already asked somewhere but no one answered. Maybe I asked in the wrong section of the forum. I’ll ask separately again: is it possible to somehow use a script to output data to the serial port of Mikrotik? As far as I understand from the descriptions, the output comes only from the keyboard, and I would need to output something like :put with the command, but it seems like such output only appears on the screen, but not to the port.
I am wrong ?
I’ll explain why this is necessary. I want to connect a device to the serial port, to which I need to output hexadecimal data, which are commands for it. This needs to be done with a script, not with the keyboard. Why doesn't Mikrotik's :put work as well as in Linux, where you can output it anywhere with a similar command?
