filipebezerra
Function Find Log doesn't work properly on v7.x
Sat Sep 30, 2023 3:34 pm
I'm making a script to find for a specific log line. I use this line on version 6.48 and works fine, but the same command on version 7.10 returns all logs, not only the last five minutes.
/log find where time > ([/system clock get time] - 5m) message~"blocktv"
Any clue?
filipebezerra
Re: Function Find Log doesn't work properly on v7.x  [SOLVED]
Sat Sep 30, 2023 5:47 pm
Ok, for anyone who's having the same trouble, just use:
/log/find where time > ([/system/clock/get time] - 5m) message~"blocktv"
Worked for me.
nediis
Mon Oct 02, 2023 11:56 am
in version 7.11.2 it works correctly
rextended
Mon Oct 02, 2023 12:04 pm
If you try the script around midnight it doesn't work...
For example, if the clock is 00:02:00, subtracting 5 minutes gives -00:03:00 and "-3 minutes" does not exist in the log...
Removing or adding the "/" had no effect, it's just that time has passed...
The approach is totally wrong and ridiculous, without thinking about the fact that in the logs there are 4 different types of dates, some without even the time.
It would be enough to read what already exists on the forum without having to rewrite the same bulls–t all over again.
Users browsing this forum: No registered users and 5 guests
