lspci | grep -i 'net'
displays only the presence of built-in adapters
04:00.0 Ethernet controller: Broadcom Limited NetXtreme BCM5720 Gigabit Ethernet PCIe
04:00.1 Ethernet controller: Broadcom Limited NetXtreme BCM5720 Gigabit Ethernet PCIe
This form-factor does come with certain limitations that you should keep in mind. The CCR NIC card needs some time to boot up compared to ASIC-based setups. If the host system is up before the CCR card, it will not appear among the available devices. You should add a PCIe device initialization delay after power-up in the BIOS. Or you will need to re-initialize the PCIe devices from the HOST system.
If you want to do it independently from the installed OS:Can you tell me how to do it in Dell R540
Can you tell me exactly how to properly re-initialize PCIe after booting. Thank you.It would be safer to simply reinitialize the PCIe device in your OS after boot.Can you tell me how to do it in Dell R540
