I'm trying to set up VLANs on an RB260 but so far every single guide I've found for doing so contains different instructions. There's this MikroTik one, another MikroTik one, a third-party one, another third-party one, and then a fifth one for which I've lost the link which is different yet again. Does anyone know which of this multitude of incompatible VLAN setup guides is the correct one? Or, if they all more or less work, which is the preferred one to go with?
In case this makes any difference for the above question, I want to use the SFP port as a trunk including web access to the router and the various ethernet ports as untagged VLAN ports with the RB260 adding the tagging.
