Observations:
1. You have two subnets one for bridge and one for WLAN but you have them both on the bridge,
Therefore you need to change your approach. It would appear you need two vlans, one for home and wlan1 and wlan2
and one for wlan3 so to speak. If not keen on using vlans recommending you keep the bridge as is, and ensure you identify the WLAN3 as the second subnet.
EDIT: Exactly what you have done, excellent!!
2. Remove this entry....
/interface list members
add disabled=yes interface=*9 list=WAN
3. Your wireguard setting for peer are incorrect.................
/interface wireguard peers
add endpoint-address=192.168.7.10 interface=wg-server public-key=\
"Wl6x8diLwOibFRdjOU1ma3hSypeqiHXS5EeABFaVlio="
The format should be
add allowed-ips=192.168.7.10/32 etc................... ( not endpoint ).
Think about the logic why would you need to reach the endpoint of the client, this is the server device!
The function of allowed-ips for a peer in general is two-fold
a. to tell the wireguard code, the legitimate destination addresses for any traffic originating from users on the router heading outbound and entering the tunnel.
(if not listed, will not go)
b. to tell the wireguard code, the legitimate source addresses for any traffic originating remotely and inbound on the tunnel and wanting to exit the tunnel at the local device.
In your case its only B.
4. Stick the input chain rule as further down the line, not critical just no reason for it to be first.....
like here
add action=accept chain=input comment="Wireguard bej\F6v\F5" dst-port=15231 \
in-interface-list=WAN protocol=udp
in-interface-list=!LAN
5.
Security wise: Consider that you allow all the LAN full access to the router whereas it should only be you. The users need access to DNS services only.
SO recommend taking the single line in input chain {
in-interface-list=!LAN } and replacing it with the below:
/firewall address-list (using statically set leases)
add address=192.168.0.XX list=Authorized comment="admin PC"
add address=192.168.0.YY list=Authorized comment="admin wifi connection"
add address=192.168.7.10 list=Authorized comment=Remote admin wireguard"
add action=accept chain=input comment="LAN DNS" dst-port=53 in-interface-list=LAN protocol=udp
add action=accept chain=input comment="LAN DNS" dst-port=53 in-interface-list=LAN protocol=tcp
add action=drop chain=input comment="drop all else"
6. Similarly its much more efficient in the forward chain to remove this rule { "defconf: drop all from WAN not DSTNATed" connection-nat-state=!dstnat \
connection-state=new in-interface-list=WAN } remove the two drop rules you added and replace with the below.......
add action=accept chain=forward comment="allow internet traffic" in-interface-list=LAN out-interface-list=WAN
add action=accept chain=forward comment="allow port forwarding" connection-nat-state=dstnat
add action=drop chain=forward comment="drop all else"
7. ONLY need the single source nat rule! Remove the others.
8. Any reason why you really need upnp ??
Especially because that *9 error also incurs here!
9. Should be set to
NONE as the mac-server entry is not secure ( the mac-winbox method is secure )
/tool mac-server
set allowed-interface-list=
LAN
/tool mac-server mac-winbox
In summary the biggest issue was missing allowed IPs in wireguard settings.
