tries to make the transition, finds that it cannot due to a configuration difference, and then bounces the client out.
My persnickety nature may be the secret behind my success here: I don't tolerate messy configurations, which gives RouterOS no choice but to do exactly what I told it to do.
sadMikrotikUser
Fri Nov 22, 2024 7:26 am
Joined the forum to let others know that I also have been experiencing SA query timeout related issues.
I have downgraded my C52iG-5HaxD2HaxD (hAP ax²) to v7.14.3 and my wifi network issues have disappeared.
MrRobotdev
Fri Nov 22, 2024 8:54 am
The frustrating thing is that Mikrotik cannot resolve the problem that persists for so many months.
Eventually i bought a usb2ethernet adapter for my business laptop and a long 7 m ethernet cable on the floor to solve the problem.
What a shame really...
Jef61
Fri Nov 22, 2024 9:56 am
I have decided to stop using Mikrotik wifi (disable it). I ordered a 3-set of Asus XD5.
infabo
Fri Nov 22, 2024 10:22 am
Looks like a nice little device. Features a lot of "AI" features. Have fun!
jdub88
Fri Nov 22, 2024 11:16 am
It does seem counterintutive. I've been consideing ditching the wifi too, however with my work machine only on a 2.4ghz radio, it's been totally fine on 7.16.1
jdub88
Fri Nov 22, 2024 11:22 am
Thanks for writing and sharing this. I don't use winbox, but I did look through it and from what I could see it was more (in relation to mine, anywya) neat than doing much diferent
Anything about this stand out to you as clearly wrong?
set [ find default-name=wifi1 ] channel.skip-dfs-channels=all comment=IOT configuration.country="United Kingdom" .mode=ap .ssid=IOT disabled=no \
set [ find default-name=wifi2 ] channel.skip-dfs-channels=10min-cac comment=IOT configuration.country="United Kingdom" .mode=ap .ssid=IOT disabled=no \
add comment=PRIV configuration.hide-ssid=no .mode=ap .ssid=PRIV mac-address=XX:XX:XX:XX:XX:XX master-interface=wifi1 name=wifi3
   security.authentication-types=wpa3-psk \
add comment=PRIV configuration.hide-ssid=no .mode=ap .ssid=PRIV disabled=no mac-address=XX:XX:XX:XX:XX:XX master-interface=wifi2 name=wifi4 \
add comment=GUEST configuration.mode=ap .ssid=GUEST disabled=no mac-address=XX:XX:XX:XX:XX:XX master-interface=wifi1 name=wifi5 security.authentication-types=\
    wpa2-psk,wpa3-psk
add comment=GUEST configuration.mode=ap .ssid=GUEST disabled=no mac-address=XX:XX:XX:XX:XX:XX master-interface=wifi2 name=wifi6 security.authentication-types=\
    wpa2-psk,wpa3-psk
add comment=HOME configuration.mode=ap .ssid=HOME disabled=no mac-address=XX:XX:XX:XX:XX:XX master-interface=wifi1 name=wifi7 security.authentication-types=\
    wpa2-psk,wpa3-psk
add comment=HOME configuration.mode=ap .ssid=HOME disabled=no mac-address=XX:XX:XX:XX:XX:XX master-interface=wifi2 name=wifi8 security.authentication-types=\
    wpa2-psk,wpa3-psk
mainTAP
Fri Nov 22, 2024 11:26 am
Both WPA3 and WPA2 are enabled, there are no neighbor's AP at 5ghz in sight and one 2ghz far at -87dbm, but I also have Chateau LTE18 ax at different channels, which is also experiencing the same issue. The client is 4-5m away from the AP without any obstructions in between.
erlinden
Fri Nov 22, 2024 11:53 am
Not clearly wrong (at first sight), I totally love the concept of DRY.
So, something like this:
add name=homeapcfg country="United Kingdom" mode=ap ssid="HOME"
add name=iotapcfg country="United Kingdom" mode=ap ssid="IOT"
add name=privapcfg country="United Kingdom" mode=ap ssid="PRIV"
add name=guestapcfg country="United Kingdom" mode=ap ssid="GUEST"
/interface wifi channel
add name=homeapchan2 skip-dfs-channels=10min-cac band=2ghz-ax width=20mhz
add name=homeapchan5 skip-dfs-channels=10min-cac band=5ghz-ax width=20/40/80mhz
add name=homeapsec authentication-types=wpa2-psk,wpa3-psk passphrase="yourPSKgoesHere" ft=yes ft-over-ds=yes
add name=iotapsec authentication-types=wpa2-psk,wpa3-psk passphrase="yourPSKgoesHere" ft=yes ft-over-ds=yes
add name=privapsec authentication-types=wpa2-psk,wpa3-psk passphrase="yourPSKgoesHere" ft=yes ft-over-ds=yes
add name=guestapsec authentication-types=wpa2-psk,wpa3-psk passphrase="yourPSKgoesHere" ft=yes ft-over-ds=yes
/interface wifi
set [ find default-name=wifi1 ] channel=homeapchan5 configuration=homeapcfg security=homeapsec
set [ find default-name=wifi2 ]  channel=homeapchan2   configuration=homeapcfg security=homeapsec
add comment=PRIV configuration=privapcfg  mac-address=XX:XX:XX:XX:XX:XX master-interface=wifi1 name=wifi3 security=privapsec
add comment=PRIV configuration=privapcfg mac-address=XX:XX:XX:XX:XX:XX master-interface=wifi2 name=wifi4 security=privapsec
add comment=GUEST configuration=guestapcfg  mac-address=XX:XX:XX:XX:XX:XX master-interface=wifi1 name=wifi5 security=guestapsec
add comment=GUEST configuration=guestapcfg mac-address=XX:XX:XX:XX:XX:XX master-interface=wifi2 name=wifi6 security=guestapsec
add comment=HOME configuration=homeapcfg  mac-address=XX:XX:XX:XX:XX:XX master-interface=wifi1 name=wifi7 security=homeapsec
add comment=HOME configuration=homeapcfg mac-address=XX:XX:XX:XX:XX:XX master-interface=wifi2 name=wifi8 security=homeapsec
It is less error-prone, and making adjustments is sooooo much easier.
Jef61
Fri Nov 22, 2024 12:07 pm
I don´t use Winbox and have reset the device many times to factory settings (with the new version). The only way to get it stable is using version 7.14.3.
