I need two switches that support VLANs, connected with 10Gb optical trunk. Currently I'm deciding between CRS312-4C+8XG-RM and CRS309-1G-8S+IN from Mikrotik, or TL-SX3008F from TPLink.
For Mikrotik CRS3xx switches I'm not certain IF and WHERE their difference in "bridging" speed as compared to "switching" speed would be applicable to my use scenario (where I only need VLANs, no need for advanced filtering rules etc). For example:
1) if PC connected to switch#1 is communicating to PC connected to switch#2, and both PCs are in same VLAN ( and I do not need filtering etc), will both switches consider that communication as "switching"?
2) is adding VLAN tags to ethernet packets sent by PCs considered basic "sweitching" feature, and does not require CPU and/or "bridging"?
3) are ports in Mikrotik CRS3xx switches by default set to "switching"? Ie, if I just unpack two of them and connect in above scenarion, will 2 PCs communicate at "switching" speeds?
4) what useful features require bridging?
5) is conversion from switching to bridging visible on Mikrotik OS ( requires user setup/configuration) or is it silently done if/when some feature that need bridging is turned on ?
Reason for these questions is that I need 10Gb connection between clients on one switch and servers on other switch, for different VLANs. And I noticed that both CRS312 and CRS309 offer same "switching" speed (and backplane speed to match 10Gbe per each port), but CRS309 is much faster for "bridging" speed (which is still far under 10Gbe). So main question is if I can avoid bridging completely while still having VLANs.
Tnx,
