ecylcje
RBGrooveGA-52HPacn - Dry Solder Join - How to open?
Sun Jan 07, 2024 4:06 pm
I've got a RBGrooveGA-52HPacn which disconnects/resets when I wiggle the ethernet connector (the link disconnect numbers increase etc). I believe the issue to be a dry solder join on the internal network connector joints.
It is out of warranty so I was going to give fixing it a go, but I don't know the type of tool required to open the 'Ring nut' on the top. I think it is some kind of hook wrench but I have no further clues on what I need to buy/do.
Does anyone have any experience on opening a 'RBGrooveGA-52HPacn' and what tools are required?
Thanks,
Chris
jaclaz
Long time Member
Long time Member
Re: RBGrooveGA-52HPacn - Dry Solder Join - How to open?
Sun Jan 07, 2024 9:21 pm
You mean the "ring nut" where the antenna connector is?
Similar to this:
https://www.binder-usa.com/us-en/produc ... 23-425-723
You can use normal pliers on the outside or bent circlip pliers like these (examples):
https://www.betafer.it/en/transmission- ... -1458.html
https://www.licotatools.com/product-BEN ... ERIES.html
on the grooves.
The tool used in a workshop for those is usually a "sector wrench" or a "compass wrench", but we are talking of bigger and much more tightened nuts.
What they use in factory is more likely something like this:
https://www.bagnoericambi.it/ricambio-c ... 2255500000
Users browsing this forum: No registered users and 4 guests