I'm a big Mikrotik fan, using it for many years, but not going to advice Mikrotik WiFi anymore.
jdub88
Fri Nov 22, 2024 2:28 pm
/interface wifi
Thank you for this, looks so much cleaner. Will have a little cleaup.
Things have been oddly stable the last few days, too..
tangent
Fri Nov 22, 2024 7:36 pm
I don´t use Winbox
Then that leaves me wondering how you managed to produce eight redundancies in that configuration, plus one outright conflict. This configuration is cleaner and simpler while saying very nearly the same thing:
add name=homeapcfg ssid=Kraailook country=Netherlands mode=ap \
/interface wifi
set [ find default-name=wifi2 ] configuration=homeapcfg \
    channel.band=2ghz-ax disabled=no .width=20mhz
set [ find default-name=wifi1 ] configuration=homeapcfg \
    channel.band=5ghz-ax disabled=no name=wifi5
The only liberty I took here was combining your SSIDs, without which your declared wish for ".ft=yes" is pointless in a single-AP setup. If you truly do want separate 2.4 and 5 GHz networks, then you'd put just the .ssid setting back the way it was and then take the .ft settings out of the homeapcfg definition.
Even if this change fails to solve your stability problem, and you find yourself back on 7.14.3, I'd still give the same cleanup advice.
Airiasas
Fri Nov 22, 2024 10:47 pm
Can someone look through my config too, as I am getting loads of SA Query timeout/ "not responding" errors in the log. Also extremely poor network performance of WiFi..
# 2024-11-22 20:27:41 by RouterOS 7.17beta6
# software id = 3ZSU-PBZW
# model = RB5009UPr+S+
# serial number = ****************
add admin-mac=*********************** auto-mac=no comment=defconf name=bridge
set [ find default-name=ether1 ] comment=Port1 name=Fiber_eth1
/interface vlan
add interface=Fiber_eth1 name=vlanfiber vlan-id=911
add comment=defconf name=WAN
add comment=defconf name=LAN
add authentication-types=wpa2-psk,wpa3-psk disabled=no name=sec1
add country="United Kingdom" datapath.bridge=bridge disabled=no mode=ap name=\
    2ghz security=sec1 ssid="Home - Wi-Fi"
add country="United Kingdom" datapath.bridge=bridge disabled=no name=5ghz \
/disk settings
set auto-media-interface=bridge auto-media-sharing=yes auto-smb-sharing=yes
# not running
# not running
# not running
# not running
# not running
add bridge=bridge comment=defconf interface=ether6
# not running
add bridge=bridge comment=defconf interface=ether7
add bridge=bridge comment=defconf interface=ether8
# not running
add bridge=bridge comment=defconf interface=sfp-sfpplus1
add comment=defconf interface=Fiber_eth1 list=WAN
add comment=defconf interface=vlanfiber list=WAN
/interface ovpn-server server
add mac-address=********** name=ovpn-server1
/interface wifi cap
set caps-man-addresses="" certificate=request discovery-interfaces=bridge \
    enabled=yes
/interface wifi capsman
set ca-certificate=auto enabled=yes package-path=/packages/ \
    require-peer-certificate=no upgrade-policy=suggest-same-version
/interface wifi provisioning
add action=create-dynamic-enabled disabled=no master-configuration=2ghz \
    supported-bands=2ghz-n,2ghz-g,2ghz-ax
add action=create-dynamic-enabled disabled=no master-configuration=5ghz \
    supported-bands=5ghz-a,5ghz-n,5ghz-ac,5ghz-ax
    192.168.88.0
/ip dhcp-client
add address-pool=default-dhcp interface=bridge lease-time=3h name=defconf \
    parent-queue=*FFFFFFFF
/ip dhcp-server lease
add address=192.168.88.253 mac-address=********************* server=defconf
    192.168.88.1
inray
Sat Nov 23, 2024 3:29 pm
Disable wpa3 leaving only wpa2 enabled and you should be OK.
Nothing wrong with your config, btw. The problem is RouterOS wifi implementation, not a user error.
jimmys01
Sun Nov 24, 2024 11:01 am
This issue is starting to bother me as imensly.
I will share my experience. I have arround 20 tasmotas (iot) in the house and 2 phones (xiaomi 11 note 5g)
The phones are havving this issue and when it happens it does not matter if I connect the device to 5ghz or 2.4ghz.
I also figured that when this happens the devices are stuck to 1000 kbps at the wifi registration page both in Tx Rate and Rx Rate.
Mikrotik, do something. Please
Airiasas
Mon Nov 25, 2024 1:33 am
Disabling WPA3 did not resolve the issue, but thanks for the advice...
erlinden
Mon Nov 25, 2024 9:55 am
Can you add/change a couple of things:
add band=2ghz-ax disabled=no frequency=2412,2437,2462 name=CHAN-2G skip-dfs-channels=10min-cac width=20mhz
add band=5ghz-ax disabled=no frequency=5170-5735 name=CHAN-5G skip-dfs-channels=10min-cac width=20/40/80mhz
/interface wifi datapath
add bridge=bridge disabled=no name=DP
add channel=CHAN-2G country="United Kingdom" datapath=DP disabled=no name=CONF-2G ssid="Home - Wi-Fi" mode=ap security=SEC1
add channel=CHAN-5G country="United Kingdom" datapath=DP disabled=no name=CONF-5G ssid="Home - Wi-Fi" mode=ap security=SEC1
add=action=create-dynamic-enabled disabled=no master-configuration=CONF-2G supported-bands=2ghz-ax
add=action=create-dynamic-enabled disabled=no master-configuration=CONF-5G supported-bands=5ghz-ax
Basicly a clean up, with all the settings in the correct place. And some adjustments (as you can see).
Hope this makes things better.
My assumption is that you only use AX CAPS, is that correct?
jimmys01
Mon Nov 25, 2024 2:27 pm
second day today, seems solved for me!! I will let you know if something changes
mndtrp
Mon Nov 25, 2024 5:07 pm
Testing this as well with the latest development build (7.17rc1). Not holding my breath. Will report back.
Edit: iPhone 16 and Chromecasts just dropped off WIFI. 30 minutes into testing... Will let the test run for the rest of the day.
Edit2: Just as bad as before. Rolling back to 7.14.3
Edit3: Rudimentary ping script showing devices loosing WIFI. Version 7.17.rc1 deployed at 16:30. Rollback to 7.14.3 at 21:30 with no more disconnects.
