Hello!
Bought a hEX S and was expecting the process to be a bit smoother (am on linux, Ubuntu).
Haven't managed to connect to it so far. I've tried "upgrading" via the CLI tool and the routeros-mmips-7.11.2.npk ....
...and after setting manually the IPv4 self IP (+mask) it actually worked....however this was successful when on Port1 ....when pinging the device... (192.168.88.1) it didn't respond....however
when swapping to Port2 ....the device did respond...so there is a connection. Attempting to access via a browser (which I tried at the very start) still doesn't work.
Why is this so hard..
Edit1: I want to set up this device to act as a DHCP server so I can then have the following setup:
Jetson Orin Nano <--> hEX S <--> PoE Switch <--> PoE cameras
