This is the config:
Code: Select all
/tool romon
set enabled=yes id=00:00:00:00:00:00
/tool romon port
set [ find default=yes ] cost=100 disabled=no forbid=no interface=all
However, three routers are the same. Not sure why. I can set ID manually, but not sure to what to default?
What MAC adres should be set as ROMON ID?
EDIT: When I just enable ROMON like this, it assigns an unique MAC to each router and I don't touch it afterwards. Not sure what to do now.