Link is up 16:43:24.56
Link is down 16:47:04.73
Link is up 16:47:08.93
Link is down 17:02:22.72
Link is up 17:02:29.12
Link is down 17:14:41.28
Link is up 17:14:42.77
Link is down 17:21:51.71
Link is up 17:22:18.44
Link is down 17:22:24.75
Link is up 17:22:25.89
Link is down 17:22:30.72
Link is up 17:22:31.94
Link is down 17:22:36.72
Link is up 17:22:37.96
Link is down 17:22:42.70
Link is up 17:22:43.78
Link is down 17:29:46.75
Link is up 17:30:02.94
Link is down 17:30:07.75
Link is up 17:30:13.84
Link is down 17:42:02.22
Link is up 17:42:08.73
Link is down 17:44:56.70
Link is up 17:45:00.92
Link is down 17:45:05.73
Link is up 17:45:11.81
Link is down 17:53:37.71
Link is up 17:53:43.78
Link is down 17:55:48.73
Link is up 17:55:49.98
Link is down 17:55:56.49
Link is up 17:56:02.53
Link is down 17:56:07.22
Link is up 17:56:08.54
Link is down 17:57:48.72
Link is up 17:57:54.83
Link is down 17:57:59.73
Link is up 17:58:05.99
Link is down 17:58:10.75
Link is up 17:58:11.82
Link is down 18:03:18.73
Link is up 18:03:25.09
Link is down 18:03:29.72
Link is up 18:03:31.09
Link is down 18:03:37.73
Link is up 18:03:39.04
Link is down 18:03:45.22
Link is up 18:03:46.72
Link is down 18:03:51.72
Link is up 18:03:53.19
Link is down 18:03:59.23
Link is up 18:04:06.08
Link is down 18:04:10.73
Link is up 18:04:21.82
Link is down 18:04:26.73
Link is up 18:04:28.02
Link is down 18:04:34.21
Link is up 18:04:35.92
Link is down 18:04:42.21
Link is up 18:04:43.28
Link is down 18:28:35.73
Link is up 18:28:37.04
Link is down 18:28:41.70
Link is up 18:28:42.78
Link is down 18:40:34.22
Link is up 18:40:40.29
Link is down 18:43:04.72
Link is up 18:43:11.04
Link is down 18:43:15.72
Link is up 18:43:17.04
Link is down 18:43:23.21
Link is up 18:43:24.67
Link is down 18:43:29.74
Link is up 18:43:35.97
Link is down 18:43:42.21
Link is up 18:43:43.29
Link is down 19:10:20.23
Link is up 19:10:21.46
Link is down 19:10:29.25
Link is up 19:10:30.43
Link is down 19:10:35.23
Link is up 19:10:36.66
Link is down 19:18:41.73
Link is up 19:18:43.27
Link is down 19:22:56.25
Link is up 19:22:59.01
Link is down 19:36:02.72
Link is up 19:36:09.15
Link is down 19:43:47.22
Link is up 19:43:48.43
Link is down 20:00:03.76
Link is up 20:00:09.84
Link is down 20:00:22.73
Link is up 20:00:28.95
Link is down 20:00:35.23
Link is up 20:00:36.31
Link is down 21:21:25.45
Link is up 21:21:32.10
Link is down 21:21:39.71
Link is up 21:21:41.01
Link is down 21:21:55.70
Link is up 21:22:07.24
Link is down 21:23:58.24
Link is up 21:24:32.27
Airiasas
Mon Nov 25, 2024 10:53 pm
Yes I use cap ax APs, I have made the changes still getting loads of disconnects and very poor WiFi performance.
When I bought the mikrotik kit I understood that wireless might not be top of the line, but I did not expect it to be so bad... Hopefully they can resolve it...
erlinden
Tue Nov 26, 2024 8:41 am
Can you post the current config, at least the /interface wifi part?
Have you enabled debug logging for wireless? That might give some more insights.
normis
Tue Nov 26, 2024 8:45 am
This topic is becoming a mix of every possible wifi related issue. Please always post exact log of the error, routerOS version, device model and preferably chipset. They are not all the same issue.
pfyod
Tue Nov 26, 2024 8:58 am
The symptom is always the same ("SA Query timeout" / "not responding") and the only "fix" that reliably works is rolling back to 7.14.3.
My setup is:
isp modem -ethernet-> ax3 (acting as a router) -wifi-> [ax3 (station bridge), ax2 (station bridge)]
and I experience "SA Query timeout" on connections between primary ax3 and station bridge devices on 7.15 and 7.16. I'll be trying 7.17 when stable is out, but judging from this thread is still might not fix the issue...
normis
Tue Nov 26, 2024 9:13 am
just to confirm, what is the signal when this happens? does it happen if the devices are reasonably close to eachother?
jimmys01
Tue Nov 26, 2024 9:18 am
I had the SA Query log error and after the update the not responding log error and I am now at 7.17beta6. After changing the default queue type from SFQ to CODEL as the post above, Its my thired day of not having issues. I repeat that only my Xiaomi Phones where havving issues and it was even when switching between 2.4g and 5g and it would go away by itself after a few minutes and come back randomly. Model is C52iG-5HaxD2HaxD
normis
Please everyone that still sees "not responding" (previously called "SA Query timeout") in their log on 7.17rc versions.
- hardware model of AP
- hardware model of the client that is disconnecting
- post exact log messages
- post distance from client to AP when this happened
- post registration table info, and frequency that is used at that time
- if nothing else is changed, simple downgrade to 7.14.x fixes it or not?
- all of this send also to support@mikrotik.com including Supout.rif file from the device, made when issue happened.
