Irelk
TV authentication timeout on wifi
Mon Oct 02, 2023 5:43 pm
Hello guys.
I'm having trouble connecting my TV(TCL 65C835) to the MikroTik hAP ax2 Wi-Fi network with auth. settings WPA2 PSK, WPA3 PSK.
It's displaying this message from LOG mentioned below:
 13:57:47 wireless,debug xx:xx:xx:xx:xx:xx@wifi2 authentication timeout
 13:57:54 wireless,debug xx:xx:xx:xx:xx:xx@wifi2 authentication timeout
 13:58:08 wireless,debug xx:xx:xx:xx:xx:xx@wifi2 authentication timeout
 13:58:17 wireless,debug xx:xx:xx:xx:xx:xx@wifi2 authentication timeout
 13:58:30 wireless,debug xx:xx:xx:xx:xx:xx@wifi2 authentication timeout
 13:58:50 wireless,debug xx:xx:xx:xx:xx:xx@wifi2 authentication timeout
 13:59:09 wireless,debug xx:xx:xx:xx:xx:xx@wifi2 authentication timeout
 13:59:28 wireless,debug xx:xx:xx:xx:xx:xx@wifi2 authentication timeout
 13:59:48 wireless,debug xx:xx:xx:xx:xx:xx@wifi2 authentication timeout
 14:00:07 wireless,debug xx:xx:xx:xx:xx:xx@wifi2 authentication timeout
 14:00:25 system,info,account user xxxxx logged in from 192.168.88.254 via local
 14:00:26 wireless,debug xx:xx:xx:xx:xx:xx@wifi2 authentication timeout
Mikrotik config:
# 2023-10-02 14:05:07 by RouterOS 7.11.2
# software id = **ELIDED**
# model = C52iG-5HaxD2HaxD
# serial number = **ELIDED**
add name=bridge-VLAN10 vlan-filtering=yes
add name=local
/interface wifiwave2
set [ find default-name=wifi1 ] channel.band=5ghz-ax .skip-dfs-channels=\
    10min-cac .width=20mhz configuration.country=Czech .mode=ap .ssid=\
    "Pila IoT" security.authentication-types=wpa2-psk,wpa3-psk
set [ find default-name=wifi2 ] channel.band=2ghz-ax .skip-dfs-channels=\
    "Pila AP" .tx-power=17 datapath.client-isolation=no disabled=no \
add name=listBridge
/interface wifiwave2 security
add authentication-types=wpa2-psk,wpa3-psk disabled=no name=VLAN10-remote
add configuration.mode=ap .ssid="Pila remote" datapath.client-isolation=no \
    .vlan-id=10 disabled=no mac-address=**ELIDED** master-interface=\
    wifi2 name=Pila-remote-VLAN10 security=VLAN10-remote
/interface vlan
add interface=Pila-remote-VLAN10 name=vlan10 vlan-id=10
add name=dhcp_pool0 ranges=192.168.88.2-192.168.88.254
add name=dhcp_pool1 ranges=192.168.85.2-192.168.85.254
add name=dhcp_pool2 ranges=\
    192.168.10.1-192.168.10.9,192.168.10.11-192.168.10.254
add address-pool=dhcp_pool0 interface=local lease-time=10m name=dhcp1
add address-pool=dhcp_pool2 interface=bridge-VLAN10 name=dhcp2
add bridge=local interface=ether2
add bridge=local interface=wifi2
add bridge=local interface=ether3
add bridge=local interface=wifi1
add bridge=bridge-VLAN10 interface=Pila-remote-VLAN10
add bridge=bridge-VLAN10 interface=vlan10
add bridge=local interface=ether5
set discover-interface-list=listBridge
/ipv6 settings
set max-neighbor-entries=15360
add interface=local list=listBridge
add address=192.168.88.1/24 interface=local network=192.168.88.0
add address=192.168.10.10/24 interface=bridge-VLAN10 network=192.168.10.0
/ip dhcp-client
add interface=ether1
/ip dhcp-server lease
add address=192.168.88.50 client-id=**ELIDED** mac-address=**ELIDED** server=dhcp1
add address=192.168.10.0/24 gateway=192.168.10.10
add address=192.168.88.0/24 dns-server=8.8.8.8 gateway=192.168.88.1
add action=accept chain=input comment="accept established, related" \
add action=drop chain=input connection-state=invalid
add action=accept chain=input comment="allow ICMP" in-interface=ether1 \
    protocol=icmp
add action=accept chain=input comment="allow Winbox" in-interface=ether1 \
    port=8291 protocol=tcp
add action=accept chain=input comment="allow SSH" in-interface=ether1 port=22 \
    protocol=tcp
add action=drop chain=input comment="block everything else" in-interface=\
    ether1
/ip service
set telnet disabled=yes
set ftp disabled=yes
set www disabled=yes
set ssh port=2200
set api disabled=yes
set winbox address=192.168.88.0/24
set api-ssl disabled=yes
/ip ssh
set strong-crypto=yes
/system clock
set time-zone-name=Europe/Prague
/system logging
add topics=wireless,debug
/system note
set show-at-login=no
/tool bandwidth-server
set enabled=no
/tool mac-server
set allowed-interface-list=listBridge
/tool mac-server mac-winbox
/tool mac-server ping
set enabled=no
Don't you have any advice what can be wrong? The TV have WiFi Built-in ax/ac/n 2.4/5Ghz
Thank you very much for your assistance.
