Matta
hEX PoE - no POE out after lightning
Fri Dec 15, 2023 5:51 pm
hEX PoE suffered surge from lightning.
- POE-in works
- All port work
Only PoE-out won't work on all 4 ports. When I try to power it up I get message "short circuit".
If someone knows which electronic component is gone ? Would it be possible to repair ?
Thanks in advance !
vitorvermaas
Re: hEX PoE - no POE out after lightning
Sat Dec 16, 2023 2:46 am
Can you post the other side of rb?
Matta
Sat Dec 16, 2023 9:17 am
gigabyte091
Sat Dec 16, 2023 7:50 pm
Well with lightning strike damage it's hard to know what is damaged... It's probably easier for you to replace device.
Users browsing this forum: Ahrefs [Bot], Kanzler, svmk and 5 guests
