DJGlooM
L009UiGS-2HaxD-IN no passthrough poe again?
Thu Nov 30, 2023 8:27 pm
Mikrotik, WTF? I bought 5009P+ thinking it'll poe-in and poe-out independently from PSU or 2-pin power, then I figure out I was wrong and you've made a bold text later that you have to use PSU to have poe-out.
Alright, I used 5009 as a main router and bought L009 to use as a switch with poe passthrough, to power it from ether1 (which is "conveniently" not on switch chip, good job either) and power daisy-chained devices from ether8 (which is now even cannot detect poe client and you have to use forced-on, great). But today I powered hex s with 56V PSU, used cat6 cable to connect hexs ether5 to L009 ether1, it powered on, but guess what - no poe-out from ether8 without PSU, AGAIN.
Not only you make worse designed (but better-looking) equipment now, you also "forget" to mention some things until you're pointed on it by users.
About 5009 - after 6 months mounted on the wall I found it leaking silicone from it's thermopads. It wasnt overheating.
sch
Re: L009UiGS-2HaxD-IN no passthrough poe again?
Fri Dec 01, 2023 3:06 pm
Please send an email to MikroTik support and include a supout.rif file.
DJGlooM
Fri Dec 01, 2023 5:02 pm
Are you a representative and you're saying that it isn't proper L009 behaviour?
Amm0
Fri Dec 01, 2023 5:16 pm
The PoE is always tricky on the Mikrotik since it does vary by model.
While brochure https://i.mt.lv/cdn/product_files/L009U ... 230546.pdf does say "* PoE-Out works only if powered by DC jack"... So I think that's how it is. Now that asterisk note isn't on the website specs.
Agree writing to support is the right call... but imagine solution is either return it or use the DC jack instead of the PoE-IN. Mikrotik should add that same note the website, since I would have assume same as you...
DJGlooM
Fri Dec 01, 2023 6:44 pm
Exactly. Before that it was enough to just read short specs, now we have to look the whole datasheet, why? I think Mikrotik goes aggressively into commerce sacrificing the good engineering that was before. We, as customers, had inexpensive good devices in plastic and now they offer us more elegant devices in metal cases but totally worse to use in network build-up, temperature profile, stability.
I just want to hear engineer that designed poe-in&poe-out device like 5009 and explain how does he see it in production when you HAVE to use PSU to use poe-out. Meanwhile I still use hex poe connected to poe switch to distribute power for cameras and APs. Same goes with L009 design as it seems: why do you need ONE poe-out port when you can only use force-on (which can be dangerous) and you have to use PSU with it? What's the point at all? What was the thought behind it? And why brag 2.5 gbit sfp port while poe-in port is out of switch chip that means out of hw offloading?
And about support - good thing that how we have help.mikrotik.com portal and convenient interface instead of email only. But what's the point if you wait over a month for any answer? And the answer "try this beta" usually come from support after month. MIkrotik, seriously? I came when there was 6.18 and it was much better and stable than what we have now and community was more alive because vendor was more involved. Now MUM is over, HW design is retarded, stable is unstable in production and no long-term still available, they use customers for betatesting in "stable" and suggest to use beta-release (which is more like alpha) for production.
Not to mention that Mikrotik excluded Russia from certificated specialists map and then sending emails about certificate expiration. What a shame.
Users browsing this forum: Fogga, timotei and 49 guests
