l2sverige
Wireguard site-to-site problem
Tue Dec 12, 2023 11:30 am
Hi!
I have made site-to-site between 2 routers on different wan locations. both have public IP.
The traffic is being seen on firewall rule from office 1, but no traffic from office 2? Wierd.
I use 0.0.0.0/0 for "allowed IP" from both sites, but I can't ping och get connections to devices between the lans.(I use VLAN on both sites)
I have made routes to local ip and used the WG adress as gateway.
Is there a problem when using it with vlan?
baragoon
Re: Wireguard site-to-site problem
Tue Dec 12, 2023 11:51 am
no problems, 3 sites are connected via wireguard dual stack.
l2sverige
Re: Wireguard site-to-site problem  Topic is solved
Tue Dec 12, 2023 1:59 pm
solved :) The problem was the Public key had been changed by itself for some reason?!...edit them back and everything worked like a charm :)
baragoon
Tue Dec 12, 2023 2:54 pm
anav
Wed Dec 13, 2023 8:35 pm
Quick, get rid of your MT device, clearly its possessed by an evil spirit.
anav
Wed Dec 13, 2023 8:37 pm
Hi!
Be careful if you add any additional remote users to the config as then it will not necessarily work properly!!!
