chris84
Loadbalancing with two different Gateways
Mon Nov 19, 2007 3:53 pm
I have two wan-internet uplinks from different isp's, what I'm trying to do is a combination of failover and per traffic load balancing.
common services like http, ftp, skype, mail, etc. should be routet over the first line and e.g. p2p over the second one, if one line fails everything should flow over the other one.
Is this possible with ros?
regards,
chris
galaxynet
Long time Member
Long time Member
Re: Loadbalancing with two different Gateways
Mon Nov 19, 2007 4:47 pm
chris84 -
Check out these links at the wiki: http://wiki.mikrotik.com/wiki/Routing
You would most likely use the multiple gateway with persistent sessions....
Thom Lawless
General Manager
RapidWiFi, LLC
thom.lawless [at] rapidwifi.com
Tanker
Wed Nov 21, 2007 1:56 pm
...... hi there
We got it all working - only to discover that Port 443 won't work....
We're still a little "cat-foot" at the moment (live network) - but if you come up with a solution please let me know...
Lots of irritated Banking Clients..!!!!!
galaxynet
Long time Member
Long time Member
Wed Nov 21, 2007 2:09 pm
Tanker -
I have not had an issue w/ https (port 443) when using persistant session connection marking. Let's see your setup and maybe we can figure out where you went wrong... :)
Thom
Thom Lawless
General Manager
RapidWiFi, LLC
galaxynet
Long time Member
Long time Member
Wed Nov 21, 2007 3:24 pm
Tanker -
From an earlier post on the forum....it is talking about improved persitant ECMP wiki setup.
add the following line before the (2) odd rules:
/ip firewall mangle chain=prerouting action=mark-connection new-connection-mark=odd passthrough=yes connection-state=new in-interface=Local dst-port=443 protocol=tcp comment="HTTPS" disabled=no
Thom Lawless
General Manager
RapidWiFi, LLC
Users browsing this forum: 0ldy0ne, Baidu [Spider], Google [Bot], johnson73, phiro, sindy, Tekkie123 and 223 guests
