... gives me problems, as the used IP address to answer an access request is not defined, seems not to be controllable, and flaps from time to time (e.g. when something is done and un-done to IP addresses, like adding or removing a VRRP). If the User Manager then answers with a different IP address to the router (AP) , as the IP address used for the access request, then the user is denied access. "E2:C0:55@wlan2: disconnected, 802.1x authentication timeout"
User Manager in ROS7.12 as RADIUS server for EAP wifi users.
If the request sent to 24.1 is answered , then here 192.168.24.4 is used , and the authentication fails.
Dis-abling 192.168.24.4 en re-enabling, makes the Immediate Gateway unknown.
How to properly set the desired source IP adress for UserManager answers? Either for User Manager, or even for that interface as a whole?
Doing like VRRP with a 192.168.24.1/32 address , or what?
Related request , no aswers yet ... viewtopic.php?p=1013710 (cfr @LdB)
