Access to the internet over WLAN and LAN is working without an issues. However I am not able to connect devices inside the LAN which are connected to the Ethernet Ports of the RB5009UPr+S+. It is not possible to ping or make any connection from one port of the RB5009UPr+S+ to any other port within the same bridge. However I can Ping devices connected to the WLANS of the RBcAPGi-5acD2nD and I also can Ping the devices if I use an additional CSS610-8G-2S+IN.I would like to use the Ports on the RB5009 just like an internal switch.
So my conclusion is the ports are isolated from each other by default in RouterOS. What are the settings to allow communication between all port of a bridge? . In my case that’s all except ETH1.
Here a part of the export:
Code: Select all
add bridge=bridge comment=defconf interface=ether6
add bridge=bridge comment=defconf interface=ether7
add bridge=bridge comment=defconf interface=ether8
add bridge=bridge comment=defconf interface=sfp-sfpplus1
add address=192.168.77.1/24 comment=defconf interface=bridge network=\
192.168.77.0
