Well, i've got nothing on this...been trying to create an IKEv2 IPSEC tunnel in my RB 760iGS for a week now and i've got nothing on this. Tried with RSA, PSK, nothing works on android. Got lots of peer's ID does not match, reconf the REMOTE_ID to ignore but even then i got disconnected right after getting an IP from the VPN pool.
So my question is: can anyone shed some light on how to configure a IKEv2/IPSEC PSK tunnel on ROS 7 ? I followed all the available tutorials on the forum and got nothing out of it.
My setup is quite simple:
ISP_Router <-> PC
<-> PC
<-> Raspberry
<-> Mikrotik RB 760iGS (my VPN server)
I've opened the ports 500 and 4500 on my ISP router and forwarded to Mikrotik but i simply cannot establish the tunnel no matter what.
I've been using self-signed certs for the RSA without luck (even tried Let's Encrypt). I have DDNS.NET on my ISP router to a given DNS name that i used as the server common-name and subject-alternative-name (xxxxxxx.ddns.net).
Anyon with a step-by-step working guide for IPSEC PSK?
Many thanks to you all!
EDIT: Followed this just now...peer ID issue, managed to ignore REMOTE ID Type, and now i have "killing ike2 SA: xxxxxxx (IP:xxxxx)" just after acquiring IP...
