Mon Oct 30, 2023 10:42 pm
I installed router os on my hypervisor virtually and did the speed tests. They were looking ok. I installed a connectx-4 and ran iperf from a my terminal workstation to my server and I got 5gbps. It seems that the switch is ok but again running ookla speed test, the upload speed is greatly affected. I have tried using flow control, but I get into the same issue.
I have identified that the switch has some trouble communicating with bell home hub router.
When I put a pfsense box with intel i350 in between the switch and the ISP bell home hub router the speed increases to 250 Mbps but there is a lot jitter when using remote desktop.
