I'm trying to get ghcr.io/farcaller/nextdns-docker:latest to run on mikrotik. For what it's worth it's a trivial OCI image that runs perfectly fine on linux in both docker and podman. RouterOS, however, fails to extract it:
13:11:31 container,info,debug getting layer sha256:06372458a23cc85259399605ca0b91d9cb68fe6cd8a2cf700cdfa894390e782a
13:11:33 container,info,debug layer sha256:06372458a23cc85259399605ca0b91d9cb68fe6cd8a2cf700cdfa894390e782a downloaded
13:11:33 container,info,debug failed to extract layer
13:11:33 container,info,debug was unable to import, container 8d50350a-15c8-4567-b007-1e2713166182
with file= the result is slightly different:
13:37:29 container,info,debug importing tar archived image: 1.tar
13:37:29 container,info,debug error: failed to extract
I tried both the remote-image=, and file= to make sure that's not some ghcr.io gimmick.
Any idea?
