Tichi
Which HW to buy
Thu Dec 07, 2023 11:22 pm
Hi all,
Quick and easy questions for the pros.
Looking to buy some new HW and was thinking about hEX + CSS326-24G-2S+RM. Or is it more logic to just buy CRS326-24G-2S+RM ?
Only specific request I have is firewall + 24 ports. Rackmountable is certainly a plus (I know the hEX isn't).
Feel free to give your advise.
Sorry for the newbie question.
Grtz!
gigabyte091
Re: Which HW to buy
Fri Dec 08, 2023 5:43 am
What is your connection speed? Are you planning to use VPN ?
L009 is rack mountable, RB5009 also.
Tichi
Re: Which HW to buy
Fri Dec 08, 2023 12:35 pm
Connection speed not more than 100mbps.
VPN maybe at a certain point when I get more used to all the options.
VLANs are a plus but not a necessity for the moment.
Thanks for the reply.
gigabyte091
Re: Which HW to buy
Fri Dec 08, 2023 5:27 pm
For that speed L009 is more than adequate.
Tichi
Re: Which HW to buy
Fri Dec 08, 2023 11:55 pm
So if I understand it correctly.
L009
SFP connection towards CSS or CRS switch ? Does it have an added value to have CRS on a switch ?
Advantage of the L009 is that I can run my Pihole in it 🙂
gigabyte091
Re: Which HW to buy
Sat Dec 09, 2023 8:31 am
You don't have to use SFP to connect switch and router, you can use normal ethernet cable.
CRS have dual boot option, so ROS or swOS but with only single core 800MHz CPU im not sure how well it will handle routing at higher speeds, especially if you start to add firewall rules etc.
I would give swOS a try, i personally use mikrotik switches with sw os and swos lite at work and home and im happy with them.
One minus is that you can't configure swos from winbox, only webfig. But winbox can discover them.
nescafe2002
Forum Veteran
Forum Veteran
Re: Which HW to buy
Sat Dec 09, 2023 9:35 am
CRS326-24G-2S+RM will handle 100 Mbps fine (routing, nat, filtering). No need to buy additional router for these tasks.
gigabyte091
Re: Which HW to buy
Sat Dec 09, 2023 9:42 am
Still... If you want something more future proof I would still reconsider buying separate router. If OP is on a tight budget okay, CRS would be a way to go, but if he is planning to run some containers etc... L009 or even RB5009 is a much better choice.
Or maybe ax3
Tichi
Re: Which HW to buy
Sat Dec 09, 2023 4:54 pm
A little bit future proof is certainly an advantage. Seen that you get at least support for 5 years for updates I think it will become a L009 and a CSS 24 switch. I like to keep it separated to be honest. RB5009 is for my utilization overkill and the price is already a lot more compared to the L009. Or can you run something on the RB5009 that is a must. I’m still a noob on Mikrotik level and all information is goed to have. I’ll use a Cat6a cable to connect both devices.
gigabyte091
Re: Which HW to buy
Sat Dec 09, 2023 7:05 pm
I think that in your case L009 and CSS326 would fit nice and you will learn ROS and swOS.
Tichi
Re: Which HW to buy
Sat Dec 09, 2023 7:59 pm
Thanks for the followup and replies. I know what to buy
Users browsing this forum: No registered users and 11 guests