- also include supout.rif from 7.14.3 where the issue does not happen, but same device is connected
WE DO NOT HAVE YOUR SUPOUT.RIF files from 7.16 and newer. I checked our support system, and there is no up to date debug information reported by anyone. Please help us to find the issue, by providing this information.
mndtrp
Tue Nov 26, 2024 10:38 am
I have posted support information as requested. Please investigate.
robmaltsystems
Forum Veteran
Forum Veteran
Tue Nov 26, 2024 11:34 pm
This gives me a little bit of comfort that the issue is most likely software, not hardware related. And thank you to Mikrotik with engaging with us all in asking for logs.
gjmelena
Re: "not responding" - f.k.a. SA Query timeout
Thu Nov 28, 2024 4:15 pm
- hardware model of AP - RB5009UG+S+
- hardware model of the client that is disconnecting - doesn't matter, lot of devices
- post exact log messages - screenshot
- post distance from client to AP when this happened - 3 meters, directly visible
- post registration table info, and frequency that is used at that time - doesn't matter, see screenshot
- if nothing else is changed, simple downgrade to 7.14.x fixes it or not? - no it doesn't help
[admin@MikroTik] > /interface wifi export
# 2024-11-28 14:52:46 by RouterOS 7.14.3
# software id = 6WWU-BQIS
# model = RB5009UG+S+
add disabled=no mode=ap name=WifiCfg1 security.authentication-types=wpa2-psk .encryption="" .ft=yes .ft-over-ds=yes ssid=\
KZP steering.rrm=yes .wnm=yes
add datapath.bridge=bridge .vlan-id=3 disabled=no name=WifiCfg2 security.authentication-types=wpa2-psk .encryption="" .ft=\
yes .ft-over-ds=yes ssid=KZP-Public steering.rrm=yes .wnm=yes
add bridge=bridge name=vlan3 vlan-id=3
set enabled=yes interfaces=bridge package-path="" require-peer-certificate=no upgrade-policy=none
add action=create-dynamic-enabled disabled=no master-configuration=WifiCfg1 slave-configurations=WifiCfg2
normis
Thu Nov 28, 2024 4:30 pm
RB5009UG+S+ has no wireless interfaces. What are the actual APs used?
gjmelena
Thu Nov 28, 2024 4:38 pm
2 devices - both cAPGi-5HaxD2HaxD
also downgraded to - 7.14.3
sinisa
Fri Nov 29, 2024 9:38 am
As I (and some other people too) wrote a few times before:
remove ft-over-ds=yes completely.
You can also add connect-priority=0/1 but I don't think it makes big difference, ft-over-ds is the main problem.
KozmoNaut
Fri Nov 29, 2024 7:53 pm
I disagree on FT over DS being the culprit.
I have FT and FT over DS turned on and Connect Priority set to 0/1, and roaming works perfectly for both Android and iPhones, as well as laptops (primarily the claimed problematic Intel AX210 and AX211 adapters). I see no "not responding" or "SA Query Timeout" messages in the log.
Previously, it did not work correctly until I set Connect Priority to 0/1.
The setup is an RB5009 as CAPsMAN controlling a wAP AC and a cAP AC, all are running 7.16.2. Both APs were configured by resetting to CAPS mode and turning off IPv6 forwarding to accept RAs and set an IPv6 via SLAAC.
infabo
Sat Nov 30, 2024 2:11 pm
wifi-qcom-ac drivers may not be affected at all. No issue here as well.
sinisa
Sat Nov 30, 2024 7:20 pm
Well, my experience is what I wrote, with ft-over-ds many clients would Timeout, without it everyone is happy.
So just try it, it takes e few seconds to change config, a within a minute you'll know it it works for you...
KozmoNaut
Sun Dec 01, 2024 12:40 pm
As I said, I tried several different combinations of configuration.
Out of everything I tested, enabling both FT and FT over DS and setting Connect Priority to 0/1 is the solution that made the errors stop.
gjmelena
Mon Dec 02, 2024 12:36 pm
Well, this is probably going to be a surprise.
Since then, it hasn't acted up... or I just didn't notice...
Please, don't start arguing here.
Honestly, I don't understand how MikroTik can allow this. This basically tarnishes their brand entirely. If I had known what kind of problems this would cause and that in our company meeting room, they’d rather just run an HDMI cable, I would have bought Ubiquiti instead. I sent an email to MikroTik support. Up until now, I haven't received a single email confirming that it was even delivered successfully. After many years, I must say this is truly a disaster. There are even free ticketing systems available
holvoetn
Mon Dec 02, 2024 12:45 pm
@gjmelena
And your point is ?? It's not really clear from your post.
PS I always use create enabled on capsman provisioning, simply to avoid numbers creeping up whenever a reboot/reconnect happens for whatever reason.
infabo
Mon Dec 02, 2024 1:42 pm
@gjmelena what is your issue with create enabled?
And regarding the free ticket system: Mikrotik uses a commercial ticket system: https://help.mikrotik.com/servicedesk/servicedesk
And on case you wrote directly to support@mikrotik.com, this also be channeled to their ticket system IIRC. If you did not receive the auto-reply, then maybe your mail inbox is misconfigured (detected mail as spam e.g.)
robmaltsystems
Forum Veteran
Forum Veteran
Tue Dec 03, 2024 11:47 am
I must say it's certainly stopped me rolling out any Mikrotik Wi-Fi 6 installations or updates which basically means I've not been installing Mikrotik for six months now as most clients are asking for (and really should be using) Wi-Fi 6.
I held hope that going back to an earlier firmware seems to resolve it which suggested software over hardware issues. Not so sure now after the recent series of replies here :(
robmaltsystems
Forum Veteran
Forum Veteran
Tue Dec 03, 2024 11:48 am
Oh no, Jira ;-)
infabo
Tue Dec 03, 2024 1:19 pm
Always to complain
erlinden
Tue Dec 03, 2024 1:29 pm
For me, specifically adding the connect-priority=0/1 (in combination with default settings mostl) made my Samsung S21+ and iPhone 11 roam without disconnecting first. No error messages after that. Currently on 7.17RC2, but it also worked for me on 7.16.2. Also my laptop, which has the Intel AX211 is no longer giving me headaches.
infabo
Tue Dec 03, 2024 1:33 pm
Weren't you on the "My Mikrotik wifi6 works like a charm"-train all the time?
erlinden
Tue Dec 03, 2024 1:36 pm
It does :lol:
Have done a lot of tweaking finding out I already had best settings.
infabo
Tue Dec 03, 2024 4:11 pm
I would call this a workaround. Sort of. I don't know why "accept- equals hold-priority" is the default after all.
gjmelena
Wed Dec 04, 2024 10:38 am
could someone explain what exactly the connect-priority=0/1 setting in MikroTik configuration affects?
Thanks for pointing that out, the email did indeed end up in the spam folder, which is unusual for me.
As for the create enabled, I don’t have a problem with that setting itself. I followed various guides on the internet, including MikroTik's documentation, and tried multiple configurations. The issue seems to be a combination of several errors occurring simultaneously.
