Hi.
Does Mikrotik not have support for configuring wireless on the wifiwave2 package? Provisions fail as we were using `Device.WiFi` which no longer is being reported to the ACS.
ROS: 7.11.2
Sigh...there always somethingHello,
Thank you for contacting MikroTik Support.
Unfortunately, yes, it is a known issue. We will try to add support for WifiWave2 interfaces in future versions.
Sorry for the inconvenience.
