I have the dude setup on a CHR. It has been setup for years.
I found I have two MIB folders. One is dude/files/default/mibs and the other is dude/files/mibs.
I can delete files from the dude/files/mibs folder and mibs I place in the folder show up as mibs in The Dude.
The other folder has some outdated MIBS I need to remove but when I try to remove the file I get "couldn't remove file - action failed (6)"
Why can I not remove these files?
I need to remove them as they are conflicting with other mibs in the othe directory.