Primarily the claimed problematic Intel AX210 and AX211 adapters – yes, I can confirm that these adapters, in combination with MikroTik, indeed cause issues with roaming, which fails to work properly. I have at least two laptops with these chips, one of which is used by a person who frequently needs to present on a projector. As I understand it, however, this is a driver issue, not a MikroTik problem.
neki
Wed Dec 04, 2024 12:22 pm
Try to use help page... https://help.mikrotik.com/docs/spaces/R ... Properties
infabo
Wed Dec 04, 2024 4:17 pm
I'd like to hear an explanation why this is the default behavior:
If (accept-priority of AP2) = (hold-priority of AP1), a connection to AP2 will be allowed only if the MAC address can no longer be reached via AP1.
This basically - IMHO - leads to unnecessary disconnect messages in log. Client is connected to AP1 and wants to roam over to AP2. But AP2 disallows, because of "client is responding on AP1" decision? IMHO it is normal behavior that client still holds the connection to AP1 to avoid interruption. This is quite dumb move by AP2 and does not improve roaming experience. But on the other hand, I see clients roaming perfectly with default settings as well.
neki
Wed Dec 04, 2024 4:59 pm
Question is, if one client can be connected to two different APs on two different frequencies at same time.
gftjhnk
Fri Dec 06, 2024 3:08 pm
I am on version 7.17rc2. The connection breaks continue. The connection is disconnected with a laptop with an AX210 network card. Moreover, during the break, the Internet disappears, including on the phone. But problems with the phone are not displayed in the logs.
104 2024-12-06 15:36:37 memory wireless, info 10:91:D1:D3:D6:DC@homewifi_5GHz disconnected, connection lost, signal strength -70
105 2024-12-06 15:36:50 memory wireless, info 10:91:D1:D3:D6:DC@homewifi_5GHz connected, signal strength -63
106 2024-12-06 15:37:22 memory wireless, info 10:91:D1:D3:D6:DC@homewifi_5GHz disconnected, connection lost, signal strength -71
107 2024-12-06 15:37:50 memory wireless, info 10:91:D1:D3:D6:DC@homewifi_5GHz connected, signal strength -64
110 2024-12-06 15:43:55 memory wireless, info 10:91:D1:D3:D6:DC@homewifi_5GHz disconnected, connection lost, signal strength -70
111 2024-12-06 15:43:59 memory wireless, info 10:91:D1:D3:D6:DC@homewifi_5GHz connected, signal strength -65
112 2024-12-06 15:44:19 memory wireless, info 10:91:D1:D3:D6:DC@homewifi_5GHz disconnected, connection lost, signal strength -67
113 2024-12-06 15:44:29 memory wireless, info 10:91:D1:D3:D6:DC@homewifi_5GHz connected, signal strength -65
erlinden
Fri Dec 06, 2024 3:28 pm
Welcome, @gftjhnk. Have you red all comments and changed configuration accordingly? Being able to replicate the problem isn't difficult.
alibloke
Mon Dec 09, 2024 5:42 pm
In summary:
* connect-priority=0/1 seems to be mandatory for Intel based wifi cards
* WPA3 works for some devices, but not others (oddly my phone used to roam just fine a few versions ago) so cannot be used yet :(
* ft-over-ds makes no difference for me
* dynamic/static slave cap interfaces makes no difference
infabo
Mon Dec 09, 2024 5:47 pm
In summary:
No. I have no such disconnect issues on my Intel AX200 devices (Windows+Linux).
alibloke
Mon Dec 09, 2024 6:04 pm
Interesting, which version of rOS are you running?
infabo
Mon Dec 09, 2024 6:05 pm
7.16.2
normis
Tue Dec 10, 2024 9:12 am
It seems that several different issues are mixed together in one topic, for example:
- AX100/AX200 series clients reconnecting
- "Not responding" (previous versions "SA query timeout") error in non other devices (AX100/AX200 clients)
balu
Tue Dec 10, 2024 1:50 pm
That's correct, and additionally, in 7.17rc2 it seems that the issue has returned. It's not as frequent as before, but for the second day in a row, I've experienced a drop on the 5G device while conducting a video call.
4A:1D:9C:7D:AB:E2@wifi_5g disconnected, not responding, signal strength -54
B6:15:04:92:71:BA@wifi_5g disconnected, not responding, signal strength -72
B6:15:04:92:71:BA@wifi_5g connected, signal strength -75
4A:1D:9C:7D:AB:E2@wifi_5g connected, signal strength -54
JonathanYoung2161
Mon Dec 16, 2024 1:21 am
20H+ over 6 days in on this issue before I found this forum. I had tried dam near everything to include another hAP ax 3!. The only work around was to roll back to 7.14.3. What a joke! We upgraded to x3 hAP ax 3 AP's and they worked great from 7.12.2 to 7.14.3 and all versions since have been crap.
I'm a die hard Mikrotik fan boy but this is ridicule!
normis
Mon Dec 16, 2024 10:20 am
Please see above, we need as much details about your setup and devices, as possible. And please try to use latest 7.17 when you make the RIF file, and send to support. You can downgrade after, but without those debug files, we can't do much.
We have received maybe 2-3 tickets about this from this topic. Please contact us, we can't solve this issue without your help.
balu
Mon Dec 16, 2024 9:04 pm
Normis you’ve already received 2-3 [devices], and in my opinion, that’s more than enough. I personally contributed to this effort, even though support is asking me to weaken my security by disabling WPA-3 and checking the registration table to see if someone might have hacked me I'm curious if, by doing this, you would take responsibility for any potential damages caused by weakening the router's security. After all, the bank would conveniently wash its hands of the matter, and I would lose my money.
Do you sell devices that are properly tested and of decent quality, or are they just kits from some Chinese manufacturer that we have to assemble and test ourselves? Be serious and start offering real solutions. You have a laboratory for testing; users here have put a lot of time and effort into isolating what causes the error—get to work and solve the problem!
By the way, I invited one of your consultants to my house; I’ll make him dinner, and he can monitor the router logs for me. So far, I haven’t received a response as to whether they’re interested or not.
normis
Tue Dec 17, 2024 10:06 am
No, that is not enough, as we have not been able to replicate the issue in our testing environment. There could be more vairables in the affected setups, that we have not yet identified.
