Something similar happens to me, I don't understand why it disconnects, it only happens with the iPhone 14 pro max.
Here the configuration
# 2023-12-27 13:33:25 by RouterOS 7.13
# software id = G48Y-1U35
# model = RBD52G-5HacD2HnD
# serial number = XXXXXXXXX
add admin-mac=2C:C8:1B:C9:12:CB arp=reply-only auto-mac=no name=bridge
/interface wireguard
add comment=back-to-home-vpn listen-port=58216 mtu=1420 name=back-to-home-vpn
/interface vlan
add interface=ether1 name=vlan20 vlan-id=20
/interface pppoe-client
add add-default-route=yes disabled=no interface=vlan20 name=pppoe-out1 user=968587466@xxxx
add comment=defconf name=WAN
add comment=defconf name=LAN
/interface wifi channel
add band=2ghz-n disabled=no frequency=2412 name=channel01 width=20mhz
add band=5ghz-ac disabled=no frequency=5680,5170 name=channel136 width=20/40mhz
/interface wifi security
add authentication-types=wpa2-psk,wpa3-psk disabled=no management-protection=allowed name=sec1 wps=disable
/interface wifi configuration
add channel=channel01 country=Spain disabled=no mode=ap name=cfg01 security=sec1 security.ft=yes .ft-over-ds=yes ssid=Nely
add channel=channel136 country=Spain disabled=no mode=ap name=cfg136 security=sec1 security.ft=yes .ft-over-ds=yes ssid=Nely
/interface wifi
set [ find default-name=wifi1 ] configuration=cfg01 configuration.mode=ap .tx-power=9 disabled=no
set [ find default-name=wifi2 ] configuration=cfg136 configuration.mode=ap .tx-power=16 disabled=no security.connect-priority=0
/ip hotspot profile
add name=default-dhcp ranges=192.168.52.100-192.168.52.254
add add-arp=yes address-pool=default-dhcp interface=bridge lease-time=8h name=LAN
add bridge=bridge comment=defconf interface=wifi1
add bridge=bridge comment=defconf interface=wifi2
add interface=bridge list=LAN
add address=192.168.52.1/24 comment=LAN interface=bridge network=192.168.52.0
/ip cloud
set back-to-home-vpn=enabled ddns-enabled=yes
/ip dhcp-server lease
add address=192.168.52.106 client-id=1:3c:6a:a7:44:80:36 mac-address=3C:6A:A7:44:80:36 server=LAN
add address=192.168.52.105 client-id=1:8e:da:61:c1:e7:d0 mac-address=8E:DA:61:C1:E7:D0 server=LAN
add address=192.168.52.98 client-id=1:80:fa:5b:5f:54:91 mac-address=80:FA:5B:5F:54:91 server=LAN
add address=192.168.52.104 mac-address=90:0C:C8:EA:56:49 server=LAN
add address=192.168.52.100 mac-address=1C:3B:F3:8D:FE:B6 server=LAN
add address=192.168.52.101 client-id=1:a:cf:fd:85:cc:51 comment=IphoneNely mac-address=0A:CF:FD:85:CC:51 server=LAN
add address=192.168.52.0/24 comment=defconf dns-server=192.168.52.1 gateway=192.168.52.1 ntp-server=192.168.52.1
set allow-remote-requests=yes servers=8.8.8.8,9.9.9.9,2620:fe::fe,2001:4860:4860::8844
/ip dns static
add address=192.168.52.1 name=nrouter.lan
add cname="nrouter.lan " comment="nrouter.lan " name=hapac2.lan type=CNAME
add action=accept chain=input comment=" accept established,related,untracked" connection-state=established,related,untracked
add action=accept chain=input comment="defconf: accept to local loopback (for CAPsMAN)" dst-address=127.0.0.1
add action=fasttrack-connection chain=forward comment="defconf: fasttrack" connection-state=established,related hw-offload=yes
add action=drop chain=forward comment="defconf: drop all from WAN not DSTNATed" connection-nat-state=!dstnat connection-state=new in-interface-list=WAN
/ip service
set telnet disabled=yes
set ftp disabled=yes
set www address=192.168.52.98/32,
set ssh disabled=yes
set api disabled=yes
set winbox address=\
192.168.52.98/32,
set api-ssl disabled=yes
/ipv6 address
add address=::1 from-pool=pool6 interface=bridge
/ipv6 dhcp-client
add add-default-route=yes interface=pppoe-out1 pool-name=pool6 rapid-commit=no request=address,prefix
/ipv6 firewall address-list
/ipv6 firewall filter
add action=accept chain=input comment="defconf: accept ICMPv6" protocol=icmpv6
add action=accept chain=input comment="defconf: accept UDP traceroute" port=33434-33534 protocol=udp
add action=accept chain=input comment="defconf: accept DHCPv6-Client prefix delegation." dst-port=546 protocol=udp src-address=fe80::/10
add action=accept chain=input comment="defconf: accept IKE" dst-port=500,4500 protocol=udp
add action=accept chain=input comment="defconf: accept ipsec AH" protocol=ipsec-ah
add action=accept chain=input comment="defconf: accept ipsec ESP" protocol=ipsec-esp
add action=accept chain=input comment="defconf: accept all that matches ipsec policy" ipsec-policy=in,ipsec
add action=drop chain=input comment="defconf: drop everything else not coming from LAN" in-interface-list=!LAN
add action=accept chain=forward comment="defconf: accept established,related,untracked" connection-state=established,related,untracked
add action=drop chain=forward comment="defconf: drop packets with bad src ipv6" src-address-list=bad_ipv6
add action=drop chain=forward comment="defconf: drop packets with bad dst ipv6" dst-address-list=bad_ipv6
add action=drop chain=forward comment="defconf: rfc4890 drop hop-limit=1" hop-limit=equal:1 protocol=icmpv6
add action=accept chain=forward comment="defconf: accept ICMPv6" log-prefix=ipv6 protocol=icmpv6
add action=accept chain=forward comment="defconf: accept IKE" dst-port=500,4500 protocol=udp
add action=accept chain=forward comment="defconf: accept ipsec AH" protocol=ipsec-ah
add action=accept chain=forward comment="defconf: accept ipsec ESP" protocol=ipsec-esp
add action=accept chain=forward comment="defconf: accept all that matches ipsec policy" ipsec-policy=in,ipsec
add action=drop chain=forward comment="defconf: drop everything else not coming from LAN" in-interface-list=!LAN
/ipv6 nd
set [ find default=yes ] interface=bridge other-configuration=yes
/system clock
set time-zone-name=Europe/Madrid
/system identity
set name=hap_ac2
