MUM Europe 2020
max0000
PROXY SERVER using Load Balancing over Multiple Gateways
Sat Nov 24, 2007 9:57 pm
I need to setup the proxy server to use both gateways is it possible? if yes please help
Ask not what you can do on your server Ask what your server can do for you
max0000
Re: PROXY SERVER using Load Balancing over Multiple Gateways
Wed Nov 28, 2007 5:12 pm
Is it a hard qustion or no help for new members :)
Chupaka
Thu Nov 29, 2007 3:20 am
what is your current config?
try adding default gw for 0.0.0.0 as "10.0.0.1, 10.0.0.2, <other gateways>" - it should work, excluding websites who control source IP address of client =)
Russian-speaking forum: https://forum.mikrotik.by/. Welcome!
For every complex problem, there is a solution that is simple, neat, and wrong.
MikroTik. Your life. Your routing.
sergejs
Fri Nov 30, 2007 3:02 pm
Unfortunately, it is not possible.
Chupaka
Sat Dec 01, 2007 1:17 pm
... but you may use two ROS =)
sergejs
Mon Dec 03, 2007 8:32 am
Yes, this is correct. So to precise it is not possible with one single router.
joylu
Mon Dec 03, 2007 10:31 am
i can do it . only need 50$ 8) mail:leoqin666@aol.com
t3rm
Mon Dec 03, 2007 8:43 pm
Use Proxy Server outside the mikrotik and make it Mikrotik as default gateway. From Mikrotik, you can have policy route or load balancing over multiple gateway as writen in Mikrotik Docs.
max0000
Fri Dec 07, 2007 10:25 pm
can you explain more? you saying to have external proxy i like the idea but i will need help with the routing settings maybe i can use (ipcop with advanced proxy it come with Update Accelerator for windows updates)
lets work on it if its possible.
karo84
Mon Dec 10, 2007 12:06 am
Hi everyone,
I have the same problem,
I need to setup web proxy and balancing with 3 Gateways,
I need it very much,
Can You help?
Now I am doing the setup, wivh is shown on wiki (load balanceing), But I need do the same with 3 or more Gateways
With Regard
Karapet Aznavuryan
t3rm
Mon Dec 10, 2007 3:10 pm
Yes, the external proxy would be Squid under Linux -> http://www.squid-cache.org
Its very recommended ..
8)
Users browsing this forum: MSN [Bot] and 66 guests