P.S: the consultants are not mikrotik developers or testers, they only help you configure the devices and are independent contractors
maigonis
Tue Dec 17, 2024 12:19 pm
Lets try to have some order related to current WiFi problems, as I do see two main issues discussed over forums and this topic, also I do suffer more or less myself. Those two issues are "SA Query timeout", that is related to WPA3 security problems (temp solution is to completely disable WPA3 and MFP) and "connection lost", that can affect any connected device on ax lineup and ac ipq40xx lineup whit vendor drivers (currently no workaround known to me).
First of all, both issues are not issues on their own, as those log entries can be present under normal usage. For example if device goes on idle, or changes APs (roams), changes networks (SSIDs), moves to mobile data etc. So if you see a few entries and you dont feel issues then you are probably fine, no reason to panic.
If you are affected whit these issues while using WiFi, for example while browsing web, gaming, Zooming (video calls), connection suddenly drops, or your smart TV looses connection while watching Netflix - then this is a real issue for you and your network.
Both issues can be related as both have the same symptom - AP have lost connection to STA (station). Or it be-leaves it does. It sounds like a low level issue (driver, firmware), as most cases I see people are showing logs whit STA rx level quite hi, aka STA is very close to AP. There is no way AP cant hear it, so mission it to find whats going on.
What to do next? Quite often i see people claiming that MT staff do not care about this, etc, but I dont believe that's the case. As Normis have sad - MT staff cant reproduce it in lab. Yesterday at work I was setting up CBs (Chromebooks), 26 identical CBs whit Intel AX201 wlan card, but only a few devices had this issue (wap ax used as AP), so even if MT staff have Intel wlan card in lab, it might not show this issue (this is what makes this issue harder to identify). So do sent supouts to support (so staff can see your logs and config) + as much as info you can give about STA. Most importantly what type of wlan card it has (OS you use, driver version etc). Even by mentioning brand and model can be problematic, as vendors do change hardware part related to markets. Also do attach pictures whit useful info, make videos, give more detailed descriptions, not just "not working!". STAs can flap because of other reason too, for example if your AP and STA have different countries set. Mediatek related cards do this, at least newer ones. Symptom is the same, but issue is different. Or PMKID presence or not on some wlan cards, etc. So do report properly, complaining on forums might not (most likely not) solve this issue. And dont forget that some STAs are "stupid", as manufacturer have issues on their own whit software (possibly hardware) and older devices can have compatibility issues whit newer wifi generation. These two problems are not MT specific and will affect you under any vendor AP.
mndtrp
Tue Dec 17, 2024 2:34 pm
Isn't the workaround for "connection lost" to roll-back to 7.14.3? It is for me and a lot of other impacted users posting in this thread.
The problem with this workaround is that we are missing out on new features, bug fixes and security patches. Which is very bad.
In my case all devices connected to my 5Ghz network loose connection at the same time. It's not a specific vendor/driver/firmware. it's ALL connected devices. 10+ of them. Chromecasts, 3rd party chromecast speakers, Nest hubs, Nest speakers, various iPhones, laptops etc.
I am actively supporting Mikrotik with supouts based on a multitude of configurations. This is eating up massive amounts of my time and WAF is dropping drastically. Mikrotik is nowhere near to finding the root cause of the issue. I'm even sharing my full, partial and minimal configuration (.rsc) with Mikrotik with the supouts and they should be able to use this in their labs to re-create the issue on ax devices. But it does seem that they instead use me (us) to identity the root cause, instead of putting effort into reproducing this issue and do low-level troubleshooting in labs made for that purpose.
Just my 2 cents.
maigonis
Tue Dec 17, 2024 4:39 pm
Just my 2 cents.
I agree that company should be able to solve these kind of issues on its own, if community can help - great. A basic device operation and stability whit default settings should be achievable. If you as user mess something up in config its on you, support can guide you to resolve it or help achieve some specific goal.
I personally haven't tested 7.14.3 (my lab wap ax cant even downgrade, min ROS version is 7.15.1), as I don't see this issue that much as others, but some models can have additional problems. Like ax2 have/had at one point, dunno if it was fully solved. All this adds up on even worse user experience.
As network enthusiast i really appreciate MT devices and capabilities ROS gives, it can be configured in way almost no other vendor can match (at least similar price point), so much fun, but currently I cant recommend AP lineup to regular consumer or enterprise because of these two (one?) issues. I can deal whit them, but most users cant.
normis
Tue Dec 17, 2024 4:44 pm
Remember that this error is a completely normal error message in most networks. It is when a station is not responding. There could be many reasons, sleep, went away etc.
We are only talking about situations where signal has not changed and device is actively being used, and did not go anywhere. Seeing a few of these messges from time to time is completely normal otherwise.
CosignerStainless
Tue Dec 17, 2024 5:00 pm
I've been following this because I experience it also. Everything matches what I have seen above. I won't bother with technical details, since that has all been said, but maybe I can talk about my general environment. I've tested almost all of the config changes mentioned in this thread and others, and none seemed to affect things. 7.13.4 has worked completely reliably since I downgraded to it.
In case more info on the environment helps: cAP ax bought in ~August 2024, disconnections from every few hours to every few hours. It is ceiling mounted in a dense European central city, in a concrete building but there are still plenty of external wifi APs visible from all sides. We have a mix of Linux, Android, iOS, and MacOS devices, depending on the time from 5-10 devices total. I haven't seen any pattern of when it happens (when I'm alone, when more people are around, etc). It was most notable on a laptop (Latitude 7310) with a Intel Wireless-AC 9462 controller, but perhaps because that laptop is the one with the longest-running connections and most use. It happens even when the laptop was almost in line of sight of the AP.
RouterOS 7.13.4 works, 7.15 and 7.16 haven't worked. I haven't tried 7.17 beta/rc because of the "can't downgrade" proposed feature: losing the ability to downgrade is really dangerous with a long-running problem like this (I realize with the latest versions, downgrades are possible, but still I am a bit hesitant/haven't had time). Since the AP is now fully in use, it will take some time to upgrade(+re-downgrade) to get a new test + supout.
maigonis
Tue Dec 17, 2024 6:54 pm
Yes, only connections dropping while in use.
A note, other vendors, for example Unifi as direct price competitor, will not show you logs, at least not by default. So you, as user, have no idea what kind of shenanigans is happening in background. Some might have even more warning and errors, but connection is still working, aka user is not interrupted, so its fine (?).
