I have 2 router-network. It is roamed by CAPsMAN (hAP ax^2 and hAP ax lite).
There are 4 networks. Main2.4, Main5, Guest2.4, Guest5 and romed Main2.4 and Guest2.4.
Guest networks are virtual.
There are 2 DHCP pools, 2 DHCP servers, 2 bridges.
Everythins works. But when user devices are connect to GUEST networks DHCP servers assigns wrong network address from MAIN network
CAPsMAN:
Code: Select all
export compact
# 2023-12-15 18:07:53 by RouterOS 7.12.1
# software id = SJPN-HJF3
# model = C52iG-5HaxD2HaxD
# serial number =
add name=GUEST_NETWORKs_bridge vlan-filtering=yes
add name=MAIN_NETWORK_bridge vlan-filtering=yes
/interface pppoe-client
add add-default-route=yes disabled=no interface=ether1 name=pppoe-out1 user=\
user
/interface wifiwave2 channel
add band=2ghz-ax disabled=no name=MAIN_NETWORK2 skip-dfs-channels=disabled
add band=5ghz-ax disabled=no name=MAIN_NETWORK5 skip-dfs-channels=disabled
/interface wifiwave2 datapath
add bridge=MAIN_NETWORK_bridge disabled=no name=MAIN_NETWORK
add bridge=GUEST_NETWORKs_bridge client-isolation=yes disabled=no name=GUEST_NETWORKs
/interface wifiwave2 security
add authentication-types=wpa2-psk disabled=no encryption=ccmp group-encryption=\
ccmp group-key-update=30m name=MAIN_NETWORK
ccmp group-key-update=30m name=GUEST_NETWORKs
/interface wifiwave2 configuration
add channel=MAIN_NETWORK2 country=Kyrgyzstan datapath=MAIN_NETWORK disabled=no mode=ap name=\
MAIN_NETWORK2 security=MAIN_NETWORK ssid=MAIN_NETWORK
add channel=MAIN_NETWORK5 country=Kyrgyzstan datapath=MAIN_NETWORK disabled=no mode=ap name=\
MAIN_NETWORK5 security=MAIN_NETWORK ssid=MAIN_NETWORK
add channel=MAIN_NETWORK2 country=Kyrgyzstan datapath=GUEST_NETWORKs datapath.bridge=\
GUEST_NETWORKs_bridge disabled=no mode=ap name=GUEST_NETWORKs2 security=GUEST_NETWORKs ssid=\
GUEST_NETWORKs tx-power=5
add channel=MAIN_NETWORK5 country=Kyrgyzstan datapath=GUEST_NETWORKs datapath.bridge=\
GUEST_NETWORKs_bridge disabled=no mode=ap name=GUEST_NETWORKs5 security=GUEST_NETWORKs ssid=\
add configuration=MAIN_NETWORK2 configuration.mode=ap disabled=no name=s2 radio-mac=\
48:A9:8A:9F:7A:D6
set [ find default-name=wifi2 ] configuration=MAIN_NETWORK2 configuration.mode=ap \
disabled=no name=s2r
set [ find default-name=wifi1 ] configuration=MAIN_NETWORK5 configuration.mode=ap \
disabled=no name=s5r
add configuration=GUEST_NETWORKs2 configuration.mode=ap datapath=GUEST_NETWORKs \
datapath.bridge=GUEST_NETWORKs_bridge disabled=no mac-address=4A:A9:8A:9F:7A:D6 \
master-interface=s2 name=d2
datapath.bridge=GUEST_NETWORKs_bridge disabled=no mac-address=4A:A9:8A:C8:49:20 \
master-interface=s2r name=d2r
add configuration=GUEST_NETWORKs5 configuration.mode=ap datapath=GUEST_NETWORKs \
datapath.bridge=GUEST_NETWORKs_bridge disabled=no mac-address=4A:A9:8A:C8:49:1F \
master-interface=s5r name=d5r
add name=MAIN_NETWORK_pool ranges=192.168.192.1-192.168.192.254
add name=GUEST_NETWORKs_pool ranges=192.168.11.5-192.168.11.250
