Havent yet created the schematics, however for a basic settings following description should be enough.
Mikrotik router set to 192.168.11.1 ( C53UiG+5HPaxD2HPaxD )
pool set 192.168.11.2-192.168.11.99
I would like to use my pc/mac to reach the home LAN network remotely.
What are the most default settings for mikrotik and wireguard client.
A. Current cfg enclosed,
Code: Select all
# 2023-10-21 06:10:37 by RouterOS 7.11.2
# software id = YXRR-3U0P
# model = C53UiG+5HPaxD2HPaxD
# serial number = xy
add admin-mac=xy auto-mac=no comment=defconf name=bridge
/interface wifiwave2
set [ find default-name=wifi2 ] channel.band=2ghz-ax .width=20mhz \
configuration.mode=ap .ssid=xy2.4G datapath.bridge=bridge \
disabled=no name=xy2.4G security.authentication-types=\
wpa2-psk,wpa3-psk
set [ find default-name=wifi1 ] channel.band=5ghz-ax .skip-dfs-channels=\
10min-cac .width=20/40/80mhz configuration.mode=ap .ssid=\
xy5g disabled=no name=xy \
security.authentication-types=wpa2-psk,wpa3-psk
add configuration.mode=ap .ssid=IOT mac-address=4A:A9:8A:09:8A:26 \
master-interface=xy2.4G name=w_IOT
/interface wireguard
add comment=vpn_wg1 listen-port=13231 mtu=1420 name=wg1
add comment=defconf name=WAN
add comment=defconf name=LAN
/iot lora servers
add address=eu.mikrotik.thethings.industries down-port=1700 name=TTN-EU \
up-port=1700
add address=us.mikrotik.thethings.industries down-port=1700 name=TTN-US \
up-port=1700
add address=eu1.cloud.thethings.industries down-port=1700 name=\
"TTS Cloud (eu1)" up-port=1700
add address=nam1.cloud.thethings.industries down-port=1700 name=\
"TTS Cloud (nam1)" up-port=1700
add address=au1.cloud.thethings.industries down-port=1700 name=\
"TTS Cloud (au1)" up-port=1700
add address=eu1.cloud.thethings.network down-port=1700 name="TTN V3 (eu1)" \
up-port=1700
add address=nam1.cloud.thethings.network down-port=1700 name="TTN V3 (nam1)" \
up-port=1700
add address=au1.cloud.thethings.network down-port=1700 name="TTN V3 (au1)" \
up-port=1700
add name=dhcp ranges=192.168.11.10-192.168.11.99
add add-arp=yes address-pool=dhcp interface=bridge lease-time=10m name=\
defconf
/interface bridge filter
# no interface
add action=drop chain=forward in-interface=*9
# no interface
add action=drop chain=forward out-interface=*9
# no interface
add action=drop chain=forward in-interface=*A
# no interface
add action=drop chain=forward out-interface=*A
add bridge=bridge comment=defconf interface=xy5g
add bridge=bridge comment=defconf interface=xy2.4G
add bridge=bridge interface=*9
add bridge=bridge interface=*A
add interface=wg1 list=LAN
/interface wireguard peers
add comment=xy interface=wg1 public-key=\
"xy="
add address=192.168.11.1/24 comment=defconf interface=bridge network=\
192.168.11.0
add address=192.168.22.1/24 interface=wg1 network=192.168.22.0
/ip arp
add address=192.168.11.100 interface=bridge mac-address=xy
add address=192.168.11.2 interface=bridge mac-address=xyxy
/ip dhcp-client
/ip dhcp-server lease
add address=192.168.11.2 client-id=1:xyxy mac-address=\
xyxy server=defconf
add address=192.168.11.100 mac-address=xy
add address=192.168.11.0/24 comment=defconf dns-server=192.168.11.1 gateway=\
192.168.11.1 netmask=24
set allow-remote-requests=yes
/ip dns static
add address=192.168.11.1 comment=defconf name=router.lan
established,related,untracked
invalid
in-interface-list=!LAN
ipsec-policy=in,ipsec
ipsec-policy=out,ipsec
connection-state=invalid
add action=masquerade chain=srcnat disabled=yes out-interface=wg1 \
src-address=192.168.11.0/24
/ip firewall service-port
set ftp disabled=yes
set tftp disabled=yes
set sip disabled=yes
set pptp disabled=yes
/ip upnp
set enabled=yes
/ip upnp interfaces
add interface=bridge type=internal
add interface=ether1 type=external
/ipv6 firewall address-list
/ipv6 firewall filter
invalid
icmpv6
add action=accept chain=input comment="defconf: accept UDP traceroute" port=\
33434-33534 protocol=udp
udp src-address=fe80::/10
protocol=udp
ipsec-ah
ipsec-esp
!LAN
icmpv6
500,4500 protocol=udp
ipsec-ah
ipsec-esp
!LAN
/system clock
set time-zone-name=Europe/Budapest
/system note
set show-at-login=no
/system routerboard settings
set auto-upgrade=yes
/tool mac-server
/tool mac-server mac-winbox
Code: Select all
[quote][Interface]
PrivateKey = xy
Address = 192.168.11.101/24
[Peer]
PublicKey = xy
AllowedIPs = 0.0.0.0/0
Endpoint = xy:13231
[/quote]