You can still downgrade, but you need to re-enable it. That will require you to toggle power to unit. (yank that cable)
jooomk
Tue Dec 17, 2024 7:07 pm
I'm having similar problems since upgrading to from 7.08 to 7.16 with multiple cap ax and hap ax3 devices. For me, It seems the errors mostly occur with Intel hardware, older Apple devices(iPhone 11 and 13) and older Android(TV) devices. I've been able to fix the SA Query timeout issue by creating 2 SSIDs one for WPA2 and one for WPA3 and setting the connection priority setting, however the connection is still very unreliable and random disconnects occur, which require a full WLAN cycle on/off/on to get the client connected again. I'm really unsatisfied how the is handled here to say It mildly, there was plenty of time to fix this and several devices which are widely used are affected. At another building, I've 2x IPQ8071A devices with latest OpenWrt + AX + Roaming, and they work just fine even with the Intel and Apple hardware.
Also, I think It's a really cheap excuse to just say this doesn't appear in testing, then your testing process is faulty which is another issue most likely. For example, a basic SSID with WPA2/3 mixed setup simply won't work with latest Windows 11 and an Intel AX200 card, how is this not in your test matrix? Is there an automated testing setup in place, like a larger VM hosts with PCIe pass-through and run automated tests against the most used Wi-Fi hardware and OSs. Ensuring the client can connect multiple times, roam and the connection stays stable? Because this would really help to ensure the software works to some degree.
jdub88
Tue Dec 17, 2024 7:19 pm
I am back on 7.14.3, though I did have an odd blip earlier..
If I want to disable management frame protection, do I need to do this on the Master WiFI or can I do it on the specific SSID, in the context of the below? I want to try WPA2 across the board.
interface wifi
set [ find default-name=wifi1 ] channel.skip-dfs-channels=10min-cac comment=IOT configuration.country="United Kingdom" .mode=ap .ssid=IOT disabled=no security.authentication-types=wpa2-psk,wpa3-psk
set [ find default-name=wifi2 ] channel.skip-dfs-channels=10min-cac comment=IOT configuration.country="United Kingdom" .mode=ap .ssid=IOT disabled=no security.authentication-types=wpa2-psk,wpa3-psk .connect-priority=0
add comment=WORK configuration.hide-ssid=no .mode=ap .ssid=WORK mac-address=XX:XX:XX:XX:XX:XX master-interface=wifi1 name=wifi3 security.authentication-types=wpa3-psk .connect-priority=0
add comment=WORK configuration.hide-ssid=no .mode=ap .ssid=WORK disabled=no mac-address=XX:XX:XX:XX:XX:XX master-interface=wifi2 name=wifi4 security.authentication-types=wpa3-psk .connect-priority=0
add comment=GUEST configuration.mode=ap .ssid=GUEST disabled=no mac-address=XX:XX:XX:XX:XX:XX master-interface=wifi1 name=wifi5 security.authentication-types=wpa2-psk,wpa3-psk
add comment=GUEST configuration.mode=ap .ssid=GUEST disabled=no mac-address=XX:XX:XX:XX:XX:XX master-interface=wifi2 name=wifi6 security.authentication-types=wpa2-psk,wpa3-psk
add comment=HOME configuration.mode=ap .ssid=HOME disabled=no mac-address=XX:XX:XX:XX:XX:XX master-interface=wifi1 name=wifi7 security.authentication-types=wpa2-psk,wpa3-psk
add comment=HOME configuration.mode=ap .ssid=HOME disabled=no mac-address=XX:XX:XX:XX:XX:XX master-interface=wifi2 name=wifi8 security.authentication-types=wpa2-psk,wpa3-psk
It pains me to be running on an older release and not using WPA3.
andyhenckel
Thu Dec 19, 2024 9:11 pm
I am on this post due to same issue.
latest 7.16.2.
very simple setup
netmetal ax to netmetal ax. (im using AX at my house, and with the most generic settings (none specified everything has been working.)
I made a connection with the client device to a hapac for testing - worked fine.
then today, in the field - we have the most basic settings/default.
changed only from default -
country-US
ssid- internet
security - wpa2
pass phrase - mysecuritypass
Same on both sides. Simple AP-Station.
It shouldn't be this hard.
I've tried all of the above guesses that may or may not have worked for other folks - To no avail.
Modifying FT paramaters yeilded nothing.
connect 0/1 no change
add fq-codel-ecn=no fq-codel-interval=60ms fq-codel-limit=800 kind=fq-codel name=fq ----- still no change.
Wpa3 - no change.
Mikrotik - if you cannot reproduce the problem, and you have a working 7.16.2 config for a basic Client and AP setup PTMP or PTP - please post so the rest of us can use the product. Kind regards.
I've noticed some SA query timeouts on my home net. But mostly I don't notice an issue for laptop or tv connections.
But it boggles my mind that I can't get a simple AX netmetal to AX netmetal to work after having used mtik products for 9 years.
infabo
Thu Dec 19, 2024 9:27 pm
@andyhenckel Now please create a supout.rif on each Netmetal AX. Send it to support@mikrotik.com. Thank you.
lele
Sat Dec 28, 2024 11:38 am
I concur. I am fighting these days with WiFI issues on hap ax^2 and ax^3 (on 7.16) and there are devices that work perfectly (firesticks, newer macbooks, apple tv, smart TVs, and all the old, 2.4GHz only hardware) while some are completely unreliable and disconnect every few seconds (few years old ipads, an XPS with intel wifi, and ikea/sonos speakers)
Everything worked fine before I replaced the old HAP ac.
macgaiver
Fri Jan 03, 2025 9:32 am
(copy from another topic)
So, before Christmas i upgraded Intel WiFi driver to 23.100.0 for my AX201... no disconnection problem since, ok i had only few days of test because of the holidays , but before it happened daily at least once. you guys might like to give it a try.
vaskoss
Fri Jan 03, 2025 5:27 pm
For me (hopefully) it looks like connect priority 0/1 fixed problems I had. Currently I have enabled mixed WPA2/3 mode with management protection = required and I have no SA Query timeouts since then. I'm not sure if there are any security flaws connected with this connect priority settings, but at least I can use WPA3
According to my observations to have FT work correctly I had
- disable management protection and use WPA2 only
- or use connect priority 0/1 setting
otherwise FT is not working well and clients are offten disconnected before registration to another AP.
edit : unfortunatelly SA query timeouts are back. Not so many as before, but problem still exists
aperture147
Fri Jan 03, 2025 7:59 pm
I'm using hap ax3, currently on routerOS/routerBOARD/wifi-qcom version 7.16.2, having connection-priority = 0/1, separate connection group of 2.4 and 5GHz to two separated groups, disabled PMKID but the problem stills persist. All of my Apple devices are disconnected at the same time, even my dishwasher was disconnecting from the wifi for the same SA Query timeout error.
