xrlls
Creating array element with type nil
Mon Dec 25, 2023 3:26 pm
I am working with the new serialize and deserialize commands for JSON. I found that the deserialize command will convert a null payload to a variable with type nil:
> global org [deserialize value="{\"a\":\"Hi\",\"b\":12,\"c\":null}" from=json ]
> put $org
a=Hi;b=12;c=
> put [typeof ($org->"c")]
nil
This is all good, and makes sense, but if I want to create a JSON payload with an entry with a null payload, how do I create an array element without assigning it any value, and with type nil?
> global new
> set ($new->"a") "Hi"
> set ($new->"b") 12
> set ($new->"c")   #What goes here?
> put $new
a=Hi;b=12
> put [serialize $new to=json ]
{"a":"Hi","b":12}
Any input is appreciated!
optio
Long time Member
Long time Member
Re: Creating array element with type nil  [SOLVED]
Mon Dec 25, 2023 3:35 pm
[:nothing]
xrlls
Mon Dec 25, 2023 5:32 pm
Thanks! :)
Users browsing this forum: No registered users and 5 guests
