srmed2000
Hide your MAC Address from hackers ??how how how please???
Thu Nov 29, 2007 2:24 am
How can I Hide my MAC Address from hackers and IP and username ...... ??????
I surprised that one HACKER gave me the names of users,MAC Address ,IP and IP mikroTik :(
How to defend myself ............Is there a solution?????
srmed2000
Re: Hide your MAC Address from hackers ??how how how please???
Thu Nov 29, 2007 3:56 pm
help meeeeeeeeeeeeeeeeeeee!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
fcwireless
Thu Nov 29, 2007 11:58 pm
go to system > shutdown
the hacker will be stopped in his tracks.
seriously though, might want to examine your internal network. Chances are he's got an inside connection and you're not configured right.
srmed2000
Fri Nov 30, 2007 12:36 am
i using hotspot mikrotik v2.9.27
and the hacker is know all the MAC address .... and can log by change MAC
How can i stop hacker........... please tel me
jacoblydon
Fri Nov 30, 2007 5:56 am
First of all how many clients are registered clients of yours. If you dont have any clients just disable the wireless card. Is this an option? Watch the registration find his MAC address, and make firewall rule to drop connection to that MAC. Let me know I will watch forum.
srmed2000
Fri Nov 30, 2007 10:13 am
give me filter rules
antefe
Fri Nov 30, 2007 1:06 pm
If he has all this info about your network, chances are that you've got more than one devices compromised in your network. Shut Down EVERYTHING, boot each pc in safe mode, and scan it with an antivirus. Once youve done that. You should change ALL the passwords of the PCs and Network Devices. About the firewall configuration you should block all the ports that aren't needed from the inside of your network (eg allow only 25,80,110,445)
jacoblydon
Fri Nov 30, 2007 4:45 pm
Try winbox>ip>firewall>add rule>chain=input>in>interface wlan1 or hotspot>advanced>mac of hacker>destination address=your device>action drop......... If this works then reset all passwords on devices, and MAC filter from here on out or User manager or WEP WAP or something.
srmed2000
Fri Nov 30, 2007 10:03 pm
Thank you ((jacoblydon)) for your reply to queries
Please .......... Explain in detail !!!!!!!!!!!!!
Winbox
Ip
firewall
Filter rules
add rule
chain=input
in.interface wlan1 or hotspot (?????)
advanced
MAK Address mak of hacker
action drop
jacoblydon
Sat Dec 01, 2007 5:58 am
Well I didn't know what interface your Hot spot, was on wlan1, or named Hotspot. If you have both do same firewall rule on all Wireless interfaces.. It was compromised through wireless interface right?
jacoblydon
Sat Dec 01, 2007 6:05 am
Winbox
Ip
firewall
Filter rules
add rule
chain=input
advanced
action drop
chain-input yes because data will be on, input coming (in) to your device, and the MAC of suspected hacker you put on the advanced page of ip>firewall>advanced the MAC you think is comprising your AP. Destination address is the address of your device that the hacker has taken advantage of. Action=drop... connection from this suspected device
jacoblydon
Sat Dec 01, 2007 6:06 am
Winbox
Ip
firewall
Filter rules
add rule
chain=input
advanced
action drop
chain-input yes because data will be on, input[/color] coming (in) to your device, and the MAC of suspected hacker you put on the advanced page of ip>firewall>advanced the MAC you think is comprising your AP. Destination address is the address of your device that the hacker has taken advantage of. Action=drop... connection from this suspected device
srmed2000
Sat Dec 01, 2007 1:18 pm
Thank you very :D ((jacoblydon)) for your reply to queries
1-Please saw pictures attached ... Are the settings correct???
2-I hope you tell me about The basic function of this rule ??and how to make sure it works properly
My Wi-Fi Network is like in the diagram -1- My server is MikroTik 2.9.27 I’m using HotSpot Authentication By Mac and HTTP CHAP and HTTP PAP, I create a user name for every client in my network.
jacoblydon
Sat Dec 01, 2007 10:45 pm
Yes that looks right to me.
jacoblydon
Sat Dec 01, 2007 10:48 pm
Is ether2, the port that has been compromised?
srmed2000
Sat Dec 01, 2007 11:33 pm
Yes
I Do that but no thing do !!!!!!!!!!!!!!!!!!!!!!
navibaghdad
Sun Dec 02, 2007 12:06 am
Dear Sarmed,
As I see ur problem is related to this controversy http://forum.mikrotik.com/viewtopic.php ... ck+hotspot and u can disable default forward from ur wireless card to isolate ur client.about the person he told u all this information about ur users and there MAC its very simple cause u can do that with a simple scan program and then change ur MAC address and use the service as we discuss in the link above
Regards,
jacoblydon
Sun Dec 02, 2007 8:23 pm
Yes
It should work, the firewall is correct. The rule is correct. You did it right. The basic function of the rule is to stop access from the MAC of suspected hacker you have probing your network. You should not see the MAC of hacker show up if the rule is working. It sounds like you need a Mikrotik consultant to come and help you.
normis
Mon Dec 03, 2007 11:20 am
also make sure you make a new router user for yourself, and then disable the default admin user. the new user has to be in the full permission group.
and of course - buy a license for your routeros ...
srmed2000
Mon Dec 03, 2007 5:36 pm
Is there scripts is linking the MAC Address with the name computer (Hostname)???????????????
Dragonmen
Tue Dec 04, 2007 10:03 am
If i'm right srmed2000 is using hotspot to authenticate wireless users via mac so hacker uses their mac to steal their internet.
Well, if that's the case, there's almost nothing you can do about these hacks becouse you can't differ ppl that is cloning mac address from regular ppl. Sure, you can use the rule above which will block the regular user as well, but hacker will surely have all macs from that AP and that rule may just annoy him but not stop him.
My advice is to use user/password for hotspot clients rather than mac login, at least for users of that AP. Other alternative is to change regular users mac but that may be problem and it will work for a short time.
You can use some equipment/packet sniffing/radiate source positioning to track him, and when you got him... you know what to do - that will make an example for others.
And btw, you should learn basics of the Mikrotik first.
rusellbernand
Mon Dec 22, 2014 2:14 pm
Yes! all the above said is good while hiding the MAC address through configuration settings. MAC access will be open to hackers when we allow them without any security settings. We can also be aware, first of all that our IP address are open to hackers for accessing the internal server details. I always prefer to hide my external IP address in order to take initiative at the beginning itself. I had used VPN software to hide the server IP and checked the IP address change through the website http://www.IP-Details.com/ and now it makes me alert regard unwanted IP access.
Users browsing this forum: No registered users and 30 guests
