tafkamax
Use netinstall-cli from routeros 7 to install routeros 6 pkgs  Topic is solved
Thu Oct 26, 2023 1:47 pm
Can I use netinstall-cli to install routeros 6 pkgs ?
I have an use case where I have an hAP Lite that I want to test a setup on and I wanted to use netinstall. I downloaded the RouterOS 6 version of netinstall and I don't like that it doesn't allow me to define an interface.
Can I use an routeros 7 version of the netinstall-cli?
EDIT: Yes you can
sudo ./netinstall-cli -r -i enxd0374502a3ce ~/Downloads/mikrotik/hap-lite/routeros-smips-6.49.10.npk
Version: 7.11.2(2023-08-31 14:41:16)
Will reset to default config
Using Interface: enxd0374502a3ce
Wait for Link-UP on 'enxd0374502a3ce'. OK
Using Client IP: 192.168.88.3
Using Server IP: 192.168.88.2
Starting PXE server
Waiting for RouterBOARD...
client: 6C:3B:6B:42:XX:XX
Sending image: mips
sendFile 4896892
Discovered RouterBOARD...
Formatting...
Sending package routeros-smips-6.49.10.npk ...
Ready for reboot...
Users browsing this forum: No registered users and 6 guests
