hilton
Long time Member
Long time Member
telnet to localhost just times out
Thu Nov 29, 2007 5:01 pm
Hi guys
I have installed 2.9.49 and trying out a few things but one issue is starting to get annoying. Whenever I try to telnet 0.0.0.0 or even the IP of the ether1 the telnet screen just says 'Trying 192.168.50.2...'.
If I reset the system, then it works. What could I be possibley doing wrong that would cause this?
BTW , New Terminal works fine and telnet from my PC also works.
Regards
Hilton
roadrunner
Re: telnet to localhost just times out
Thu Nov 29, 2007 9:29 pm
Don't use 0.0.0.0, that isn't the IP address of localhost; try 127.0.0.1 instead. As for telneting to the IP address of ether1, you might have a firewall filter rule blocking the traffic. Try adding an 'allow' rule in the input chain for a source address of your ether1 IP.
There might be something else that is causing your trouble, but give that a try.
ashish
Long time Member
Long time Member
Fri Nov 30, 2007 6:46 am
make sure that /ip service telnet is Enabled.
or as roadrunner said theie should be some firewall rules
- AP - ASHISH PATEL - 757 309 0236 -
hilton
Long time Member
Long time Member
Fri Nov 30, 2007 10:34 am
Ok I added this line to the filter;
chain=input action=accept dst-address=192.168.50.2 dst-port=23 protocol=tcp
But I thought that this original line would have accepted it;
chain=input action=accept in-interface=bridge1 src-address=192.168.50.0/24
Thanks to roadrunner and ashish.
Regards
Hilton
Users browsing this forum: Baidu [Spider], robor and 20 guests
