After upgrading my two Wap LR8 to 7.11.2, I installed IoT package and removed the lora package.
Now Lora does not start by default and the LoRa network is forgotten by default.
Is there a way to netinstall Wap LR8 with correct settings so that LoRa starts by default.
There was no communication from Mikrotik and no fix was provided (I did not check beta though)
I have a feeling that LoRa users are not taken seriously, which is especially a problem with LoRa which sometimes has distant installation.
One of my Lora Wap LR8 is 120 km away from home and I cannot drive there without being sure what to do.
I have around 10 x Mikrotik devices and I was never really able to netinstall them under 7.x, just under 6.4.
I have been a Linux user since year 1998 so don't blame me not to use Microsoft.
At present my netinstall script is:
Code: Select all
#!/bin/bash
IFNAME=enp0s31f6
systemctl stop firewalld
/sbin/ip addr replace 192.168.88.2/24 dev $IFNAME
/sbin/ip link set dev $IFNAME up
./netinstall -r -a 192.168.88.1 routeros-arm-6.49.10.npk
But there is not serial on the Wap LR8.
I connect to a small dumb unmanaged switch, no other software is running on network.
Therefore any information is welcome how to fix the Wap LR8.
Kind regards,
French Fries
