ilgmars
CHR image for ARM systems?
Fri Aug 18, 2023 2:01 pm
Is there a CHR image for ARM?
The plan is to deploy it on the Oracles ARM instance.
Thank you,
Ilgmars
BartoszP
Re: CHR image for ARM systems?
Fri Aug 18, 2023 2:02 pm
No such image on "Download page" = No :(
stmx38
Long time Member
Long time Member
Sat Dec 23, 2023 9:37 am
Is there a way to run CHR natively on Apple ARM or UTM is a single solution?
ahmdzaki18
Sat Dec 23, 2023 10:51 pm
Is it for ARM Ampere cpu? If yes, is it coming soon.
stmx38
Long time Member
Long time Member
Wed Jan 03, 2024 11:12 am
Software run on Hetzner Ampere run fine on Apple ARM M-series.
Did Mikrotik announce it anywhere?
mkx
Wed Jan 03, 2024 11:38 am
https://mikrotik.com/download ... scroll down past PPC and before X86 architectures.
anav
Thu Jan 04, 2024 4:23 pm
What the hex is Ampere..... MT sold with a tazer ??
Assuming its like a new Cloud virtual computer or something not linux, not windows but something else VPS???
https://amperecomputing.com/
Is it software is it hardware.... seems rather vague to me.
mkx
Fri Jan 05, 2024 8:44 am
It's an ARM processor with some "AI accelerator" silicon parts built in. Since AI is a huge buzz word, everybody is looking at how to make it run faster. They found out that GPGPUs are not optimal for AI (e.g. even single-precission floating point is too precise), they started to design dedicated acceleration chips, specifically to run AI workloads. Ampere looks like one of those. ROS will very likely not benefit from those AI accelerators, but if this Ampere thing is getting widely used in cloud hosting, then demand for Ampere CHR will only rise. I guess that Ampere CHR will be simple ARM CHR, but why not jump on this hype?
sinisa
Fri Jan 05, 2024 8:00 pm
My idea when starting search for "CHR+ARM" was to run it on Rapberry Pi (or clone) as a VM.
For example, I'd like to run CAPsMAN on it, instead of on hap ac2, and leave hap as an AP only.
Waiting for first alpha images...
floaty
Wed Feb 28, 2024 10:07 pm
over a pita-situation with an ISE-deployment ... I found this ...
https://community.cisco.com/t5/security ... -p/4866726
start reading at <<Why I chose Traefik to run in OCI>>
Larsa
Wed Feb 28, 2024 11:12 pm
Ampere Computing LLC, with brands like Ampere Altra and Ampere One, is a family of processors with different design objectives where some models are optimized for networking.
floaty
Wed Feb 28, 2024 11:39 pm
You are in a Free Trial. When your trial is over, your account is limited to Always Free resources.
¯\_(ツ)_/¯ ... and there is no thing in the world, which is always free ... I'm standing against the damp in the cabooze for a while now ... to know that
but ... let it last ... 3 ... 2 years ... or a half ( if only for "how to learn to hate the cloud" : )
where is my ampere-image ? : )
stmx38
Long time Member
Long time Member
Fri Apr 19, 2024 9:04 pm
v7.15rc [testing] is released!
!) system - added support for AMPERE (R) and ARM64 CHR installations (new ARM64 CHR image available);
Download
floaty
Sat Apr 20, 2024 10:14 am
oh really !?
floaty
Sat Apr 20, 2024 11:22 am
nix Filetto di Manzo !
Pizza Margherita senza Mozzarella ¯\_(ツ)_/¯
Znevna
Mon Apr 22, 2024 10:15 pm
@floaty, you seem to be a little lost, you ok?
floaty
Wed Apr 24, 2024 12:25 am
nah ... fine ... just back in reality
but not giving up so fast ... just asked my trusted Oracle Cloud Adoption Assistant in which region I can get my free "VM.Standard.A1.Flex"-maschin'sche ...
there is no rest ... until that 'dingen' is booted with a CHR-image : )
floaty
Tue May 14, 2024 9:27 pm
... seems it is not happening in the near future ...
<<Thank you for reaching out. Always Free services are based on capacity in the data center, if you cannot create the shape you want is due to there is no capacity currently available in your home region.
Please, be aware that paid accounts have higher priority.
You have two options: to wait until some of those resources become available or to upgrade your account to PAYG (Pay-As-You-Go), this way you will only be charged for the paid resources that you consume , that are above and beyond the published free limits, see https://www.oracle.com/emea/cloud/free/#always-free
Find below the Free Tier FAQ for more information:
https://www.oracle.com/uk/cloud/free/faq/
Please, don't hesitate to reach me if you need anything else.>>
... mabe I should ask for a paperweight ... ... or warm underwear ... ... summer is coming ...
normis
Wed May 15, 2024 9:02 am
Your posts are off topic. If you want to discuss how to make a free oracle account ... of whatever that rant is about ... you can make a new topic.
CHR Image for ARM/AMPERE is on the webpage and works fine for example in Hetzner
floaty
Sun May 26, 2024 12:22 am
pardonner ... wishful surmise ... ~ ... sat me adrift
BillyVan
Wed Feb 12, 2025 7:57 pm
Just received from Hetzner support
Thank you for your request.
I'm sorry to inform you that CAX servers only support UEFI boot.
If you need any further assistance, please feel free to contact us again.
Kind regards
Da**d B***w
Hetzner Online GmbH
try to install with
curl -L https://download.mikrotik.com/routeros/ ... .2.img.zip | funzip | dd of=/dev/sda bs=1M
On Hetzner Ampere CPU vps CAX21
https://ibb.co/DH4B3gCk
