Does anybody know what is the type of plug (and it's orientation) to be used with the side 2-pin power connector of the RB5009UG+S+IN ?
The manual (https://help.mikrotik.com/docs/pages/vi ... d=78086262) does not mention it:
The device accepts power from the power jack or from the first Ethernet port:
Direct-input power jack (5.5 mm outside and 2 mm inside, female, pin positive plug) accepts 24-57 V DC.
The First Ethernet port accepts Power over Ethernet 24-57 V DC.
Apparently something's missing here.
Thanks in advance,
