ddlan
Bug in RC11 Bridge
Tue Dec 04, 2007 11:54 am
H(a)i,
Konfig related for Problem:
/interface eoip
add arp=enabled comment="" disabled=no mac-address=00:00:5E:80:00:06 mtu=1500 name="eoip-tunnel4" remote-address=10.0.9.1 tunnel-id=4
name="HOTSPOT" priority=0x8000 protocol-mode=rstp transmit-hold-count=6
add bridge=HOTSPOT comment="" disabled=no edge=auto external-fdb=auto horizon=none interface=eoip-tunnel5 path-cost=10 point-to-point=auto priority=0x80
add address-pool=NAT authoritative=after-2sec-delay bootp-support=static disabled=no interface=HOTSPOT lease-time=2h30m name="HotSpot"
add address=192.168.222.0/24 comment="" dns-server=192.168.222.1 domain="ddlan.local" gateway=192.168.222.1 netmask=24
add address=192.168.222.1/24 broadcast=192.168.222.255 comment="hotspot network" disabled=no interface=HOTSPOT network=192.168.222.0
add action=drop chain=input comment="drop invalid" connection-state=invalid disabled=no protocol=tcp
add action=accept chain=input comment="established related" connection-state=established disabled=no protocol=tcp
add action=accept chain=input comment="" connection-state=related disabled=no protocol=tcp
add action=accept chain=input comment="ICMP ratenlimitiert" disabled=no limit=50/5s,2 protocol=icmp
add action=drop chain=input comment="" disabled=no protocol=icmp
add action=accept chain=input comment="DNS" disabled=no dst-port=53 protocol=tcp
add action=accept chain=input comment="" disabled=no dst-port=53 protocol=udp
add action=accept chain=input comment="DHCP" disabled=no dst-port=67-68 protocol=tcp
add action=accept chain=input comment="" disabled=no dst-port=67-68 protocol=udp
add action=drop chain=input comment="drop all" disabled=no
over the tunnel works DHCP, DNS works only when last firewall rule is disabled.
/interface bridge settings> pr
use-ip-firewall: yes
use-ip-firewall-for-vlan: no
use-ip-firewall: no
no changes by problem
mfg
Thomas Böttcher
sorry for my english
michalkos
Re: Bug in RC11 Bridge
Wed Dec 05, 2007 12:12 pm
Hmm, I have same problem, FW rules not work very well with bridge !
I can't control interfaces included in bridge ! 2.9.xx versions work well. I turn on IP firewall on bridge settings.
ddlan
Bug is not only in the Bridge
Thu Dec 06, 2007 10:15 am
Same problem on ether1,
no Access to DNS when drop rule enabled
janisk
Thu Dec 06, 2007 11:47 am
have you set
 /interface bridge> settings set use-ip-firewall=yes
is that vaule is still no and your bridge is bypassing all the ip filter rules?
michalkos
Thu Dec 06, 2007 11:56 am
YES ! I have checked this options :o)
ddlan
Solved: Bug in RC11 Bridge
Sun Dec 09, 2007 5:05 pm
i added the red line and this works
add action=accept chain=input comment="" connection-state=established disabled=no protocol=udp
mfg
THomas Böttcher
Users browsing this forum: anav, BartoszP, Caldasart, elico, eworm, xvo and 163 guests
