I want to configure the use of the 5 GHz band as a priority for connecting clients with the same SSID. As far as I understand, it is necessary to reduce the power of the 2 GHz transmitter. Based on the data that the router produces for the 2 GHz range - the power is 30dBm and for 5 GHz - 7 units lower, namely 23dBm
According to the documentation for the device, it is also possible to amplify antennas for 2 GHz - 3 dBi, for 5 GHz - 5.5 dBi
When calculating dB, dBi, dBm, they are all essentially decibels, i.e. are summed (if gain) or subtracted (if attenuation) which means we need to add the values of the transmitter power and the antenna gain
As a result, we get for 2 GHz: 30 + 3 = 33 dBi
And for 5 GHz: 23 + 5.5 = 28.5 dBi
That is, theoretically, you need to lower the 2 GHz transmit power by several units, for example: 33 - 29 = 4+6 (further lower as a test option) = 10
Based on the fact that the transmitter power is 2 GHz = 30 dBm, it turns out that you need to set the power to 30 - 10 = 20 dBi
At the same time, on the Wiki Mikrotik page for setting up Wireless it is indicated that:
802.11n wireless chipsets represent power per chain and the 802.11ac wireless chipsets represent the total power, for reference see the table below:
The device has 2 antennas and 2 chains enabled
How to correctly understand the table below? And what power of the transmitter amplifier should I set so that the 5 GHz range is a priority? Or it’s enough to just underestimate it by 10 units, as I suggest above. I am not a radio frequency specialist, but I want to figure it out and understand the principle. Thank you.
