hi
my routerOS(having laadbalancer PCC with two WANs) .
When I do the traceroute, I observe the request is passing through BOTH the IPS's Gateways every time!
for every connection request isn't it supposed to pass through only one ISP for each request !!
here is the output i observed.
USER-MG:~$ traceroute google.com
traceroute to google.com (142.250.196.46), 30 hops max, 60 byte packets
1 _gateway (192.168.1.1) 7.657 ms 7.623 ms 7.609 ms
2 gw (103.211.39.1) 7.603 ms 7.591 ms 7.578 ms
3 * broadband.actcorp.in (183.83.249.10) 21.240 ms *
4 broadband.actcorp.in (183.82.14.78) 21.224 ms 21.211 ms 103.10.134.157 (103.10.134.157) 7.503 ms
5 72.14.203.80 (72.14.203.80) 21.206 ms 21.195 ms 72.14.223.26 (72.14.223.26) 21.148 ms
6 * * *
7 maa03s45-in-f14.1e100.net (142.250.196.46) 17.342 ms 142.251.55.232 (142.251.55.232) 17.301 ms 142.251.49.218 (142.251.49.218) 19.971 ms
traceroute to google.com (142.250.193.142), 30 hops max, 60 byte packets
1 _gateway (192.168.1.1) 7.713 ms 7.672 ms 7.657 ms
2 183.82.96.1.actcorp.in (183.82.96.1) 8.521 ms login.bharatfiber.net (103.211.39.1) 7.734 ms 183.82.96.1.actcorp.in (183.82.96.1) 8.498 ms
3 broadband.actcorp.in (183.83.249.10) 8.513 ms 8.500 ms 103.211.36.29 (103.211.36.29) 7.598 ms
4 103.10.134.157 (103.10.134.157) 7.573 ms broadband.actcorp.in (183.82.14.78) 21.077 ms 103.10.134.157 (103.10.134.157) 7.551 ms
5 72.14.223.26 (72.14.223.26) 21.056 ms 72.14.203.80 (72.14.203.80) 21.075 ms 21.064 ms
6 * * *
7 209.85.248.210 (209.85.248.210) 18.246 ms 142.251.55.68 (142.251.55.68) 18.234 ms 142.251.55.30 (142.251.55.30) 18.223 ms
8 108.170.253.122 (108.170.253.122) 18.207 ms 108.170.253.120 (108.170.253.120) 18.199 ms 21.909 ms
9 74.125.242.129 (74.125.242.129) 21.713 ms 21.699 ms maa05s25-in-f14.1e100.net (142.250.193.142) 21.685 ms
USER-MG:~$
can someone explain to me how the routing is served?
or is there any configuration change I need to make?
