larmaid
[ask]Bandwidth Test & Load Balancing....??
Thu Nov 15, 2007 8:45 pm
1. how to use bandwidth-test in mikrotik tool....?
2. i want to ask what is load-balancing....? i've been searching the internet for load-balancing in mikrotik and i found very diffrent info about load-balancing. is it like this =
a. when router 1 down and then router 2 will take charge (VRRP) or
b. ISP1:256KBPS + ISP2:512KBPS = 768KBPS
need help pliss from forum guru or anyone...?
i'm very noob in load-balancing and i'm sorry if my english is bad :(
thx for advanced
i like it
larmaid
Re: [ask]Bandwidth Test & Load Balancing....??
Sat Nov 17, 2007 7:00 am
anyone..?? :(
i like it
Chupaka
Sat Nov 17, 2007 5:21 pm
Bandwidth-test: http://www.mikrotik.com/testdocs/ros/2. ... /btest.php
Load-balancing means using different channels to Internet simultaneously
Russian-speaking forum: https://forum.mikrotik.by/. Welcome!
For every complex problem, there is a solution that is simple, neat, and wrong.
MikroTik. Your life. Your routing.
larmaid
Sun Nov 18, 2007 7:36 am
euy the bandwidth-test only work for mikrotik :(
chupaka can u be more specific about load balancing, can i do this with load balancing =
[/quote]
i like it
shielder
Sun Nov 18, 2007 1:41 pm
on winbox try to go to Tool/bandwidth test
for simple one, use ECMP, gateway check, you can find it in ip/route
Chupaka
Sun Nov 18, 2007 3:19 pm
there's windows client/server in downloads section
it is failover, not load-balancing
Users browsing this forum: sindy and 50 guests
