vruzicka
Unable to connect Tuya devices
Thu Dec 14, 2023 5:51 am
Hello.
I have an unsolvable problem. Unable to connect Smart Tuya devices to Mikrotik AP. I try to set only basic configuration on MikroTik AP - bridged port eth1 and wifi2 (2,4GHz) with WPA auth. When trying connect in Tuya Smart app - not succes with timeout. Old noname (not sure of manufacturer) AP joined to same network working without problem - Tuya device was connected successfully. For this i am focusing on problem in MikroTik AP (hAP ax2) not in rest of the network.
In different network, where i try connect my Mikrotik AP, the same problem.
Does someone know the solution?
V.
Ca6ko
Long time Member
Long time Member
Re: Unable to connect Tuya devices
Thu Dec 14, 2023 3:36 pm
with WPA auth.
Do these devices support this ancient standard?
Reset the Mikrotik to factory settings, merge the ports into bridge and do not touch anything else.
vruzicka
Fri Dec 15, 2023 10:30 am
Sorry for hte wrong information. Of course, I using WPA2 auth.
But I also tried different autentication settings without success. (Other noname AP without probleam as I wrote).
And I also wrote
...only basic configuration on MikroTik AP - bridged port eth1 and wifi2...
Other devices joined to the MikroTik AP (laptops, smartphones, TV) work fine.
But only the Tuya not....
The same problem on second hAP ax2 device. Other MikroTik devices not tested.
vruzicka
Tue Dec 19, 2023 10:43 am
Does anyone have the same problem?
rextended
Tue Dec 19, 2023 2:23 pm
If you yourself say it's unsolvable, why bother?
strods
Tue Dec 19, 2023 2:30 pm
What do you see on the AP in logs? Can you provide supout file to support@mikrotik.com? Plenty of Tuya devices connected to MikroTik routers all over the globe. This definitely is not a global incompatibility issue.
robmaltsystems
Long time Member
Long time Member
Tue Dec 19, 2023 2:38 pm
I've got a similar problem with connecting 10-year old Kindle to AX2. Kindle doesn't even see the network. Tried disabling WPA3-PSK and enabling WPA-PSK and WPA2-PSK, no help. Switching 2GHz AX and switching to 2Ghz N worked so I'm guessing some devices don't work with AX at all.
vruzicka
Wed Dec 20, 2023 11:47 am
Supout has been send...
vruzicka
Wed Dec 20, 2023 7:54 pm
Now tested hAP ac2 - works fine, Tuya connected.
raffav
Thu Dec 21, 2023 12:29 am
I have with tp link kasa smart plug
2.4ax all possible combinations they can't find WiFi (kasa app shows all devices are off)
Making 2.4n only make device connected and disconnecting loss signal
2.4g makes work but not stable...
Because of them im still using cap ac only 2.4 just for then
While cap ax I have only enabled 5g ax
robmaltsystems
Long time Member
Long time Member
Thu Dec 21, 2023 1:12 am
Same with my ancient Kindle. I would be interesting if anyone has an AX device from another manufacturer and whether the same devices work with it in AX mode. I would hope/imagine not.
raffav
Thu Dec 21, 2023 10:38 am
I Wish but unfortunately I don't want to buy any out of shelf router ax just to check they will work or not
Now I was thinking maybe one of my android I can try to see if mobile hotspot with 2.4 can do ax
robmaltsystems
Long time Member
Long time Member
Thu Dec 21, 2023 12:22 pm
For me, the Kindle is a non-issue. Only needs to be on the internet when I need to download a new book so can use hotspot on phone. I'm guessing the solutions are a) switch to 2N on 2.4Ghz or b) install a cheap Wi-Fi 4 access point. Must be loads 2nd hand on eBay. Would suggest mAP lite but they're expensive IMO these days. TBH loosing 2AX wouldn't be disastrous as high speed devices will be connecting to 5GHz anyway.
raffav
Thu Dec 21, 2023 1:11 pm
But even putting in 2gz-n it won't work or be very unstable....
There is something with this legacy device that is messed up...
vruzicka
Fri Dec 22, 2023 9:42 am
Further testing:
* Smartphone connected to the hAP ac2, none device in Tuya app. I run new device adding procedure and device is added successfully. Device status is online and working well.
* Now I switch off (disconnect from power) the hAP ac2. Previously added device status is going to offline (in Tuya app).
* I switch on the TP-Link AP (connected to the same network), where is set the same wifi configuration as in hAP ac2 (the same SSID and WiFi password, security,…) Device in Tuya app is going to online automatically and working well.
* I switch off the TP-Link AP. Tuya device status is going to offilne.
* I switch on the hAP ax2 (connected to the same network), where is set the same wifi configuration as in hAP ac2 (the same SSID and WiFi password, security,…) Device status in Tuya app stays offline. Device does not work]
clivejo
Fri Dec 22, 2023 6:25 pm
Have you tried separating 2.5 and 5GHz networks with separate name (SSIDs)? Then both app device and Tuya IoT device need to be on the same 2.4Ghz network
vruzicka
Fri Dec 22, 2023 11:48 pm
For this tests 5GHz radio is disabled. Configured 2,4GHz only.
999masks
Tue Jan 02, 2024 12:03 am
I have the same exact issue. I think this is due to recent updates on Mikrotik routher. My devices used to work 4-5 years, not anymore..
aldmik
Tue Jan 30, 2024 10:03 pm
I am experiencing the same issue with the hAP ax lite, for example, when trying to adopt the Tuye WiFi switch.
bleve2000
Sun Feb 04, 2024 10:06 am
My situation is similar but i solved it like that:
I have gree AC (4 appliances) they do not want to connect only to the caps with only ax network. Using my provisovision section I have a hybrid structure of 2.4 IoT network: main 2.4g network with N and slave working in AX standard.
My gree devices connect to my caps only when N standard is main and AX is slave. With AX first and only AX they do not connect. Strange is that they can connect to AX as you can see in my registration table. So probably when AX is only or AX is the first the devices can not see the network or something else.
Users browsing this forum: r0ut3r5 and 14 guests
