Please release this same version as long-term.*) www - improved service stability when receiving malformed packets;
Actually ROS6 is like the long-term version.
That was my question also............. what precipitated the change, an edge case or something that affects general use???@EdPa
Could you elaborate more what "stability when receiving malformed packets" means?
This almost certainly means DoS / RCE from exposed www service. "Stability" in Mikrotik-speak means crashes.@EdPa
Not yet. See post #4 above for further explanation.Does it also come as long-term version ?
Everything is possible.Hello
Since 6.49.10 i have troubles streaming my Cams in Homekit when i am outside from my Home (i.e. LTE or external WLAN).
Can this caused by the new enhancement: "www - improved service stability when receiving malformed packets;" ?
br, Richard
First, contact support and find out what exactly the problem is. (support@mikrotik.com or https://help.mikrotik.com/servicedesk/)Firmware and Software is on 6.49.10 .. ist there a way back for both ? or is only a software rollback necessary ? (sorry, it is my first time for a potential rollback) :-)
Did you upload the older firmware to the Files tab and then click on Downgrade from the Packages tab ? You also need to update the firmware in the RouterBOARD tab afterwards. I've downgraded with the same router many times without any issues... Else, Netinstall the firmware you wish to use.Firmware and Software is on 6.49.10 .. ist there a way back for both ? or is only a software rollback necessary ? (sorry, it is my first time for a potential rollback) :-)
btw: it's also a RB4011iGS+5HacQ2HnD-IN ... but no errors RX or TX on the interfaces ?!?
I have submitted a ticket (SUP-128685) 5 days ago with no response so far... as this is my first ticket with Mikrotik, what are the normal turnaround times here?OK, created a support case :-)
thx !
Their is a link to Mikrotik Consultants here, too: https://mikrotik.com/supportBefore contacting us:
- If you have purchased your device from a distributor, please contact them first.
- Check documentation and configuration examples. Maybe answer is already there.
- Make sure that your issue is present with the latest version of MikroTik RouterOS. The latest version is available at the download section.
- Give us a brief problem description that includes information about your network setup.
- Provide us with support output file (suppout.rif), that is created when problem appears, instruction how to make it.
- Technical support does not include training on TCP/IP.
- E-mail reply might take up to 3 business days.
On Long term channel the status is "System is already up to date", on stable channel the status is stuck(ed) in "New version is available." state.@Numlock, if you change Channel to long term, is this still happening?
Data leak on image...Update to 6.49.10 but keep in loop update.
I don't think, this is the cause. After updated the router on Stable channel, the status is remaining New version... The build number(s) must be the same in this case.That is because LTS and stable are on the same version (but there might be a difference in build number which is not the same as version). Just ignore it. Or not.
