Hi. I fixed that issue.
Traffic still arrives at Unit 4. (it now looks like this)
[admin@unit4] /routing/filter/rule> /export
# 2023-10-02 18:41:30 by RouterOS 7.11.2
# software id = JBWK-JPLI
# model = CCR2004-16G-2S+
# serial number = HD5083A5RPK
add name=loopback0
/port
set 0 name=serial0
set 1 name=serial1
/routing id
add disabled=no id=10.10.240.4 name=Ospf select-dynamic-id=""
/routing ospf instance
add disabled=no name=backbone originate-default=always router-id=10.10.240.4 routing-table=main
/routing ospf area
add disabled=no instance=backbone name=default
set discover-interface-list=none
add address=10.10.90.254/24 interface=ether15 network=10.10.90.0
add address=10.88.88.2/30 interface=ether1 network=10.88.88.0
add address=10.88.85.2/30 interface=ether2 network=10.88.85.0
add address=10.10.240.4 interface=loopback0 network=10.10.240.4
set servers=8.8.8.8
add check-gateway=ping disabled=no distance=1 dst-address=0.0.0.0/0 gateway=10.10.90.1 pref-src="" routing-table=main scope=10 suppress-hw-offload=no target-scope=11
/routing ospf interface-template
add area=default disabled=no interfaces=ether1,ether2 type=ptp
add area=default disabled=no interfaces=loopback0
/system clock
set time-zone-name=Europe/Stockholm
/system identity
set name=unit4
/system note
set show-at-login=no
/tool romon
set enabled=yes
route like this
[admin@unit4] /routing/filter/rule> /routing/route/print
Flags: A - ACTIVE; c - CONNECT, s - STATIC, o - OSPF; H - HW-OFFLOADED
Columns: DST-ADDRESS, GATEWAY, AFI, DISTANCE, SCOPE, TARGET-SCOPE, IMMEDIATE-GW
DST-ADDRESS GATEWAY AFI DISTANCE SCOPE TARGET-SCOPE IMMEDIATE-GW
As 0.0.0.0/0 10.10.90.1 ip4 1 10 11 10.10.90.1%ether15
Ao 10.0.6.0/30 10.88.88.1%ether1 ip4 110 20 10 10.88.88.1%ether1
Ao 10.0.7.0/30 10.88.88.1%ether1 ip4 110 20 10 10.88.88.1%ether1
Ao 10.10.7.0/30 10.88.88.1%ether1 ip4 110 20 10 10.88.88.1%ether1
Ac 10.10.90.0/24 ether15 ip4 0 10 ether15
Ao 10.10.220.109/32 10.88.88.1%ether1 ip4 110 20 10 10.88.88.1%ether1
Ao 10.10.220.110/32 10.88.88.1%ether1 ip4 110 20 10 10.88.88.1%ether1
Ao 10.10.221.102/32 10.88.85.1%ether2 ip4 110 20 10 10.88.85.1%ether2
Ao 10.10.221.103/32 10.88.85.1%ether2 ip4 110 20 10 10.88.85.1%ether2
Ao 10.10.221.104/32 10.88.85.1%ether2 ip4 110 20 10 10.88.85.1%ether2
Ao 10.10.221.105/32 10.88.85.1%ether2 ip4 110 20 10 10.88.85.1%ether2
Ao 10.10.221.107/32 10.88.85.1%ether2 ip4 110 20 10 10.88.85.1%ether2
Ao 10.10.240.2/32 10.88.85.1%ether2 ip4 110 20 10 10.88.85.1%ether2
Ao 10.10.240.3/32 10.88.85.1%ether2 ip4 110 20 10 10.88.85.1%ether2
Ac 10.10.240.4/32 loopback0 ip4 0 10 loopback0
Ao 10.10.240.5/32 10.88.88.1%ether1 ip4 110 20 10 10.88.88.1%ether1
Ac 10.88.85.0/30 ether2 ip4 0 10 ether2
Ao 10.88.86.0/30 10.88.85.1%ether2 ip4 110 20 10 10.88.85.1%ether2
Ao 10.88.87.0/30 10.88.85.1%ether2 ip4 110 20 10 10.88.85.1%ether2
Ac 10.88.88.0/30 ether1 ip4 0 10 ether1
Ao 10.99.12.0/30 10.88.88.1%ether1 ip4 110 20 10 10.88.88.1%ether1
Ao 10.102.1.0/30 10.88.85.1%ether2 ip4 110 20 10 10.88.85.1%ether2
Ao 10.103.3.0/30 10.88.85.1%ether2 ip4 110 20 10 10.88.85.1%ether2
Ao 10.104.3.0/30 10.88.85.1%ether2 ip4 110 20 10 10.88.85.1%ether2
Ao 10.105.3.0/30 10.88.85.1%ether2 ip4 110 20 10 10.88.85.1%ether2
Ao 10.105.5.0/30 10.88.85.1%ether2 ip4 110 20 10 10.88.85.1%ether2
Ao 10.106.3.0/30 10.88.85.1%ether2 ip4 110 20 10 10.88.85.1%ether2
Ao 10.107.3.0/30 10.88.85.1%ether2 ip4 110 20 10 10.88.85.1%ether2
Ao 10.111.111.0/30 10.88.88.1%ether1 ip4 110 20 10 10.88.88.1%ether1
Ao 10.193.193.0/29 10.88.85.1%ether2 ip4 110 20 10 10.88.85.1%ether2
Ao 10.222.222.0/30 10.88.85.1%ether2 ip4 110 20 10 10.88.85.1%ether2
Ao 10.223.223.0/30 10.88.85.1%ether2 ip4 110 20 10 10.88.85.1%ether2
Ac fe80::%ether1/64 ether1 ip6 0 10 ether1
Ac fe80::%ether2/64 ether2 ip6 0 10 ether2
Ac fe80::%ether10/64 ether10 ip6 0 10 ether10
Ac fe80::%ether15/64 ether15 ip6 0 10 ether15
Ac fe80::%loopback0/64 loopback0 ip6 0 10 loopback0
A H ether1 link 0
A H ether2 link 0
A H ether10 link 0
A H ether15 link 0
A H loopback0 link 0
If I traceroute directly
Columns: ADDRESS, LOSS, SENT, LAST, AVG, BEST, WORST, STD-DEV
# ADDRESS LOSS SENT LAST AVG BEST WORST STD-DEV
1 10.10.90.1 0% 8 0.1ms 0.1 0.1 0.1 0
2 82.183.39.xxx 0% 8 0.6ms 1.7 0.4 10.5 3.3
3 89.253.100.240 0% 8 0.9ms 0.7 0.5 0.9 0.1
4 148.122.8.241 0% 8 0.8ms 0.8 0.6 0.9 0.1
5 148.122.10.194 0% 8 5.5ms 4 1.6 8.5 2.5
6 1.1.1.1 0% 8 1ms 1.1 1 1.2 0.1
if I trace route from loopback
A H ether1 link 0
A H ether2 link 0
A H ether10 link 0
A H ether15 link 0