Reason: elided PII; fixed code block formatting
memelchenkov
Re: TV authentication timeout on wifi
Mon Oct 02, 2023 6:40 pm
Check signal strength.
gigabyte091
Mon Oct 02, 2023 7:18 pm
For testing purposes disable WPA3 if possible
Irelk
Mon Oct 02, 2023 10:04 pm
It seems that disabling WPA3 will figure it out. For now TV is connected so we will see a test by kids tommorow. :D Thank you.
I hoped that i will be running on WPA3 PSK. :(
Moba
Tue Oct 03, 2023 4:55 am
Many devices do not yet support WPA3. As a home user, you do not need to worry. There is nothing broken with WPA2, unlike WPA.
gigabyte091
Tue Oct 03, 2023 5:47 am
For IoT devices you can create separate VLAN network and SSID with WPA2 only network.
Irelk
Tue Oct 03, 2023 9:05 pm
Thats my new step, what im trying for now. If you can look at the config i maked VLAN wifi "pila remote" for home office work, but i dont know if its correct. I cant ping cross networks so i think its working. But i have been studying it for a week and still not comfortable and convinced that im doing it right. :D
Im planning to make it look like this:
VLAN 10 - 192.168.10.0 - WiFi for phones
VLAN 20 - 192.168.20.0 - WiFi for work notebook homeoffice
VLAN 30 - 192.168.30.0 - WiFi IoT - vacuum, washing machine, TV(i dont know if should TV put there)
VLAN 40 - 192.168.40.0 - kids room cam, the problem is that cam need to be connected to network for i can use it on my and wife phones, if i cut the internet, it will only work in main app for me, so still idk how to figure it out, the cam without power over day, its only for night, if everythink is ok when they are sleeping. I will start looking for some cam that dont need to be in some 3rd party cloud.
VLAN 50 - 192168.50.0 - ETH2 - my computer
VLAN 60 - 192.168.60.0 - ETH3 - wife gaming PC
What i saw, there is several method to make "VLANs". But i cant still find the right guidance for me. :)
gigabyte091
Tue Oct 03, 2023 9:28 pm
Why so many VLANs ?? I would put phones and your and your wife's PC in same VLAN or are you trying to say that you don't trust your wife ?? :lol: :lol:
Kids camera in the same VLAN as your IoT devices, office stuff can go in separate VLAN.
I can recommend you VLAN guide from pcunite so you became familiar with VLANs and anav have great tutorial.
pcunite guide:
viewtopic.php?t=143620
anav guide:
viewtopic.php?t=182373
And don't use two bridges... only one bridge is needed...
add name=loca
Irelk
Wed Oct 04, 2023 8:30 pm
More secured. :D Yep, i definitely need to separate her computer.
Ok, thank you for recommendations. I will take a look and will put a feedback, how im doing. :) 8)
gigabyte091
Wed Oct 04, 2023 8:53 pm
You know, my colleague once said to me... but why so much security ? Are you running a bank ? :lol: :lol: :lol:
Irelk
Tue Oct 17, 2023 11:31 am
No, im not, but i like it. :D Im starting to reading the guide what u reffered. I would like to prepare it like this. What you think about that? For the VLAN40 i will enable client isolation. The WIFE PC i want it to be separated if she donwload some malware, but i think that i can put it to VLAN 10 and make isolation too? Hard to decide without experience for me. Thank for your tips. :). Sorry for ugly diagram.
Stibila
Tue Apr 09, 2024 4:11 pm
I have similar problem and it seems to be connected to SAE Anti Clogging Threshold. more here viewtopic.php?p=1068685#p1068685
Users browsing this forum: anav, infabo, thefriendlyguy and 29 guests
