nopria
SIM insertion
Mon Nov 13, 2023 1:13 pm
I just unpacked a Mikrotik LHG LTE18, since I've read of problems about not-working SIMs stuck inside the slot, I stopped inserting the SIM as soon as I felt some resistance, in your experience is this the right position of SIM in slot?
I also cannot connect to 192.168.188.1, but I think that's a different issue...
Sertik
Re: SIM insertion
Mon Nov 13, 2023 9:42 pm
In Mikrotik you usually need to connect to 192.168.88.1 ...
nopria
Re: SIM insertion
Mon Nov 13, 2023 9:49 pm
The "Quick guide" I received says "188", not "88", I'll try 88 too...
rextended
Re: SIM insertion
Mon Nov 13, 2023 10:07 pm
A photo of that guide, please?
Amm0
Re: SIM insertion
Tue Nov 14, 2023 2:18 am
It same as online one, which uses .188 too: https://help.mikrotik.com/docs/pages/vi ... d=47579305
rextended
Re: SIM insertion
Tue Nov 14, 2023 12:52 pm
Is not a typo error (the wrong is the link: online text is .188. but the link is .88.).
Defconf now have 192.168.188 for LTE devices, so the guide is right... But only for RouterOS 7.12?...
lines extracted from 7.12 arm defconf code
:local ipNetwork "192.168.88";
  :if ($board->"model"~"SXT|EC25") do={
          :if (!($defconfLte="" || [:typeof $defconfLte]= "nothing") || $marketingName~"LTE") do={
            :set ipNetwork "192.168.188";
  :if ($board->"model"~"LDF") do={
    :if (!($defconfLte="" || [:typeof $defconfLte]= "nothing")) do={
  :if ($board->"model"~"LHG|Disc|nRAY|ATLGM|L00G") do={
Amm0
Re: SIM insertion
Tue Nov 14, 2023 4:02 pm
The guide also suggests https://... But unless you add a cert, it's just http://192.168.88.1 or http://192.168.188.1
Sertik
Re: SIM insertion
Wed Nov 15, 2023 12:14 pm
Well, we sorted out 88 and 188. Maybe the topicmaster doesn’t have an address on the interface at all?
Let him try to connect using the Mac address.
Users browsing this forum: AndHe and 9 guests