This is not a "haha funny" experience, especially when I need to download a big file oversea with 10Mbps connection and suddenly the connection dropped and due to some policy the download URL are not resumable, and you have to download that file again with ethernet cable plugged, super inconvenient. My PC Wifi card, an intel ax200 card, are also suffer from this problem.
I've been using Mikrotik routers for a long time, but this is the first time I bought a Mikrotik AP and not happy about it. Should have sticked with the good old Huawei AX3, was working for 3 years non-stop.
MichalPospichal
Mon Jan 06, 2025 8:34 pm
I too started having the "SA Query Timeouts" now and I know exactly what introduced it and how to reproduce it randomly.
Almost a year ago I bought cAPax and I manage it via Capsman from RB5009, it is the only cAP managed by it. I have a several devices (mostly IoTs) on 2Ghz connected permanently, but on the 5Ghz radio the only permanently connected device has been my phone (Motorola Android14). Occasionaly I had other devices connected randomly for shorter periods of time like other phones and laptops, with zero issues, not once the phone disconnected on me.
A couple weeks ago I bought a WiiM Ultra streamer and connected it to this 5Ghz WiFi - since then I have been observing my phone disconnecting randomly with the SA Query Timeout while the streamer is using the network. Sometimes the streamer gets disconnected too after a few seconds the phone disappears, but sometimes it keeps the connection, but it still stops the playback for about 10 seconds like it was not getting the data, which is very weird, it seems like the phone being disconnected totally messes up the 5Ghz network for a brief amount of time for everything connected. I even observed this brief playback cutout on another streamer connected to the 2Ghz network.
As someone wrote higher up in this thread, it seems there are no issues with single device being connected in the network, but with 2 "just right" connected devices at the same time the magic starts happening. And judging by the number of the affected people by this issue, it is not that hard to reproduce.
This is not normal and it definitely must be fixed by Mikrotik.
Just to add, the ROS is the latest 7.16.2 and the 2Ghz and 5Ghz SSIDs are separated, so no roaming involved. This is happening on single 5Ghz network. I just cannot comprehend, that if it is clearly confirmed by lots of people that 7.14.3 was ok and that was the last version with the older wireless driver, why Mikrotik refuses to accept there is something clearly wrong in the new driver?
grzegorzb
Tue Jan 07, 2025 9:38 am
My setup consists of AX3 as capsman and AX2 and WAP AX as CAP. Software version 7.16.2 on each device. Unfortunately, there are frequent internet outages especially on Acer (Intel 201 AX wifi card) and HP_830 (Intel 210 AX wifi card) laptops. Unfortunately, I do not have the possibility to downgrade the ROS version to e.g. 7.14.3 because of the WAP AX.
I have sent the supout.rif file to support.
It is a pity that fixing this problem is not a priority for the Mikrotik team, it severely lowers the already questionable reputation for WiFi networking :(
I've been following this thread for a while and when I read responses that it's difficult to reproduce the aforementioned problem in-house, it unfortunately speaks ill of the testers/programmers :(
In addition, I would like to mention that the problem occurs not only on AX hardware, after installing the qcom package on ac hardware (HAP AC3 capsman, HAP AC2, CAP AC) there are also problems with WiFi network stability, in addition to frequent “kernel failure in previous boot”. The problem was reported to support, but the response time is unheard of, and by this time I was forced to repair on my own. Reverting to ROS 7.12 and uninstalling the qcom package restores stability, but this deprives support for WAP3 security.
maigonis
Tue Jan 07, 2025 10:00 am
As far as I have debugged whit my limited skills, looks like AP can send death frames to STAs. I have seen reason code 7 on android devices and reason code 3 on my test wap ax as station connected to ax3 whit no specific reason. I guess that there is a code error somewhere, that makes some part of AP code stack think that STA have left AP, but its not the case. As result when STA receives deauth frame it actually leaves AP as 802.11 standards require, and we get log entry "connection lost", or "sa query timeout" on AP. This affects all wave2 lineup devices afaik.
I have reported this to support.
kcastner
Sun Jan 12, 2025 12:17 am
I could reproduce this too - in my headers there is only a vendor specific deauth reason. Does anybody know the reason?
KindlyMan
Mon Jan 13, 2025 4:15 pm
Same problem in 7.17rc7 (hap ax3). HP laptop and iphone periodically lose connection with router. Only the 5GHz network is enabled. DHCP server is configured correctly and there is a bridge with hap ac in station pseudobridge mode in 20 Mhz AC mode. Bridge with hap ac is needed for a wired connection to music server. I've been using Microtik for 8 years and this is the first time problems with my devices.
Today I have set channel width to 20/40/80 in wi-fi interface settings. I hid channel as 0000 in screenshots.
The status now shows only two priority channels. If you don't select any option in channel width, then much more priority channels are displayed.
No. Still problems
rif file has been sent to support
I found the reason for the loss of signal in all gadgets with a router. Private wi-fi address mode was enabled on iphone settings in static address mode. Turning off this mode doesn't result in loss of signal from the router during two day. Additionally turned off Wi-Fi Assist mode in cellular data.
true
mndtrp
Thu Jan 16, 2025 6:33 am
Did this also solve the issue you are having with the HP laptop? What settings did you change on that device to make it stay connected?
I have similar issues and I can configure my iPhone the same way, but I also have loads of Chromecast enabled devices and they are not configurable. So, I'm very curious to understand how just changing settings on your phone impacted devices that do not have the same configuration options?
Either way. I'm glad that you found a workaround that works for you! :)
KindlyMan
Thu Jan 16, 2025 11:56 am
thx :)
Now there is no complete disconnection from router. But on HP communication level dropped to a minimum once last night. Previously, there was a complete shutdown of all devices after iPhone connection was lost. In general, the problem has not been completely solved, and it is strange that Microtic don't pay due attention to this.
KindlyMan
Thu Jan 16, 2025 11:58 am
Hi. We are waiting for a solution to problem with signal loss at router. Now you have my rif files to analyze.
KindlyMan
Fri Jan 17, 2025 7:58 pm
Mikrotk answered me by mail
Please check these items in interface settings.
