Please read and heed the warning of the documentation's Compatibility section:...
As soon as I enable wave2 capsman on my controller (RB4011 with wifi) my hap ac2 (running still wireless package until I'm ready with new capsman) stayed connected to legacy capsman.
But I lost the local wifi interfaces of the RB4011 only.
As soon as I disable wave2 capsman the local wifi interfaces are coming back.
At the very beginning of the Wireless documentation in the RouterOS package type section there are two tables describing what package(s) is/are required to achieve certain features on a given device.Compatibility[:] Incompatible
Devices[:] RB4011iGS+5HacQ2HnD-IN (no support for the 2.4GHz interface)...
I've read all this several times before and after and still believe that my understanding is correct.Please read and heed the warning of the documentation's Compatibility section:At the very beginning of the Wireless documentation in the RouterOS package type section there are two tables describing what package(s) is/are required to achieve certain features on a given device.Compatibility[:] Incompatible
I'm asking you to try to configure local interfaces directly without trying to use local capsman. I wrote the reasons for my suspicions that this might be a problem in my previous post.cap1: local RB4011 wifi interfaces <- managed by legacy capsman
I observed similar when I put up this post.Sorry, don't understand the questions/statements.
I could provision the RB4011 wireless interfaces locally because I have the "wireless" package. But I prefer to keep them managed via the legacy capsman on the same device as it is as of today.
And yes, using local wifi capsman I cannot manage them but that is not what I'm trying to do.
Just to repeat again
RB4011 (routeros+wireless) (wifi and legacy capsman available)
cap2: ax3 <- managed by wifi capsman
cap3: ac2 (with wifi-qcom-ac drivers) <- managed by wifi capsman
cap4: ac2 (with wireless (for now) <- managed by legacy capsman
The above is the scenario i'm trying to set up and still I believe that is supposed to work.
And the roadblock I currently have is that cap1 interfaces are disconnected as soon as I enable wifi capsman while cap4 stays happily connected.
Ok, so you are basically telling me to use that as a workaround because something might cause problems?I'm asking you to try to configure local interfaces directly without trying to use local capsman. I wrote the reasons for my suspicions that this might be a problem in my previous post.cap1: local RB4011 wifi interfaces <- managed by legacy capsman
... unless MT says ...
That is the point of my post.
1. just read it "Built-in cards can only work with legacy drivers" - what have the drivers to do with the fact if they are configured via old capsman or via local configuration. That is no contraindicator.Before believing read the (extended) documentation first as while 7.13 made it possible to run both CAPsMANs on the same device at the same time there are certain limitations:
- Wireless part of the documentation RouterOS package type pay special attention to the notes.
- Compatibility section of the WiFi part of the documentation.
- The dedicated announcement 7.13 wireless package split question topic.
2. now I've read it the 20th time. Still nothing in there which would explain the issue I'm seeing. Instead of pointing multiple times to the same documentation it would be helpful to get a direct pointer to the information which says that my issue is "expected"?
3. thanks for that pointer because this post exactly describes my problem. The problem just is that there is no reply, no explanation, not a solution dedicated to this. So a pointer to the same question is interesting because information could be consolidated but unfortunately no solution.
I had the same issue and found that on my access points I was discovering CAPsMAN via an ip address. Once I removed that and discovered CAPsMAN using a discovery interface then the access points could join back in with both CAPsMANs enabled.I have been using CAPsMan 1 for my local and remote AP. I know I need to allow UDP 5246, 5247 for traffic
When I upgrade to 7.13, I wish to try CAPsMan 2. I know it can be used on the same main routeros device. But seems it does not allow remote APs to come it when both CAPsMan 1 and 2 are on
Interesting. My local interfaces on the capsman host are configured to use 127.0.0.1 which works (as long as I don't enable new capsman in parallel).I had the same issue and found that on my access points I was discovering CAPsMAN via an ip address. Once I removed that and discovered CAPsMAN using a discovery interface then the access points could join back in with both CAPsMANs enabled.
Does discovery in general not work on the same device?
New capsman explicitly doesn't support provisioning local devices (MT is very clear on that).
Old capsman apparently did[*] support that but MT (AFAIK) never really advertised this as a feature ... so it might be an unsupported glitch they just let working all these years.
I try two routerOS device on the same network - one with legacy wifi; connect and work with CAPsMan 1; the other is a AX3 could not connectYour CAPS that can't connect try to reach your CAPsMAN server via WAN? Then check your firewall rules?
I use both 7.15.beta9 in my x86 as CAPsMan 1 + 2 and AX3 as CAP. From the AX3 log, it shows timeout. Firewall allows both UDP ports 5246 and 5247 in and out.If issue persists while 7.14.2 is installed on CAPs and CAPsMAN, please create supout.rif files on involved devices and share the files with us support@mikrotik.com
This issue should be resolved in latest versions.