add address-pool=MAIN_NETWORK_pool interface=MAIN_NETWORK_bridge name=sky_dhcp \
server-address=192.168.192.1
add address-pool=GUEST_NETWORKs_pool interface=GUEST_NETWORKs_bridge name=GUEST_NETWORKs_dhcp \
server-address=192.168.11.1
add bridge=MAIN_NETWORK_bridge interface=ether2
add bridge=MAIN_NETWORK_bridge interface=ether3
add bridge=MAIN_NETWORK_bridge interface=ether4
add bridge=MAIN_NETWORK_bridge interface=ether5
add bridge=MAIN_NETWORK_bridge interface=*6
add bridge=MAIN_NETWORK_bridge interface=*7
add bridge=MAIN_NETWORK_bridge interface=*18
add bridge=MAIN_NETWORK_bridge interface=*19
/interface bridge vlan
add bridge=MAIN_NETWORK_bridge vlan-ids=501
/interface wifiwave2 access-list
add action=reject disabled=no interface=d2r signal-range=-120..-80
add action=reject disabled=no interface=s5r signal-range=-120..-80
add action=reject disabled=no interface=s2r signal-range=-120..-80
add action=reject disabled=no interface=d5r signal-range=-120..-80
/interface wifiwave2 cap
set caps-man-addresses=127.0.0.1 discovery-interfaces=MAIN_NETWORK_bridge enabled=yes
/interface wifiwave2 capsman
set enabled=yes package-path="" require-peer-certificate=no upgrade-policy=none
/interface wifiwave2 provisioning
add action=create-enabled disabled=no master-configuration=MAIN_NETWORK5 name-format=\
cap slave-configurations=GUEST_NETWORKs5 supported-bands=5ghz-ax
add action=create-enabled disabled=no master-configuration=MAIN_NETWORK2 name-format=\
cap slave-configurations=GUEST_NETWORKs2 supported-bands=2ghz-ax
add address=192.168.192.1/24 interface=MAIN_NETWORK_bridge network=192.168.192.0
add address=192.168.11.1/24 interface=GUEST_NETWORKs_bridge network=192.168.11.0
/ip dhcp-server lease
add address=192.168.192.254 client-id=1:94:de:80:a3:cc:f4 mac-address=\
94:DE:80:A3:CC:F4 server=sky_dhcp
add address=192.168.11.0/24 dns-server=192.168.11.1 gateway=192.168.11.1 \
netmask=24
add address=192.168.192.0/24 dns-server=192.168.192.1 gateway=192.168.192.1 \
netmask=24
set allow-remote-requests=yes servers=8.8.8.8
add action=masquerade chain=srcnat out-interface=pppoe-out1
/ip service
set telnet disabled=yes
set ftp disabled=yes
set www disabled=yes
set ssh disabled=yes
set api disabled=yes
CAPsMAN client
Code: Select all
# mode: AP, SSID: MAIN_NETWORK, channel: 2452/ax/Ce
set [ find default-name=wifi1 ] configuration.manager=capsman datapath=capdp \
disabled=no
# managed by CAPsMAN
# mode: AP, SSID: GUEST_NETWORK
add configuration.mode=ap datapath=capdp datapath.vlan-id=502 disabled=no \
mac-address=4A:A9:8A:9F:7A:D6 master-interface=wifi1 name=wifi3
/port
set 0 name=serial0
add bridge=bridgeLocal comment=defconf interface=ether1
add bridge=bridgeLocal comment=defconf interface=ether2
add bridge=bridgeLocal comment=defconf interface=ether3
add bridge=bridgeLocal comment=defconf interface=ether4
set discovery-interfaces=bridgeLocal enabled=yes slaves-datapath=capdp \
slaves-static=yes
/ip dhcp-client
add comment=defconf interface=bridgeLocal
