antiloop
Script to reboot router daily.
Mon Nov 19, 2007 10:08 pm
Hi there
I got a rb109 i think.(Old routerboard, got a com port for null modem cable) and the OS its running is 2.9.40
I would like the router to reboot every night at 12h10pm.
Can someone please assist with a script.
I am quite a novice with this and know i will have to use the scheduler to execute the script and would like some tips on setting it up.
Thanks in Advance.
Letni
Re: Script to reboot router daily.
Tue Nov 20, 2007 2:27 am
Try this.
/ system scheduler add name="Reboot Router Daily" on-event="/system reboot" start-date=jan/01/1970 start-time=00:10:00 interval=1d comment="" disabled=no
antiloop
Wed Nov 21, 2007 12:52 am
WONDERFUL :D
Worked liked a charm.
Thanks.
dingsingo
Fri Dec 28, 2007 4:38 pm
Try this.
it work's in RC3.0, too??
Dingsingo
cieplik206
Trainer
Trainer
Fri Mar 21, 2008 3:28 pm
yup it does work... just tested it in 3.6
https://www.wispcasts.com - Mikrotik Video Tutorials.
The best place where you can improve your skills!
Facebook - F/wispcasts
Twitter - @wispcasts
rgraham
Fri Mar 21, 2008 6:43 pm
Why?
Randy
eebng_1422
Sun Mar 23, 2008 3:22 am
Very good, but i want to ask you if that work with any MT os and i want to do another script to disconnect non-payed users from my hotspot
:lol:
Ahmed Bakhiet
skype Name: abakhiet
Mob: +2/0108944553
Move 2 Improve
moazdabsheh
Mon May 12, 2014 2:41 am
worked very well with Router OS 5.26 :)
chechito
Tue Sep 01, 2015 2:20 am
works on 6.30.2 :lol:
wichets
Tue Jan 30, 2018 2:31 am
Try this.
Work.. :D Very good..Thx
crowdedtent
Thu Jul 04, 2019 10:36 am
Try this.
Many thanks @Letni, worked like a charm!
Jotne
Fri Jul 05, 2019 3:47 pm
If you need to reboot every day some thing are wrong.
Try to fix the problem, not just the symptoms.
Why do not use Splunk to monitor your MikroTik Router(s)? Look at this page in how to set it up.
MikroTik->Splunk
kilokilo
Thu Apr 23, 2020 9:38 am
work with 6.46.5 hap lite
if the wifi on hap lite works well, i don't have to reboot it everyday.... :(
however the problem happened and reboot solve the problem....
Users browsing this forum: No registered users and 16 guests
