minfrin
RouterOS 7.11.2 bricks CAP ac after routine update
Fri Oct 06, 2023 8:03 pm
Hi all,
Routine upgrade of a CAP ac:
  MMM      MMM       KKK                          TTTTTTTTTTT      KKK
  MMMM    MMMM       KKK                          TTTTTTTTTTT      KKK
  MMM MMMM MMM  III  KKK  KKK  RRRRRR     OOOOOO      TTT     III  KKK  KKK
  MMM  MM  MMM  III  KKKKK     RRR  RRR  OOO  OOO     TTT     III  KKKKK
  MMM      MMM  III  KKK KKK   RRRRRR    OOO  OOO     TTT     III  KKK KKK
  MMM      MMM  III  KKK  KKK  RRR  RRR   OOOOOO      TTT     III  KKK  KKK
  MikroTik RouterOS 7.8 (c) 1999-2023       https://www.mikrotik.com/
Press F1 for help
[mnfrin@bellrock.xxx] /system/package/update> check-for-updates        channel: stable
[minfrin@bellrock.xxx] /system/package/update> download
            channel: stable
  installed-version: 7.8
     latest-version: 7.11.2
             status: Downloaded, please reboot router to upgrade it
[minfrin@bellrock.xxx] /system/package/update> /system/reboot
Reboot, yes? [y/N]:
y
system will reboot shortly
Received disconnect from UNKNOWN port 65535:11: shutdown/reboot
Disconnected from UNKNOWN port 65535
45 minutes later ethernet is still down and the CAP ac is nowhere to be seen.
Is v7.11.2 a dud for anyone else?
Regards,
Graham
robertoss
Re: RouterOS 7.11.2 bricks CAP ac after routine update
Thu Oct 26, 2023 10:41 pm
Hi, same problem with 4 hAP mini that we use in class with students, other 3 of the same batch updated without problem. Just after the update they stay in loop, can not be found in winbox nor am I able to restore with netinstall, they keep restarting continuously.
Were you able to solve your problem? Any help or suggestions are welcome.
Salu2
inteq
Mon Oct 30, 2023 6:11 pm
The only time I've managed to brick a CAP was when the CAP was powered via PoE from a Mikrotik 4011 router.
Updated RoS on router and CAP, but restarted the router while the CAP was updating the firmware.
No PoE from router to CAP while updating = bricked CAP.
Managed to recover via netinstall.
Lesson learned.
gotsprings
Fri Nov 10, 2023 1:33 pm
Bricked a hAP AC2 during update.
Integrator plugged it into a Wattbox from SNAP AV. Left auto reboot on.
It was the loss of Power during update reboot, that Killed it.
Users browsing this forum: No registered users and 5 guests
