doctor12th
Mini PC with 2x 10G
Mon Oct 02, 2023 3:02 pm
Can somebody suggest me a mini PC that can support PPPOE 10G at full speed?
I Need 2x 10g ports and some 1gbit ports
gigabyte091
Re: Mini PC with 2x 10G
Tue Oct 03, 2023 7:48 am
Closest I was able to find is this: https://www.cnx-software.com/2022/12/08 ... etworking/
It have 3×2.5Gig ports and 2×10Gig sfp ports but for supporting PPPoE at full speed you will have to wait somebody more knowledgeable.
Or this: https://www.amazon.com/MOGINSOK-Firewal ... B0C7L174KM
Core i7 should be capable of doing that...
doctor12th
Wed Oct 04, 2023 9:01 am
What do you think about https://mikrotik.com/product/crs310_8g_2s_in ?Does it support full speed pppoe 10g ?
I checked also https://mikrotik.com/product/ccr2004_16g_2s_pc
gigabyte091
Wed Oct 04, 2023 9:13 am
First one is more of a switch instead of the router so i don't think so...
For the second one I don't know, you will have to wait for someone more knowledgeable.
grusu
Tue Oct 10, 2023 8:24 am
mada3k
Long time Member
Long time Member
Tue Oct 10, 2023 6:33 pm
Some Supermicro board with 2x10G ports.
DeviceLocksmith
Wed Oct 11, 2023 12:08 pm
You'll want a CPU with higher clock rate or network card with hardware acceleration. 10Gbps line speed does not leave a lot of CPU cycles do useful things with packets.
emunt6
Mon Nov 06, 2023 9:58 pm
PPPOE is CPU intensive task, if you get rid of the PPPOE you have plenty options.
Mikrotik doesn't have hardware like you requested, look the CISCO ASR line ( example: CISCO ASR9901 ), another option - you can buy cheaper used cisco on ebay (example: CISCO ASR1004 or CISCO ASR1006 ) that can do it.
normis
Tue Nov 07, 2023 4:12 pm
Are you looking for PC, router, switch or PCI-e interface card? Original post is not clear
Beone
Trainer
Trainer
Sat Nov 18, 2023 12:23 am
as of today, none of the Mikrotik hardware devices are capable of doing 10Gbit/s PPPoE.
There is SUP-128496 with the request if this would be possible to have PPP(oE) hardware accelerated to reach 10Gbit/s
iustin
Tue Nov 28, 2023 12:11 am
Not quite 10Gbps, since I think upstream doesn't support it, but I can hit ~6Gbps on a HP Microserver Gen 10 Plus, with Intel DA710-X2 add-on card for the SFP+ ports.
Users browsing this forum: phascogale and 4 guests
